Bosch filters sold in the U.S. and Mobil 1 filters were made when last I looked in the same factory, Champion Labs, in Illinois.quote:
Originally posted by Big John:
I just changed out a M1 filter as I was getting a little start up rattle.I now have a Bosch on my engine and all is well,maybe it filtered too well and caused a little starvation????
Sometimes you can't run a larger filter. On many cars one isn't easily available or doesn't fit. Plus, just like the current M1 filter it will probably have other benefits over a $2 filter.quote:
Originally posted by Dominic:
Why do that when I can just run a slightly larger oil filter for $2?I dont have any problems with oil filters stopping up.
Not likely, the filter element would have to be pluggged and the bypass would have to have failed.quote:
Can the ADBV fail and you get a dry start?quote:
