At least, I didn't find any "E"s on it anywhere...
This is used mostly on old Buick engines from like '68 to '87, I'm thinking that not much has changed in their design in decades other that maybe materials.
I had this on my shelf and won't be using them - and I just got this oil filter cutter, so...
AC Delco PF24
Can removed. Big metal end caps, steel spring, lots of pleats that are fairly evenly spaced.
Rubber ADBV that is a really close fit on both the filter base and the metal end cap
The whole filter laid out:
Comparing this to the MotorCraft FL9 I also cut open, it has slightly fewer pleats, but they are much more securely glued into the metal end caps. The ADBVs in both filters are nearly identical in appearance.
AC Delco PF24
