out with the subaru and in with a new Fusion
by stygz
08/27/16 04:33 PM
Brand perception
by OldEuroCarLover
08/27/16 04:16 PM
Looking for a super economical car, accent ?
by sirgerman
08/27/16 04:00 PM
Cooling system hoses. Old but not brittle.
by Martin10
08/27/16 03:52 PM
CHEVRON DELO Reveals their line up of CK-4/FA-4
by Powerstroke
08/27/16 03:07 PM
New belt or new belt tensioner?
by Parlay_Slow
08/27/16 02:53 PM
PP 5w-30 Amazon subscribe and save
by buck91
08/27/16 01:52 PM
My parents took my nissan s13 silvia
by Nissan101
08/27/16 01:21 PM
New Hyundia Santa Cruz pickup with extendable bed
by gfh77665
08/27/16 01:12 PM
Pro Line PPL 14610 4,000 miles CUT OPEN
by car51
08/27/16 01:00 PM
STP S-10590 6,000 miles CUT OPEN
by car51
08/27/16 12:47 PM
Store Kerosense in Non-Vented Container?
by ET16
08/27/16 12:16 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
65 registered (andrewp1998, 2cool, barkingspider, 4WD, AirgunSavant, Astro14, 7 invisible), 1647 Guests and 35 Spiders online.
58935 Members
66 Forums
253634 Topics
#3329888 - 04/01/14 01:43 AM How to check if oil control rings are ok?
Spetz Offline
Loc: Australia
My car (3.5L Diamante) consumes oil.
It does not smoke on cold start up.
It smokes when it idles a bit and I depress the throttle suddenly.
Uses 1 quart to about 1,300 miles roughly.
Runs smooth, quiet and has good power.
118K miles, full service history.
I was told if it was the valve seals that there would be smoke on cold start up but there is none.
I know I can do a wet/dry compression test to test the piston rings, but what if just the oil control rings are worn?
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 137,000 miles
#3329954 - 04/01/14 06:32 AM Re: How to check if oil control rings are ok? [Re: Spetz]
01_celica_gt Offline
Loc: St. Louis, MO
A teardown, all 4 Teardowns I have witness only 1 of the 4 engines was actually outside the car. Oil Control ring was the culprit each time as all compression tests read good numbers.
1ZZ-FE (fixed)
2ZZ-GE (fixed)
2AZ-FE (coming 2014 summer, same issue)
D16Y7 (fixed, sold separately just the engine)
D16Y7 (coming 2015 summer, same issue)
All were neglected by previous owners expect the 2AZ-FE, it was run on cheapest Dino since new at 3-4k OCI. Using Full Synthetic oil was dramatically reduced oil consumption, but that may not work on every engine.
Red/Black 01 Celica GT 1ZZ-FED(Rebuilt @ 211/144) @ 211/145k
Red 02 Corolla S 1ZZ-FED(Rebuilt @ 140k) @ 141k
All Autos!
#3330006 - 04/01/14 07:24 AM Re: How to check if oil control rings are ok? [Re: Spetz]
JHZR2 Offline
Loc: New Jersey
One test I've heard is to take it out on the highway in lower gear, so it's spinning fast, say, 5500 rpm. Then coast down to about 3000, and hit it to see what sort of smoke comes out.
I could never get anything with that test, nor did I ever see smoke at startup or any other time.
#3330020 - 04/01/14 07:45 AM Re: How to check if oil control rings are ok? [Re: Spetz]
Spetz Offline
Loc: Australia
01_celica_gt, are you saying the oil control rings can be changed with the engine in the car?
JHZR2, I thought this was to check valve seals? As the high vacuum situation would cause oil to build up from the top?
#3330027 - 04/01/14 07:53 AM Re: How to check if oil control rings are ok? [Re: 01_celica_gt]
Doog Offline
Loc: North Coast
1ZZ-FE (fixed)
2ZZ-GE (fixed)
How many miles on the 2AZFE?
The difference between a beer and your opinion is that I asked for a beer... well except for just now..Coffee2
#3330041 - 04/01/14 08:06 AM Re: How to check if oil control rings are ok? [Re: Doog]
Loc: St. Louis, MO
180k now
All Autos!
#3330047 - 04/01/14 08:10 AM Re: How to check if oil control rings are ok? [Re: Spetz]
Loc: St. Louis, MO
http://www.toyotanation.com/forum/131-8th-generation-1998-2002/402362-diy-oil-consumption-fix.html
That same concept can be applied to any engine I guess, as far as my cars, it worked and should work on the ones that are to go through with this process.
All Autos!
