All,
Looking for information in regards to what oil to put in. I appreciate the help in my other thread this is one is for my truck.
1. What kind of vehicle you have
2001 Dodge Dakota
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well
Grade: Manual just mentions API and that is it as far as grade
Viscosity: 10w-30 preferred for the 3.9L but says I can use 5w-30 if temperature range anticipated before next oil change is -20 to 32 degrees. I would assume if for this next change I should go 10w-30. I doubt we will see much below 0 temps until the next winter
Change Interval: 7500 on schedule A and 3000 on schedule B
Schedule B says if you meet any of the following:
Day or night temperatures are below 32 degrees
Stop and go driving
Extensive engine idling
Driving in dusty conditions
Short trips of less than 10 miles
More than 50% of your drive is at sustained high speeds during hot weather above 90 degrees
Trailer towing
Taxi, Police or delivery services
Off-road or desert operation
While my trips are short the truck is not driving much as I work from home. I might drive it once every month to a month and a half. So I wouldn't think of putting it off as far as mileage goes. 3k or 7500 is going to be way too long. But can I get away with once every 4,5, or 6 months?
3. Where you live
Minneapolis, MN
4. How you drive (easy? hard? fast? slow?)
I drive a bit harder than what I would consider normal but not all that hard.
5. What your daily drive is like (short trips? long trips? city? highway?)
Short trips most are probably under 10 minutes and most are the city. On occasion highway miles
6. Whether your car has any known problems
Slight oil leaking from what I assume are valve covers
The truck has around 100k miles on it
Appreciate the responses.
Thanks,
Scott
2001 Dodge Dakota
Stop and go driving
Trailer towing
3. Where you live
Minneapolis, MN
Thanks,
Scott
