Originally Posted By: exranger06
A cordless impact with a strong battery should be all you need to remove the pinion nut. Might as well have the shop pop a new pinion seal in it while it's apart. But don't be surprised if the pinion bearings start howling 15k miles later. Been there, done that.
No power tools of any sort allowed in junkyards. Pinion bearing already howls in rear axle on decel. Just has to hold out for another year until I can have it regeared.
Originally Posted By: 440Magnum
Ah, if you're contracting it out, then its a different matter... except for the fact that the same rust monster may make it completely impossible to pull a yoke off in the junkyard, too. Not having a shop is the BEST argument for swapping the whole axle, though. It requires a shop to change a yoke.
Let me poke my old set of XJ links here and see if I can find a new one some other places...
How about Quadratec:
http://www.quadratec.com/products/52425_10.htm
Same part at 4Wheel Parts:
http://www.4wheelparts.com/Drivetrain-Di..._pn=CRO52068839
Looks like Crown is about the only brand going, just have to find a vendor that can deliver fasteest
If I can't pull by end of week, I'm going to order new and wait a few weeks.
Originally Posted By: old1
If your mechanic won't charge much to change them if you supply one, then all you gotta do is get the old one off. But then you knew that. To get it off you need something to hold it from turning. A LARGE pipe wrench works if it has the body or something to jam it from turning. Then a socket to fit the nut, and a breaker bar with probably a pipe to extend the handle. Then PUSH OR PULL as the case will be till it comes loose, remove the nut, and use a hammer to tap the yolk off the pinion shaft. Always worked for me anyway.
He was just going to give me a yoke but didn't have any hanging out in the shop. All were for Dana 35 apparently.
I have a 3/4'' breaker bar with 36'' pipe.
