Originally Posted By: camelCase
I still don't think this addresses the whole ATF vs MTF question.
From the sounds of it, this article seems to be implying that possibly a more heavy EP or AW dosing in MTF vs. ATF. However, sycros do need some "wear" so they can grip. So how much is too much?
I personally have ran an EP gear fluid (differential case fluid), ATF, and OEM MTF in my Mazdaspeed3 manual transmission. I've noticed the ATF I use works well. The EP gear fluid did work great, and UOA showed no increases in wear metals. However, I still still a bit concerned about the brass, so I went back to an ATF. Been using it for about 25,000miles now and I think it works great.
I'd like to see some more input on this conversation.
Quote:
GL-4 is a level of protection rating for gears and is generally applied to manual transmissions and to manual transaxles that do not have hypoid designs.
The older formulations in GL-4 MT lubes had about 1200 to 1500 ppm of phosphorous and zinc or ZDDP as the primary Anti-Wear additive. Some simply contained a lower level of phosphorous-sulfur EP additives like those used in differential (GL-5) lubes.
GL-4 MT lubes don't need a strong EP additive level like the phosphorous-sulfur EP levels in a differential lubricant because of the type of gearing and gear-tooth loading.
If you care to read the White Papers you will see that gear lubes, whether GL-4 or GL-5, have more than just Anti-Wear (AW) or Extreme-Pressure (EP) additives.
ALL Gear lubes contain anti-rust, anti-foam, and Metal Deactivator chemistries.
Metal Deactivator chemistries are chemical compounds that keep an additive component or contaminant from reacting with metals in the gear box.
The important thing to keep in mind about the Specific Application GL-4 MT lubes is that they contain the proper friction modifier chemistries to assist with better shifting and synchro engagement.
Personally, I relegate GL-5 rated lubes to hypoid differentials only.
Quote:
Here is what application-specific (Dedicated) MTLs consist of:
1. Base oils of various types and viscosities to make a specific viscosity and have anti-shear properties
2. GL-4 Performance Improvement (PI additive package) chemistry which consists of the following
a) GL-4 anti-wear (AW) additives
b) anti-rust additive
c) copper and aluminum metal deactivator/buffering agent
d) anti-foamant
e) special friction modifier (FM)
f) dye
Application Specific = Dedicated.
