2016 Volkswagen Tiguan Oil filter - Weird Design?
by FordBroncoVWJeta
Today at 02:21 AM
New old ride
by SEBZX79
Yesterday at 11:25 PM
Motor Trend Visit with Valvoline
by tenderloin
Yesterday at 10:46 PM
Fixing Tractors a no-no, Are cars next?
by user52165
Yesterday at 10:38 PM
Cosmetic only or replace
by ram_man
Yesterday at 09:55 PM
Wooden Motorcycle Piston from Vietnam
by KeithS_NW_Ohio
Yesterday at 09:49 PM
Castrol Edge for hard-driven turbo + DI
by Atomic
Yesterday at 09:27 PM
2001 Camry LE V6 - Synthetic ATF Recommendation
by 01CAMRY
Yesterday at 08:39 PM
Delo 400?
by Sealbilly
Yesterday at 07:17 PM
Noob question about chain maintenance
by JeepWJ19
Yesterday at 07:00 PM
Rural King Full Synthetic Oil Sale...
by AnthemBassMan
Yesterday at 05:16 PM
Mobil 1 EP oil filter - Cross Reference
by Kung_Faux
Yesterday at 05:08 PM
rfabrocini, Tobin28, r0k, KNA, Roanoke6370
58598 Registered Users
31 registered (Charlie1935, chrisri, Boomer, bullwinkle, bmod305, denver1, 1 invisible), 675 Guests and 17 Spiders online.
58598 Members
66 Forums
252250 Topics
#3330079 - 04/01/14 08:38 AM 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks
Beanboy Offline
Loc: Beantown
Posted my first oil report here back in 2006, back again with the same car with more mods. Got my numbers back from Blackstone and just wanted confirmation as to what may be going on before I drop the car off for a rebuild.
I sent two samples in, lead was high in one of the samples (10ppm) but all other metals and oil properties were normal in both. I don't know which sample is which (had them stored in clean containers), but assume the 10ppm lead one was the 2nd.
It looks like lead is present in the larger bearings in the EJ255, which points to bearing wear. But without any iron, it seems I caught it fairly early? Not getting any audible knock or performance/fuel economy changes, and the current mods have been on the car for 5 years/40K miles.
Only thing I can think of is that perhaps my fuel pump is going/bad gas caused detonation and I hammered the rod bearing(s) and/or had a lubrication issue?
Next Steps
I haven't checked the IAM value in a very long time, so I'll be tracking down a cable and checking to make sure IAM is still 1.0. Anything else that I should check (cut oil filter at last change and it was clean) or any thoughts on what happened/how to avoid it going forward much appreciated.
Thanks!
-B
Code:
	      Sample   Average
ALUMINUM	3	3
CHROMIUM	1	1
IRON	        7	8
COPPER	        9	13
LEAD	        10	5
TIN	        0	1
MOLYBDENUM	45	48
NICKEL	        0	0
MANGANESE	0	0
SILVER	        2	1
TITANIUM	0	0
POTASSIUM	2	1
BORON	        30	22
SILICON	        4	8
SODIUM	        7	5
CALCIUM	        2141	2086
MAGNESIUM	28	22
PHOSPHORUS	709	683
ZINC	        895	802
BARIUM	        0	0
Edited by Beanboy (04/01/14 08:39 AM)
#3330203 - 04/01/14 10:51 AM Re: 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks [Re: Beanboy]
Eddie Offline
Loc: Florida, Cape Coral
Not sure I agree with your diagnoses with only 10 PPM of lead on one UOA. Possibly have Blackstone redo the analysis or if you still have more sample, send out to another lab before going to rebuilding. My opinion. Ed
CX5 Touring 2.5L :-)
#3330229 - 04/01/14 11:16 AM Re: 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks [Re: Beanboy]
Nate1979 Offline
Loc: Portland, OR
If you worry so much about it just run a really short OCI as a rinse, do a UOA and see if the Pb is still high. No need to go to drastic measures over one UOA.
2015 GMC Sierra 2500 6.0L Factory fill
2010 Subaru Forester 2.5X QSUD 5w-30 w/ Fram Ultra
#3330237 - 04/01/14 11:20 AM Re: 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks [Re: Beanboy]
05LGTLtd Offline
Loc: Va
Check the turbo shaft play before going right to a short block rebuild?
2005 Legacy GT, Synpower 5w-40
2010 Forester SOHC, Edge 0w-30
#3330243 - 04/01/14 11:26 AM Re: 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks [Re: Beanboy]
Wilhelm_D Offline
Loc: Tacoma, WA
10 ppm of lead would not necessarily lead me to rebuild the engine unless I am experiencing operational issues.
Looking at your posts you report running something like this:
Stage 2 Power Package
over the last eight years.
Wouldn't that explain the additional stress on the bearings?
#3330281 - 04/01/14 12:11 PM Re: 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks [Re: Beanboy]
Beanboy Offline
Loc: Beantown
Along with the elevated Pb, did have visible flecks in the oil on the last two changes, which is why I sent the oil in for analysis. Is there a particle size between visible to the naked eye, what gets caught by the filter, and what can be measured via oil analysis?
#3330559 - 04/01/14 05:16 PM Re: 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks [Re: Beanboy]
bluesubie Offline
Loc: NJ
My lead jumped to 10 right before a turbo failure. Stop running girly man oil in an '05 Subaru turbo. smile
Where's the rest of the uoa ? Are you still running the AVCS/turbo banjo bolt screens ?
-Dennis
'04 Subaru Forester 2.5XT
Mobil 1 0W-40
#3330630 - 04/01/14 06:56 PM Re: 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks [Re: Beanboy]
cptbarkey Offline
Loc: texas
turbo's blowing in LGT's seem to be the rule, including the one i bought recently which is now in the queue to be repaired sometime this fall. I would suggest proactively replacing yours.
#3331434 - 04/02/14 02:00 PM Re: 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks [Re: Beanboy]
Beanboy Offline
Loc: Beantown
Aftermarket turbo hss been in place for 5 years/40K. Forced Performance 20G. Banjo bolt screens removed at the same time.
Sourcing a log cable (got rid of APV1 when I went for a custom tune) to check IAM.
I think the next step beyond checking for knock will be dropping pan, checking oil pickup and inspecting turbo before going for a full rebuild starts. Hate to take the engine out and find it was a journal bearing in the turbo going.
#3331488 - 04/02/14 03:01 PM Re: 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks [Re: Beanboy]
05LGTLtd Offline
Loc: Va
Did you upgrade the oil line with the turbo? Or are you running stock line with banjo filter pulled?
#3335088 - 04/06/14 04:21 PM Re: 05 Subaru LGT 4K,5w30 PP , 10ppm Pb + gold flecks [Re: Beanboy]
Beanboy Offline
Loc: Beantown
Oh WTH?
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=Oil_Supply
Just read that in 2009 FP said to go with larger banjo bolt and oil line? Wish I had known about this change since I bought in the fall of 2007.
Anway, checked IAM today and still at 1.0, so the ECU hasn't made any overall corrections due to knock.
So I think it may come down to a turbo rebuild/replace oil pan and cooler, and maybe new oil pickup and hope that no damage was done to other bearings. Thoughts?
