Ustria?
by Pontual
41 minutes 53 seconds ago
Georgia bans 71 oils from 29 brands
by Tom NJ
Today at 11:27 AM
Trying to send a Blackstone sample
by 15SilvyEcotec
Today at 11:10 AM
2005 Trailblazer getting a new engine
by The_Eric
Today at 11:02 AM
AAP: 5 qt Castrol Edge, Boss filter, $30 PP $33
by DoubleWasp
Today at 10:48 AM
Make own external backup?
by doitmyself
Today at 10:33 AM
What should I use for my next oic?
by dan_erickson
Today at 10:25 AM
Motul Sport Ester 5w40 vs Gulf Competition 5w40
by Brit33
Today at 10:12 AM
M1 0W-20 EP / 15,745 mi oci / 2004 Honda Accord V6
by vinu_neuro
Today at 09:58 AM
Recommend me a small 12v battery.
by dlundblad
Today at 09:22 AM
Painful To Find M1 5W30 ESP
by Virtus_Probi
Today at 08:37 AM
Conventional oil in a 3.6 Penastar ok?
by oilchangeguy
Today at 08:27 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
91 registered (A310, Abakev, Ball9320, aquariuscsm, Andy636, Al, 11 invisible), 1912 Guests and 204 Spiders online.
56834 Members
66 Forums
244312 Topics
Page 1 of 2 1 2 >
#3326385 - 03/28/14 02:54 PM How do I clean the piston oil rings?
Cleft_Asunder Offline
Loc: Reno, NV
168k 1997 honda civic dx:
I just replaced my valve seals and I am still consuming lots of oil. Is there anything I can place through the spark plug holes so that it dissolves the carbon? I have a gallon of LC20, I wonder if I can pour some in and let it sit on the rings. Maybe it's too thick.
Edited by Cleft_Asunder (03/28/14 02:56 PM)
#3326388 - 03/28/14 02:57 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
Doog Offline
Loc: North Coast
Did you replace the PCV valve?
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
#3326439 - 03/28/14 03:44 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
FL_Rob Offline
Loc: gulf coast FL.U.S.
Seafoam,Kreen,Berrymans B-12.
#3326441 - 03/28/14 03:49 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
MolaKule Offline
Loc: Iowegia - USA
Try something with lubrication such as LCD's LC20, 4-6 ounces in each cylinder.
Let it soak overnight and then turn crankshaft by hand.
Let it soak overnight again and repeat next day.
Before firing up, inspect each hole to make sure all liquid has run past the rings. If not suck it out.
Edited by MolaKule (03/28/14 03:55 PM)
"Tyranny is defined as that which is legal for the government, but illegal for the citizenry." T. Jefferson smile
#3326501 - 03/28/14 04:47 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
andyd Offline
Loc: Marshfield , MA
Leave the plugs out for the entire operation. smile
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3326513 - 03/28/14 05:02 PM Re: How do I clean the piston oil rings? [Re: andyd]
MolaKule Offline
Loc: Iowegia - USA
Absolutely and thanks for reminding me of that crucial step. thumbsup
Edited by MolaKule (03/28/14 05:03 PM)
#3326521 - 03/28/14 05:08 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
Gokhan Offline
Loc: Los Angeles, California
Are you sure that it was done right? It's not difficult to damage or break these very delicate seals during installation. Also, if they aren't seated properly, they will pop out and then you have no seals.
I had posted this a while ago:
Wonders of valve-stem oil seal replacement
1985 Toyota Corolla LE, 4A-LC engine, ~ 263,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3329137 - 03/31/14 12:58 PM Re: How do I clean the piston oil rings? [Re: Gokhan]
Loc: Reno, NV
I'm confident I did it right, just the way you described in your DIY, but I will check again soon, just to make sure they haven't come loose. Thanks.
#3329140 - 03/31/14 12:59 PM Re: How do I clean the piston oil rings? [Re: MolaKule]
Loc: Reno, NV
I'm going to try that!
#3329180 - 03/31/14 01:35 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
Loc: Reno, NV
I'm putting in like 2 quarts every 3000 miles. No external leaks. Could a headgasket leak oil into one of the cylinders? I have no coolant leaks.
#3329203 - 03/31/14 02:01 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
jayg Offline
Loc: Anchorage, AK
How is it smoking? Usally smoking at idle = valve stem seals. Smoking under aceleration = rings.
