Here's some testing on filtration, construction and flow.
Hope it helps.
Filtration:
1. Delco UPF 52
2. PureOne, Bosch Premium, and Donaldson
3. Purolator Classic, Mobil 1 Ext Perf. and K&N, Mann, Fram Extended Guard
4. Wix/NAPA Gold and Wix built Delco Duraguard PF53, Mahle
5. Ecore style AC/Delco, Supetech, STP, and Fram Extraguard
6. Denso, Honda, Hamp
Construction:
1. Mobil 1 and K&N
2. Wix/NAPA Gold, Fram Extended Guard, Mann, Mahle
3. Purolator, Bosch Premium and PureOne
4. Denso, Honda, Hamp
6. Fram Extraguard
Easy oil flow:
1. Denso, Honda, Hamp
2. Mann, Mahle, Purolator Classic, Proline, Fram Extraguard, Fram Toughguard
3. Mobil 1, K&N, Wix/NAPA Gold,
4. PureOne, and Bosch Premium
6. Delco UPF52 , Fram Extended Guard
Not all test were done on all filters as you can see.
Any of these sample filters tested will filter your oil and should do the job. If you want maximum flow with absolute minimum pressure drop from the filter, you may decide to choose from very low restriction filters.
