Originally Posted By: supercity
Just curious to know if R30 is worth all the trouble or is it just old tech now? Would it perform better than say a synthetic 5w30 or 0w40 PCMO in a non competitive but dedicated race car?
It would completely depend on your engine technology (cold start engine tolerances)and how extreme/expensive your engine is, it's still opted for in many historic race engines. When I was at the Goodwood Revival I saw a Ferrari 250GTO with a can of Morris MLR 30 next to it (the Morris MLR 30 is better thought of than the Castrol because the Morris keeps the engine cleaner). In general it's more suited to historic cars.
It's a monograde SAE 30 castor oil for 4 stroke race engines
Castor oil has some serious credentials
It stays fluid and does not carbonise at temps over 700'F.
Phenomenal film strength and low wear
It's attracted to metal and builds platelets just like ester synthetics do.
Mainly, it can do something no synthetic or mineral does, it's attracted to heat so it's drawn to all the hot points/high stressed points in the engine.
but, it leaves deposits....
It's/it was mainly used for racing (now historic cars) where frequent strip downs were common, the engines are warmed really gently with no load for a long time until the oil heats up and thins out before they set off. It far outperformed any lubricant of the time and still out performs synthetics to this day in some aspects.
It's not exactly old tech but the monograde SAE 30 is only really useable in old tech engines with a specific warm up procedure
