2002 GMC Yukon Climate Control Problems
by Kgrant
10 minutes 16 seconds ago
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
Today at 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
Yesterday at 11:08 PM
GM Oil Life Update
by CapitalTruck
Yesterday at 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
Yesterday at 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
Yesterday at 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
Yesterday at 08:48 PM
why would someone want to pay with a phone?
by turtlevette
Yesterday at 08:16 PM
The connection was reset problem
by Triple_Se7en
Yesterday at 08:14 PM
BIG PROBLEM!
by Avery4
Yesterday at 08:03 PM
11,000 miles on a BMW
by BigJohn
Yesterday at 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
Yesterday at 07:20 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
41 registered (AutoCoil, asand1, bbhero, akela, AJP, 4 invisible), 613 Guests and 205 Spiders online.
56834 Members
66 Forums
244295 Topics
Page 2 of 2 < 1 2
#3264881 - 01/30/14 01:05 PM Re: Oil recommendation [Re: wckelly]
wckelly Offline
Loc: MS
I think it's settled, I'm swapping to Mobil 1 Syn High Mileage 5w-20. Is there a best practice for swapping from Conventional to Synthetic? Does it matter? I'll be draining Mobil 1 Super 5000 conventional and replacing with synthetic, any problems with new syn oil mixing with the old conv oil left behind?
Looks like the consensus is to NOT put seafoam in the crankcase and just let the oil help keep the engine clean.
Fuel additive suggestions seem to lean towards techron or gumout. I've used techron for years and will start adding to fuel system again. I do still plan on using seafoam occasionally though the vacuum line as a direct treatment to the engine.
#3329301 - 03/31/14 03:45 PM Re: Oil recommendation [Re: wckelly]
wckelly Offline
Loc: MS
I've been running Mobil 1 Syn High Mileage 5w-30 for about a 1.5 months now and I'm noticing quite a bit of blueish smoke when I first crank my truck. I'm assuming that since this is a thinner oil than what I was using and seals having some wear on them is the reason... Should I be concerned at all? It hasn't affect oil levels yet but I don't think it's been long enough for that. Should it eventually (and hopefully) stop if the high mileage additives actually work properly on the seals? I'm about to be changing plugs, COPS, fuel filter, etc... Was curious if I should do anything to address this.
Thanks,
Chris
#3329399 - 03/31/14 05:06 PM Re: Oil recommendation [Re: wckelly]
Wilhelm_D Offline
Loc: Tacoma, WA
Originally Posted By: wckelly
Thanks for the suggestion so promptly... Just out of curiosity, why? I understand the oil recommendation but why motorcraft over fram filter and why no seafoam in crankcase? Would anything be good in the crankcase to remove unwanted materials not disposed of by just pulling the drain plug?
A high quality motor oil removes unwanted materials not caught by the filter when you pull the drain plug.
Inexpensive Fram filters, and Ecore Champion-made filters, look pretty chintzy when disassembled, with lots of glue and cardboard.
However, they do seem to filter okay.
Motorcraft and its factory brothers, Purolator and Bosch, contain a lot more metal and quality parts. Whether the oil knows that is another matter.
#3330044 - 04/01/14 08:08 AM Re: Oil recommendation [Re: wckelly]
wckelly Offline
Loc: MS
At what point should I be concerned with burning a little oil at start up? How much is considered too much oil to add between changes?
#3330164 - 04/01/14 09:59 AM Re: Oil recommendation [Re: Ramblejam]
NormanBuntz Offline
Loc: Coastal NC
Originally Posted By: Ramblejam
Chris,
Hello, and welcome to the forum!
Get rid of the Engine Restore, Fram filter, and Seafoam.
Mobil Super High Mileage and a Motorcraft filter would be appropriate for both.
Agreed, with QS Defy as a second option. It may be a wive's tale, but Engine Restore has a reputation for being harsh and a last resort.
Badges? We ain't got no badges. We don't need no badges.
2015 Subaru Outback 2.5i
2007 Honda Ridgeline
2007 Infiniti M35
1987 Alfa Spider Veloce
Page 2 of 2 < 1 2