'15 Toyota Prius C TGMO 0w20
'91 Toyota Land Cruiser VWB 5w30
'73 Datsun 240Z 4sp Vintage QS 10w40 from '73 in the sump
#3329209 - 03/31/14 02:08 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
JHZR2 Offline
Loc: New Jersey
I had no smoke, no drips, just lots of consumption on the highway... Did B-12 chemtool flush after other options didnt help. Added restore after that on a whim because lots of reports indicated it quiets lifter ticks. Both the tick and the consumption are gone!
#3329227 - 03/31/14 02:29 PM Re: How do I clean the piston oil rings? [Re: JHZR2]
demarpaint Offline
Loc: NY
Be careful speaking positively about Restore, it could get you in trouble around here. LOL
God Bless Our Troops
#3329359 - 03/31/14 04:33 PM Re: How do I clean the piston oil rings? [Re: demarpaint]
Loc: Reno, NV
Yeah but for how long are they gone? Until you stop using the engine restore? Was it the b12 flush that cured it or the engine restore?
#3329785 - 03/31/14 10:18 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
JHZR2 Offline
Loc: New Jersey
I cant say for sure. I wasnt intending to do a scientific study, just some last-ditch efforts after trying a few other things. Next step would be to live with it or to shell out money.
In all practicality, given that one item is like $3 (for a full bottle that you only use half of), and the other is maybe $10, I really dont care all that much, because application of both is so darn cheap. When I change out my oil and dont put anything in, then if/when I see changes, it may be telling...
#3329961 - 04/01/14 06:40 AM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
Cujet Online   content
Loc: Jupiter, Florida
Once again,
No common solvent dissolves hard carbon. Not Marvel Mystery Oil, not Berrymans, Not Carb Clean, not Seafoam, nothing.
Only chemicals that contain methylene chloride or other caustics will soften or dissolve hard carbon. Such as paint stripper, oven cleaner, paint gun cleaner and so on. Ever wonder why blocks and heads are cleaned with a "hot tank" caustic process? Placing them in a typical parts washer won't remove the carbon, regardless of how long you let them sit.
I have had success with higher viscosity synthetics in cars that consume too much oil.
Turbo's rule.
#3330449 - 04/01/14 03:11 PM Re: How do I clean the piston oil rings? [Re: Cujet]
Loc: Reno, NV
Originally Posted By: Cujet
Once again,
Can I put any of those through the spark plug holes before an oil change and let it soak, or can I mess something up?
#3330516 - 04/01/14 04:05 PM Re: How do I clean the piston oil rings? [Re: Cujet]
friendly_jacek Offline
Loc: southeast US
Yes, but the ring groove deposits are not 100% hard carbon, at least not initially.
There are posts about rerings jobs in Saturns or Corollas after using solvents that showed clean but worn out rings.
Cleaning is doable, but has to be done before the rings are worn out or lose their tension.
#3330643 - 04/01/14 07:07 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
Gokhan Offline
Did you hear the "click" seating sound for all of them when you pushed them down?
#3331406 - 04/02/14 01:22 PM Re: How do I clean the piston oil rings? [Re: Cleft_Asunder]
Once again,
I think what you are asking is if you can use very harsh, often caustic chemicals internally in your engine. Absolutely not! While the piston, valves and rings won't likely be affected by them, seals, gaskets, plastics, composites and rubber parts will be destroyed by them. Yes, I've used EZ-OFF engine cleaner to clean intake manifold ports and intake valves. But, only with the valve closed, done carefully-one at a time, and the metal intake manifold sitting in the driveway smile
Today, I'd never do such a thing. I prefer to use synthetic oil to prevent or reduce the risk of carbon buildup on rings and valves. My suggestion stands: Try a higher viscosity, quality synthetic oil. Possibly high mileage Mobil 1, 10W-40. It's use will help clean and keep clean engine internals.
Turbo's rule.
#3333535 - 04/04/14 06:46 PM Re: How do I clean the piston oil rings? [Re: Cujet]
Loc: Reno, NV
Once again,
Why such a high viscosity? Because it is less likely to seep through the rings? I was thinking about increasing my viscosity to 5w-40 at first, but your suggestion sounds better since I would burn less oil in the winter too. I think I will continue using valvoline high mileage synthetic blend, plus adding some LC20 in there.
Edited by Cleft_Asunder (04/04/14 06:48 PM)
#3333539 - 04/04/14 06:51 PM Re: How do I clean the piston oil rings? [Re: Gokhan]
Loc: Reno, NV
Yes I did hear it each time. The valve job is a PITA with that OEM tool we both used. I would never recommend anyone use it, and to instead find a tool that actually compresses the spring without it wanting to fly out in my face, which it did.
Page 1 of 2 1 2 >
