MicroGreen filter at 8,114 miles
by Rex
05/30/16 02:33 PM
Opinions on this 2006 Lincoln
by Milkman
05/30/16 01:40 PM
I'm sure these have been posted before but...
by Yup
05/30/16 01:24 PM
Weedeater nylon string cartridge doesn't feed out
by 69GTX
05/30/16 01:23 PM
Larger Oil Filter for 2006 Highlander 2.4 Four Cyl
by Samzone
05/30/16 01:01 PM
I bought a Stihl weed trimmer, but...
by skyactiv
05/30/16 01:01 PM
2010 Tacoma oil selection help
by bchannell
05/30/16 12:52 PM
Will this "Universal" coolant work on my Car?
by Miller88
05/30/16 11:37 AM
Repelling heat
by mjoekingz28
05/30/16 11:27 AM
Wrong Dipstick? Honda Accord 2.4 Reading Low
by ThirdeYe
05/30/16 09:09 AM
radiator hose install, 08 Matrix.
by JustinH
05/30/16 08:56 AM
Bendix CT-3 Brake Pads
by RevelationLion
05/30/16 08:38 AM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
62 registered (alan003, aquariuscsm, bbhero, BeerCan, 69GTX, Bebop367, 9 invisible), 1882 Guests and 334 Spiders online.
58023 Members
66 Forums
249600 Topics
Page 3 of 4 < 1 2 3 4 >
#3329766 - 03/31/14 09:58 PM Re: Help! The wrong oil was used! [Re: turtlevette]
dave1251 Offline
Loc: Maricopa, AZ
Common sense.
Keep in mind I am one that prefers thin as possible.
Too thin you have a dead engine. Too thick the engine is just a little less efficient.
don't use.
#3329815 - 03/31/14 10:47 PM Re: Help! The wrong oil was used! [Re: Mantachieman]
Merkava_4 Offline
Loc: Clovis, CA
Holy wall of text Batman!! shocked2
#3329877 - 04/01/14 12:57 AM Re: Help! The wrong oil was used! [Re: dave1251]
turtlevette Offline
Loc: Massachusetts
Originally Posted By: dave1251
Common sense.
There is a study somewhere here on the site that does a statistical analysis on all the UOAs here. The 20wt oils show lower iron as a pattern than the 30wt.
I'll try and find it again.
#3329890 - 04/01/14 01:54 AM Re: Help! The wrong oil was used! [Re: turtlevette]
turtlevette Offline
Loc: Massachusetts
#3330128 - 04/01/14 09:21 AM Re: Help! The wrong oil was used! [Re: Mantachieman]
Dallas69 Offline
Loc: Texas
Leave it in
It wont hurt at all
I am starting to think that BITOG does more harm than good cause folks start over thinking
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Valvoline Maxlife 5-30
Motorcraft filter
#3330143 - 04/01/14 09:42 AM Re: Help! The wrong oil was used! [Re: Mantachieman]
thomasew Offline
Loc: North Carolina, USA
Don't feel bad, one time I took my truck to the dealership for some stuff, and an oil change. I had the oil and filter in a box in the open bed of the truck, and I told them to use the oil I provided. When I went back to get it, the oil that I bought, and the filter were still in the box in my truck bed. I thought about asking them why, etc., but decided to just forget it, and go on. I am pretty sure I had mobil 1 and a wix in the box, but that is not what went on and in the truck. I figured it isn't worth getting into it with them, so, I didn't.
#3330154 - 04/01/14 09:49 AM Re: Help! The wrong oil was used! [Re: turtlevette]
dave1251 Offline
Loc: Maricopa, AZ
Originally Posted By: turtlevette
You realize trying to use UOA's on a micro level to establish wear trends are widely inaccurate. Correct?
don't use.
#3330328 - 04/01/14 01:05 PM Re: Help! The wrong oil was used! [Re: Mantachieman]
Black_Thunder Offline
Loc: Wisconsin
i know companies that ran bulk oil in everything, including company cars spec'ed for 5w20.
bulk oil was 5w40 to 15w40, then it was 10w30 hdeo for awhile, now its 10w40
I'd buy Callahan autoparts if I could.
#3333743 - 04/04/14 10:56 PM Re: Help! The wrong oil was used! [Re: Mantachieman]
TiredTrucker Offline
Loc: Central Iowa
While the general consensus is that the 20w oils were introduced because of CAFE standards, I have read some stuff recently that the main motivation for the 20w oils over 30w oils was that the 20w will dissipate heat more quickly. Not sure if that was the reason, but a lighter fluid will generally dissipate heat quicker.
In order to know what is bad, you have to know what is good. The question them becomes, what is the source of knowing what is good?
#3333790 - 04/05/14 01:03 AM Re: Help! The wrong oil was used! [Re: TiredTrucker]
Shannow Offline
Loc: Oz
that's a claim that demands some evidence...got some ?
#3333800 - 04/05/14 01:29 AM Re: Help! The wrong oil was used! [Re: Shannow]
turtlevette Offline
Loc: Massachusetts
The thinner oil flows from the rod bearings faster providing more cooling oil to the piston. You know, like in power plants more flow transfers more heat. Get out your thermo book.
#3333801 - 04/05/14 01:43 AM Re: Help! The wrong oil was used! [Re: turtlevette]
Shannow Offline
Loc: Oz
With a positive displacement pump that shifts the same volume of oil for each and every revolution ?
#3333805 - 04/05/14 02:09 AM Re: Help! The wrong oil was used! [Re: Shannow]
turtlevette Offline
Loc: Massachusetts
The oil pump bypasses oil at anything above fast idle.
#3333812 - 04/05/14 02:18 AM Re: Help! The wrong oil was used! [Re: turtlevette]
Clevy Offline
Loc: Saskatoon canada
What?
First off an oil pump doesn't bypass anything. Some new engine have an oil pump that is variable,meaning basically it's able to adjust volume depending on engine needs however I'm not aware of any pump that is able to bypass anything.
Either the engine has a bypass built in to the oil circuit and when pressure exceeds a specific psi it will bleed off the excess pressure back into the pan,or the oil filter is equipped with the bypass valve.
So again. You're incorrect.
This isn't even fun anymore. Pointing out the flaws in your posts is getting old. It's such a common event lately that it's become stale.
Thanks for trying though.
All a steer can do is try....eh
2006 Charger RT
Miles x 2 per oil filter
#3333865 - 04/05/14 06:53 AM Re: Help! The wrong oil was used! [Re: Mantachieman]
demarpaint Offline
Loc: NY
Another vote for leaving it in.
God Bless Our Troops
