Premium Guard Filters
by CapitalTruck
04/30/16 01:54 PM
Wheel centering ring
by Donald
04/30/16 01:22 PM
tight pocket knife
by spasm3
04/30/16 01:04 PM
Any Jack Russell owners?
by chrisri
04/30/16 12:10 PM
Tire ply description as listed on sidewall
by Cressida
04/30/16 11:43 AM
spec that measures ability of oil to cool an engin
by paulri
04/30/16 11:41 AM
Best USA Produced Olive Oil
by hatt
04/30/16 11:29 AM
How often do you run malware bytes?
by Doog
04/30/16 11:03 AM
F250 Rear Diff Fill Plug Seized
by Mantooth
04/30/16 10:48 AM
What oil should I use for 2000 cavalier that burns
by SeasonalEclipse
04/30/16 10:47 AM
Why is HDEO better for OPE, than regular oil?
by NH73
04/30/16 09:53 AM
CASTROL EDGE 5W-40 FST no ACEA A3/B4 ?
by alcyon
04/30/16 09:53 AM
paydase, Scopx, speedysmitty, hdwizard21, raihan
57751 Registered Users
78 registered (AirgunSavant, bdcardinal, Astro14, Atesz792, Bill_G, 5 invisible), 2060 Guests and 326 Spiders online.
57751 Members
66 Forums
248253 Topics
Page 1 of 2 1 2 >
#3331050 - 04/02/14 06:55 AM What straight wt oil to try for 2000 RHD Cherokee
Raye7r Offline
Loc: Indiana
Have a 2000 RHD Cherokee (200K miles) that got hot on mail route and oil pressure went away (this was a few years back,radiator blew). Been getting by with 15 40 Synthetic in winter, regular 15 40 in summer. In both cases a bottle of STP added. The oil light has started to come on at idle after it is warm. Some one suggested going to a straight weight. Don't want to start thin and waste it. Don't want to go too thick to begin with. Whats your best guess on the weight I should try first. Thanks.
It is used as a back up vehicle now so not driven all the time. The oil light started coming on this winter.
Edited by Bill in Utah (04/02/14 08:52 AM)
Edit Reason: Changed subject to be more useful in search
#3331065 - 04/02/14 07:18 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Astro14 Online   content
Loc: Virginia Beach
If the oil light is coming on with 15W40 in it, no monograde/straight weight short of a 50 is going to make any difference. At operating temp, a 15W40 and a monograde 40 are just about the same. I think the advice that you received is uninformed...
So, best guess? Try something like the Valvoline racing 50 for a monograde...but it's going to be awful trying to get it started in cold weather...I think your best bet is to bump up to a 20W50 multigrade...any brand will do...easier starts, slightly higher viscosity than the 15W40 you're running.
It's worth putting a known/calibrated oil pressure gauge on this when it's hot...would be nice to know what your actual pressure is...instead of trusting the idiot light. Given the age/history, your bearings are likely very worn...and nothing short of a rebuild is going to fix this permanently.
Edited by Astro14 (04/02/14 07:23 AM)
32 Packard 15W40
90 4Runner 10W40 Edge
92 300E 0W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
#3331109 - 04/02/14 07:47 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Plumber Offline
Loc: USA
Try the 20w50
#3331123 - 04/02/14 07:55 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Zaedock Offline
Loc: Massachusetts
200K? Verify the sending unit and oil pressure with a mechanical gauge. If low, replace the oil pump.
It's $60-$70 and you can upgrade oil pan gaskets to the one piece as well (rear main is right there too). I did one on a New Hampshire house call on the ground in winter. It took me 4 hours.
If you're not interested in looking into it/repairing correctly, as I suspect because it happened a few years ago, then just drive it. SAE50 might help in summer, but is a silly bandaid IMO, as lubrication will suffer just to keep an idiot light off.
