Early review on 2015 Chrysler T&C
by badtlc
06/28/16 07:25 AM
New car storage
by JoelB
06/28/16 07:17 AM
How often should I change my oil.
by Greatwhite7
06/28/16 07:01 AM
'91 Mazda B2600i transfer case and trans oil?
by Jason280
06/28/16 03:59 AM
How to cut power to breaker box ?
by Merkava_4
06/28/16 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
06/28/16 01:07 AM
OK, before I lube it ...
by BrocLuno
06/28/16 12:53 AM
Toyota Japan Fluid SDS
by SXE10
06/27/16 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
06/27/16 11:25 PM
Considering a differential swap
by buck91
06/27/16 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
06/27/16 09:51 PM
Car Acronyms
by Marco620
06/27/16 09:46 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
72 registered (Benzadmiral, 69GTX, bbhero, AirgunSavant, 2015_PSD, Astro14, 9 invisible), 1375 Guests and 9 Spiders online.
58295 Members
66 Forums
250920 Topics
Page 2 of 2 < 1 2
#3332561 - 04/03/14 05:37 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
Brent_G Offline
Loc: Aberdeen SD
IF you are that worried about being perfectly exact measure out each and mix in a larger container before filling the system.
You engine isn't going to notice or care if you accidentally get 48/52 or something.
05 Grand Prix GTP
01 Ford F150
06 Yamaha R1
69 Roadrunner 528 Hemi
68 Dart GTS 512
71 Superbee's 440 and 383
87 Camaro 540 BBC
#3332572 - 04/03/14 05:51 PM Re: What's the best way of getting proper coolant mix? [Re: Wolf359]
eljefino Offline
Loc: ME
Originally Posted By: Wolf359
Originally Posted By: Gokhan
Originally Posted By: mrsilv04
A higher concentration of coolant has a higher boiling point... better than lower. Not sure where you got the opposite.
Of course, it has a higher boiling point and lower freezing point.
I am talking about the cooling efficiency -- how much a coolant can extract heat from the engine. Water is more efficient than antifreeze in extracting heat; so, in principle, your engine would run cooler with 100% distilled water than with an antifreeze mix. Of course, there would be little corrosion protection.
As someone else said, you are over analyzing things. Your car has fans, if it gets too hot, the fans will kick it. It's a moot point. You might save 2 cents in gas due to use less electricity to power the fans. Life's too short, just fill with water and move on. If you wanted to go nuts, make sure you use distilled water, but that would affect your savings from a going with a more efficient mix.
I spent a week flushing my cutlass ciera by simply draining the radiator. Every night I dumped the previous night's water and put new in. It ran better, less pinging, on pure water than it ever did with antifreeze. Since water conducts the heat away better it was cooling down a specific hot spot in the motor.
#3332589 - 04/03/14 06:15 PM Re: What's the best way of getting proper coolant mix? [Re: eljefino]
Sayjac Offline
Loc: The Old North State
... I spent a week flushing my cutlass ciera by simply draining the radiator. Every night I dumped the previous night's water and put new in. It ran better, less pinging, on pure water than it ever did with antifreeze. Since water conducts the heat away better it was cooling down a specific hot spot in the motor.
Well McGyver (j/k), while I personally wouldn't run pure water, that is an interesting anecdote about reducing the pinging. Never heard that one before, but an interesting result nonetheless. Since I don't want to bothered trying to find or use block drains, I usually use a similar method only using distilled water, and do it all in one day. Difference though after last drain, I fill with concentrated AF to ~50% capacity, then top off with distilled.
Running straight water wouldn't help me sleep at night. But for McGyver I could see it working out just fine.
#3332799 - 04/03/14 09:48 PM Re: What's the best way of getting proper coolant mix? [Re: 901Memphis]
artificialist Offline
Loc: Florida
Originally Posted By: 901Memphis
Guy at work insisted on filling his pt cruiser with straight antifreeze and wondered why it overheated in the winter. Now he has castor oil in there and said it doesn't over heat anymore.
My dad also made the mistake of using 100% antifreeze in his '71 Toyota Corolla.
He looked at the package of the antifreeze and noticed that 70% Antifreeze and 30% water would not boil at higher temperatures.
He then was sure 100% antifreeze was best, but he was wrong.
He said his cooling system had the worst corrosion he ever saw. He used a very strong chemical to clean his cooling system, and he truly needed it.
He then learned more about how cars work, so he didn't make mistakes in the future. He said that what he learned was that anti-corrosion additives weren't effective without water.
Anyway, I get as close to a 50/50 mix by putting a small amount of antifreeze in, then use an equal amount of water. After I do this several times, the system is full, and since the antifreeze goes in first, if I can't add water, I don't have much more than 50% antifreeze.
2010 Lancer Ralliart Sportback
#3333397 - 04/04/14 03:24 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
circuitsmith Offline
Loc: Wash, DC
Pouring concentrate into some systems can cause a problem:
http://www.agcoauto.com/content/news/p2_articleid/322
2006 Toyota Matrix 5-sp. 1zz-fe 5000mi/12mo OCI
Any major brand dino 5w-30 on sale
#3333501 - 04/04/14 05:38 PM Re: What's the best way of getting proper coolant mix? [Re: circuitsmith]
Gokhan Offline
Loc: Los Angeles, California
Great tip, thanks!
All set for measuring and mixing.
1985 Toyota Corolla LE, 4A-LC engine, ~ 264,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3333518 - 04/04/14 06:18 PM Re: What's the best way of getting proper coolant mix? [Re: Gokhan]
Rick in PA Offline
Loc: Southeastern, PA
Antifreeze = this.
Distilled water = that.
A quart of this, then a quart of that, then a quart of this, than a quart of that... Until full.
That's how I do it. No worries about if it wasn't totally emptied.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
#3333529 - 04/04/14 06:33 PM Re: What's the best way of getting proper coolant mix? [Re: circuitsmith]
901Memphis Offline
Loc: Northern Kentucky
I've heard that but plenty of us pour straight anti freeze right into our radiators and it seems to mix just fine.
I'm sure some have coolant analysis to back up the positive mix too.
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
Page 2 of 2 < 1 2
