anybody good in theorycrafting mathematic?
by yvon_la
05/24/16 06:51 AM
Aeroshell 22 v Mobil 28
by rooflessVW
05/24/16 06:36 AM
QSAD 5W20 VOA Bottled 2/25/16
by dustyroads
05/24/16 06:29 AM
What polish/wax to apply before Collinite 845
by pennzoil_guru
05/24/16 05:46 AM
Native American Advertising
by tony1679
05/24/16 05:45 AM
Akebono ProACT ceramic pads
by dlundblad
05/24/16 04:37 AM
3D printed plastic lower receiver
by Merkava_4
05/24/16 04:19 AM
How to install an AR-15 in your F150
by Merkava_4
05/24/16 03:39 AM
12 quarts Redline 5w30 $96.00 York pa area
by spiderbypass
05/24/16 03:00 AM
Trying to prevent high mileage leaks
by twincam00
05/24/16 02:04 AM
food depot
by urrlord
05/24/16 12:13 AM
Re-surfacing original GM wheels
by HM12460
05/23/16 10:28 PM
WeekendWarrior, emily, lex73, showstopr30, any_user
57966 Registered Users
75 registered (2015_PSD, badtlc, 2009Edge, Bandito440, Al, 1foxracing, 7 invisible), 975 Guests and 124 Spiders online.
57966 Members
66 Forums
249332 Topics
Page 1 of 2 1 2 >
#3332221 - 04/03/14 11:56 AM What's the best way of getting proper coolant mix?
Gokhan Offline
Loc: Los Angeles, California
I'll do a distilled-water flush. I have a separate radiator cock and engine-block cock, and I'll drain both. Specified system capacity is 6.6 qt per the OEM repair manual.
Do I just assume that this is the correct capacity and use 3.3 qt of concentrated antifreeze and top off the rest with distilled water to get the optimal 50/50 mix? Should I put a little more than 3.3 qt just in case? Heavy-duty heater core could result in a higher system capacity and the repair manual might not have taken into account a generously filled overflow reservoir. Of course, the overflow reservoir needs to be filled with the 50/50 mix separately as it won't mix easily by itself and I need to include the amount of the antifreeze put in there in the calculations.
Any tips are appreciated.
1985 Toyota Corolla LE, 4A-LC engine, ~ 263,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3332229 - 04/03/14 12:00 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
ABerns Offline
Loc: Iowa
If it were me, I'd put in 3.3qt of antifreeze, then top off with water (as you suggested).
I don't think it gets that cold where you are to worry about it, but you can always later test your anti-freeze to see its freezing point. If too low, just add a bit more anti-freeze.
#3332231 - 04/03/14 12:02 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
dparm Offline
Loc: Chicago, IL
Getting exactly 50/50 is not a big deal. You can safely run 60/40. Seeing as how you're in LA, you'll never know the difference.
2011 BMW M3 sedan ZCP
#3332249 - 04/03/14 12:19 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
datech Offline
Loc: us
I guess you measure how much you drain out and somehow calculate the amount.
#3332257 - 04/03/14 12:23 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
Gokhan Offline
Of course, I am not worried about freeze protection at all in LA, where it went down to 30 F only once in the last 20 years.
I am worried that (1) if I put less than 50% antifreeze, corrosion inhibition will be compromised, as the corrosion inhibitors will be too dilute, and (2) if I put more than 50% antifreeze, cooling efficiency will be compromised, as antifreeze is not as efficient as water in transferring heat. (3) In addition, antifreeze has very low viscosity and a very high concentration could result in leaks and coolant consumption.
#3332284 - 04/03/14 12:45 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
dparm Offline
Loc: Chicago, IL
Like I said, being off by a bit isn't going to be a big deal. Pour in the 3.3 quarts and fill the rest with water.
#3332289 - 04/03/14 12:49 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
mrsilv04 Offline
Loc: Illinois
A higher concentration of coolant has a higher boiling point... better than lower. Not sure where you got the opposite.
Dump in 4 quarts of coolant, and top off with water. You'll be fine. You're over-analyzing this big time.
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
#3332307 - 04/03/14 01:11 PM Re: What's the best way of getting proper coolant mix? [Re: mrsilv04]
Gokhan Offline
Of course, it has a higher boiling point and lower freezing point.
I am talking about the cooling efficiency -- how much a coolant can extract heat from the engine. Water is more efficient than antifreeze in extracting heat; so, in principle, your engine would run cooler with 100% distilled water than with an antifreeze mix. Of course, there would be little corrosion protection.
#3332380 - 04/03/14 02:22 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
Sayjac Offline
Loc: The Old North State
~3.3 qts. AF in system, top with distilled to full. Make a 50/50 mix AF/distilled for or in recovery tank. Good to go. Close enough.
#3332383 - 04/03/14 02:26 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
jrustles Offline
Loc: Ontario, Canada
If you use distilled exclusively in your system, then don't get too hung up on corrosion protection. In your climate, I'd be fine with 60/40 h2o/glycol (and my personal preference, a surfactant based wetting agent). I premix the coolant with distilled before I pour it in, and adjust later for any flushwater that may have been used and remained in the system, if it's any consequential amount.
"No matter how paranoid or conspiracy-minded you are, what the government is actually doing is worse than you imagine" W.Blum
#3332447 - 04/03/14 03:17 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
mrsilv04 Offline
Loc: Illinois
I give up. Go buy a new car. Problem solved.
horse
#3332476 - 04/03/14 03:58 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
Wolf359 Offline
Loc: MA
As someone else said, you are over analyzing things. Your car has fans, if it gets too hot, the fans will kick it. It's a moot point. You might save 2 cents in gas due to use less electricity to power the fans. Life's too short, just fill with water and move on. If you wanted to go nuts, make sure you use distilled water, but that would affect your savings from a going with a more efficient mix.
#3332514 - 04/03/14 04:30 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
901Memphis Offline
Loc: Northern Kentucky
Guy at work insisted on filling his pt cruiser with straight antifreeze and wondered why it overheated in the winter. Now he has castor oil in there and said it doesn't over heat anymore.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3332544 - 04/03/14 05:07 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
thrace Offline
Loc: USA
If you can drain out more than 50% of cooling system volume, your plan should work.
However have found on some cars, cannot drain out half of the stated total coolant system volume. If true, cannot put in full strength antifreeze in volume of 50% of stated total coolant volume and expect 50/50 mix after water flush. In that case, if coolant not too dirty or acidic, consider just drain and measure volume and fill with home brew or store bought 50/50 mix and repeat at or more often than manufacturer's recommendation.
#3332547 - 04/03/14 05:11 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
SHOZ Offline
Loc: Illinois
I flush mine with distilled. Then top off with 70/30. It usually comes out at 50/50.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Page 1 of 2 1 2 >
