Material Safety Data Sheet – SLIP 2000
I. SPS Marketing Inc. 355 Mandela Parkway Oakland, CA. 94607 (707) 585-8329
Prepared by: Mike Cork Date Created: 01/05/04 Last Revision: 01/05/05
Trade Name: SLIP 2000 Weapons Lubricant Label:Slip 2000 Gun Lube
II. Hazardous Ingredients
Hazardous Determination: .....................Material is not hazardous as defined by OSHA hazard communication standard,
29CFR1910,1200. Non-hazardous ingredient: 40 to 70 percent synthetic hydrocarbon-CAS
#68515-33-3 5 to 25 percent metallic salts CAS#-mixture (trade secret) components of this
material are not known to be hazardous. 5 to 20 percent synthetic hydrocarbon-CAS#
-trade secret. This material is not known to be hazardous.
III. Physical Data
Boiling Point: ................. ..........................650°-790° F Melting Point:………..110° F
Specific Gravity:.............. .........................895 Vapor Pressure:………Nil
Vapor Density: ............... ..........................N/A Solubility in H2O:……Nil
% Volatile by Volume:... ..........................Nil Evaporation Rate: ......N/A
Appearance and Odor:.... ..........................Light Green/brown pH: .............................Neutral
IV. Fire and Explosion Data
Flash Point (Test Method):........................410° F COC
Auto Ignition Temperature:.......................715° F
Flammable Limits in Air: ..........................N/A
Extinguishing Media: .......................... Water spray, dry chemical, foam or carbon dioxide.
Special Fire fighting Procedures: ..............Water or foam may cause frothing. Use water to keep containers cool. Water spray
may be used to flush spills.
Unusual fire/Explosion hazard:................. Products or combustion may contain carbon monoxide, carbon dioxide, or other
Materials. Do not enter enclosed or confined area without proper protective
Equipment, including respiratory equipment.
V. Health Hazard Information
Inhalation: ..................... .......................... No volatiles. Inhalation is unlikely route. Acute inhalation in rats LC50 Mg/Liter.
greater than 2.0 (non toxic).
Skin Contact: .................. .......................... Repeated exposure can cause irritation. Clothing (dry) and gloves (impenetrable). Wash
with soap and water. Primary skin irritation in rabbits: Ave. Score: 1.88 (mild irritant)
Skin absorption: Unlikely. Use protective gear during continued or extreme exposure.
Eye Contact: ................... ..........................Can cause irritation. Use safety glasses at all times, goggles when handling in overhead or when agitating. Eye
Irritant in rabbits.. Washed—mild irritant. Unwashed—minimal irritant.
Ingestion: ........................ .......................... Oral LD50 (Rat) at 5000 mg/kg. No deaths.
Effects of Overexposure
Acute Overexposure:...... .......................... Potential skin and eye irritant.
Chronic Overexposure: .. ..........................Product may cause irritation to eyes, lungs, or skin after prolonged or repeated exposure.
Overexposure may cause central nervous system depression.
Emergency and First Aid Procedures
Eyes: ............................... ..........................Wash with water for 15 minutes. If irritation persists, consult physician.
Skin:................................ ..........................Use protective clothing for sensitive skin. Wash with soap and water to remove.
Inhalation:....................... ..........................Remove victim to fresh air and provide oxygen if breathing is difficult.
Ingestion: ........................ .......................... If large amounts are ingested, do not induce vomiting. Consult physician, as gastric lavage may be indicated.
VI. Reactivity Data
Conditions Contributing to Instability: ..... Generally stable. Keep away from heat sources and open flame.
Incompatibility: .............. ..........................Keep away from strong oxidizers.
Hazardous Decomposition Products: ........ Generally none, except as carbon monoxide during incomplete combustion.
Hazardous Polymerization: .......................None
VII. Disposal, Spill or Leak Procedures
Aquatic Toxicity:............ ..........................None know.
Waste Disposal Method: ..........................Use absorptive material and dispose at professional disposal complying with state, federal and local regulations.
Material is Spilled or Released:................. Contain spill immediately in smallest area possible. Soak up and dispose in professional disposal fashion.
Keep out of sewers or bodies of water.
Neutralizing Chemicals: . ..........................None indicated
VIII. Special Protection Information
Ventilation:..................... ..........................Normal shop ventilation
Respiratory: .................... ..........................None normally required except as noted in Sec III
Eye:................................. .......................... Always wear safety glasses. Chemical goggles if danger of splash or drip exists.
Gloves:............................ ..........................Recommend impervious type.
HMIS rating:................... ..........................Health 1, Flammability 0, Reactivity 0, Personal Protection A
IX. Special Precautions
Not listed as a carcinogen or potential carcinogen by NTP, IARC or OSHA
Handling or storage requirements............D.O.T. Label – Not regulated. OSHA Label – Not regulated. Product is Class III B Combustible liquid per
NFPA Code N. 30-1984. Store and handle accordingly.
III. Physical Data
VI. Reactivity Data
