CV boots ripped on Chevy Blazer
by dlundblad
07/24/16 07:02 PM
Built-in pour spout on Delvac jugs
by fdcg27
07/24/16 06:45 PM
Mobil 1 question
by Moondawg
07/24/16 06:36 PM
Mold & Moisture Resistant Drywall
by Warstud
07/24/16 06:36 PM
FRAM EG 3614, 5,000 miles, CUT OPEN
by car51
07/24/16 06:25 PM
FRAM XG2, 10,xxx miles CUT OPEN
by car51
07/24/16 05:33 PM
MC FL-820S, 7.6K miles, 2012 F-250
by car51
07/24/16 04:41 PM
Scion tC Radiator Fan troubleshooting
by sky
07/24/16 03:59 PM
Does Americastire sell tires from the DTD list?
by zorobabel
07/24/16 03:54 PM
My $250 Saturn climbed Mt Washington
by eljefino
07/24/16 03:07 PM
Coolant change issue
by renegade_987
07/24/16 03:05 PM
Shell X100 30/40?
by FordCapriDriver
07/24/16 02:59 PM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
99 registered (01rangerxl, 2015_PSD, 69GTX, 182RG, AandPDan, 12 invisible), 1806 Guests and 10 Spiders online.
58578 Members
66 Forums
252203 Topics
#3326652 - 03/28/14 07:14 PM 1997 Ford 7.3L 177k 4800mi Sample
Wicked94Z Offline
Loc: Washington (WA)
Ok first post here, but I'm a longtime lurker.
I've put 20k miles on this truck, unknown previous lifetime. I have done two UOAs on this truck. Both are listed, with comments from the lab. This oil is still in service, first time I've used the fumoto valve which was nice. No makeup oil added, it's about 1 qt down.
Two changes ago, I put new injectors in with new orings. Curious if that would affect the silicon levels? How much longer does everyone think I should run this oil?
Thanks!
1997 F350 CCLB-7.3L E4OD Delo XLE 10w30
#3326827 - 03/28/14 10:18 PM Re: 1997 Ford 7.3L 177k 4800mi Sample [Re: Wicked94Z]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
Hey....Welcome!
So you have 4,800 on the oil or 20K?
I would check the air filter and change as needed, is it stock?
These engines like to run a quart down, so I would keep it that way.
If you put an average of 10 to 12 k PER year on the engine, I would do a once a year oil change with all filters....i.e. fuel, oil, air, and call it good.
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#3326829 - 03/28/14 10:19 PM Re: 1997 Ford 7.3L 177k 4800mi Sample [Re: Wicked94Z]
Donald Online   content
Loc: Upstate NY
If your looking to see how long an oil can run, you need TBN. The oxidation and nitration numbers do not look correct. Those numbers are not zero with a VOA. So you found the air intake leak since silicon is down?
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3329053 - 03/31/14 11:38 AM Re: 1997 Ford 7.3L 177k 4800mi Sample [Re: Wicked94Z]
Wicked94Z Offline
Thanks for the replies. I have 4800mi on this oil, and it is still in service. The silicon numbers are UP, sorry the numbers on top are this change, the bottom are from 16k ago which was the initial analysis I did on this truck.
Sodium numbers came down, the lab was worried before about a possible coolant leak. I inspected the injector cups, and have kept a very close eye on coolant levels with no changes. I think it must have been residual from before I aquired the truck.
I have a K&N air intake on the truck that came with it. I did clean and re-oil the filter about 12k ago, but it appears that the silicon numbers don't lie. I drained about 5 sec out of the fumoto before taking my sample, so I don't believe contamination occured at the time of sampling. I'll have to measure, but maybe the popular 6637 filter will directly replace the possibly poor filtering k&n. Thoughts?
#3330518 - 04/01/14 04:09 PM Re: 1997 Ford 7.3L 177k 4800mi Sample [Re: Wicked94Z]
sdan27 Offline
Loc: Michigan
Yeah, get rid of that KN air filter. I had one in mine for awhile but didn't like it. Seemed like kind of a mickey mouse set up the way you had to apply grease all around it just to get it to seal. Do the 6637 open air element and you'll like it a lot better except then you'll have to get an aftermarket downpipe to help all the extra air flow back out of the engine.
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#3332915 - 04/04/14 12:51 AM Re: 1997 Ford 7.3L 177k 4800mi Sample [Re: Wicked94Z]
BituminousCoal Offline
Loc: New York
From a guy who loves the 7.3 engines, please, get rid of the K&N filter. These trucks are prone to dusting as it is, and even more people who run the K&N's have experienced it.
I'd recommend disassembling the intake air setup, installing a quality paper filter, clean everything, and apply something like curil-T to all seals and hose connections if you want to have good compression for years to come.