2012 F150 Ex-cab 5.0L/2004 Malibu Maxx LT
1992 YJ "The Heep"/1994 Olds Cutlass Ciera 3.1/auto
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3331147 - 04/02/14 08:15 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
armos Offline
Loc: California
I agree that you need to verify the problem. Electric oil pressure senders are not trustworthy. Even new ones are sometimes inaccurate. A mechanical gauge should be used to verify what the pressure really is when the light is coming on.
If that's not an option, and you have to trust the sender, then at least make sure you're using the proper OEM spec sender (Mopar or whatever label they use now. I've had major accuracy problems with knockoff brands on GMs anyway). But if you can, a mechanical measurement is 100x more meaningful than any replacement sender.
Assuming the pressure problem is real, then I'd suggest 20w50 to nurse it along, and be easy on it. If it starts knocking, it's done and the damage will accelerate quickly. In that event definitely stop driving it until you can get it rebuilt.
Also consider the possibility that the previous overheating may have blown a head gasket (maybe worse, especially if it's an aluminum head). There could be slow contamination that's thinning the oil.
#3331149 - 04/02/14 08:17 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
spasm3 Online   content
Loc: out there
As Zaedock and armos have suggested, you may be fixing a problem that does not exitst. Your pressure may be fine, at that mileage replace the sender.
13 elantra 42k 5w30 ultra
03 chevy avalanche65k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 74k 5w30mc5k
#3331157 - 04/02/14 08:22 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: armos]
Zaedock Offline
Loc: Massachusetts
Yeah, forgot to mention this ^^^
In my experience, cheap replacement sending units are just that, cheap!
#3331165 - 04/02/14 08:32 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
Chevron Delo 400 30w and add a can of STP
or
Amsoil 60w motorcycle oil
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#3331173 - 04/02/14 08:37 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: LargeCarManX2]
Zaedock Offline
Loc: Massachusetts
or
I had a lot of Delo SAE30 and 15W40 from the '05 sale. The SAE30 is on par with a 15W40 when cold and is 12.1cST @ 100*C when hot, thinner than the 15W40.
I also wouldn't put Amsoil anything into this engine $$. Supertech all the way!
#3331188 - 04/02/14 08:54 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Chris142 Offline
Loc: apple valley, ca
20w50 if the oil pressure is actully low.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3331213 - 04/02/14 09:16 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Miller88 Offline
Loc: Onondaga County
Check with a mechanical gauge.
If it's really low - why not stick another engine in it?
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
#3331239 - 04/02/14 09:46 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Donald Offline
Loc: Upstate NY
I agree you need to find out if its really low oil pressure with a mechanical gauge. But given your scenario it certainly may be. Certainly an oil pump is worth trying.
After that I think you are looking at a rebuild. Does it also burn oil?
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3331240 - 04/02/14 09:47 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Stelth Offline
Loc: California
If I were trying to nurse along such a vehicle, I'd see if I could get some Penrite HPR30 20w-60. According to Penrite, it's available in the US, and should give better cold-start performance than a heavy straight grade.
Experts are often wrong, but rarely in doubt.
#3331245 - 04/02/14 09:53 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
threeputtpar Offline
Loc: Appleton, WI
NAPA has their house brand 15W-50 on sale for $3.69/quart this month. Stock up.
2013 Honda Odyssey Touring Elite - M1 5W-20 / M1-101 40k miles
2008 Ford Taurus X - Resolute 5W-20 / MC FL-400S 128k miles
#3331252 - 04/02/14 10:03 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
michaelluscher Offline
Loc: Tri States Little Italy
First, actually check oil pressure with mechanical gauge, or replace the cheap sender.
If pressures good, replace sender.
Then, move on to the oil pump. Under $100 including refreshing several gaskets.
'06 Toyota Camry SE V6 3MZ-FE 51k
'01 Mercury Villager Estate VG33E 48k
'06 Ford Taurus SE Vulcan 48k
'13 Chrysler 300 3.6 Pentastar 45k
2012-2015
Page 1 of 2 1 2 >
