Originally Posted By: supercity
Valvoline dont give many specs on their website. I'd be happy to use it as a chassis grease but I would use something else in a bearing. Moly is not the best additive to use in a bearing or UJ. It can cause the balls to slide rather than roll.
IIRC when I called their tech line last year they confirmed that Durablend and Synpower are approcx 1% moly content, not sure if that's weight or volume, though.
Their PDF lists the following:
Originally Posted By: Valvoline Product Info PDF
VALVOLINE SYNPOWER GREASE
Valvoline SynPower Grease is an excellent heavy-duty and multi-purpose automotive and industrial extreme pressure grease. It consists of a lithium complex thickener in synthetic base oil and is fortified with molybdenum disulfide and other quality additives. It provides protection from high loads and may be used over a wide temperature range.
Valvoline SynPower Grease is recommended for use in disc brake wheel bearings, all-purpose chassis lubrication, suspension systems, universal joints, steering linkage, and constant velocity joint applications.
Character: Molybdenum Disulfide, Rust and Oxidation Inhibited, Extreme Pressure Fortified
Approvals/Performance Levels
NLGI GC/LB, MACK GC-G
Typical Properties
NLGI Grade
2
Thickener Type
Lithium Complex
Color and Texture
Gray-Black / Buttery
ASTM Worked Penetration @ 77° F
275
ASTM Dropping Pt, °F
500 min.
ASTM D-1743 Rust Test
Pass
Weld Pt., kg
315
Load Wear Index, kg
60 min.
Vis @ 100°C (cSt)
12.0
Viscosity Index
135
Pour Point °C
-20
Timken OK Load, lbs
60 min.
