Walmart ST Full Synthetic 5W30 & 10W30 5QT $12.00
by Jonny5alive
7 minutes 43 seconds ago
Keep America's Nuclear Power Stations Running
by Shannow
Today at 12:14 AM
Lubegard Biotech,my thoughts
by Marco620
Today at 12:03 AM
Frivolous lawsuit loser pays court cost !
by HTSS_TR
Yesterday at 11:49 PM
cold seizure on a small air cooled engine?
by motor_oil_madman
Yesterday at 11:20 PM
Walmart.com PUPP 5W-20 $22.47
by mike718
Pick my oil '75 Plymouth Gran Fury 400 big block
by gallydif
Yesterday at 08:40 PM
Spark plug resistance R5 vs R6
by Ndx
Yesterday at 08:39 PM
Firestone TF2876 C&P
by holdorf333
Yesterday at 08:38 PM
Castrol High mileage or Valvoline Maxlife
by NH73
Yesterday at 08:30 PM
Got to experience cornering ABS today
by LoneRanger
Yesterday at 08:10 PM
Engine Heat Soak - What causes sluggishness
by ryan2022
Yesterday at 08:03 PM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
28 registered (BigRalphie, alcyon, 2009Edge, bvance554, barkingspider, bdcardinal, 2 invisible), 981 Guests and 11 Spiders online.
58332 Members
66 Forums
251067 Topics
#3321785 - 03/24/14 09:35 AM Oil for Engine Driven Welder
IntIron Offline
Loc: CO
Hello,
We run Kohler Commander engines, air cooled. The recommended interval is 100 hours for oil and 150 for Oil Filter.
We have been running Mobil 1, Full Synthetic 10W-30 and just putting the interval at 150 for each.
Do you think this is ok?
Thank you.
#3321797 - 03/24/14 09:47 AM Re: Oil for Engine Driven Welder [Re: IntIron]
Oil Changer Offline
Loc: Michigan
I had a Miller Bobcat and we used Rotella SAE30 in SoCal. M1 is fine but I would use the HM version. The HM is A3/B3 and much heavier with an HTHS of 3.5 as opposed to the 3.0 of what you are currently using. The HM also has more Z and Ph. As a total package, go with the HM if M1 is cheap and easy to get.
Having said all of that, T5/T6, SAE30/40 HDEO will work just fine.
#3321846 - 03/24/14 10:36 AM Re: Oil for Engine Driven Welder [Re: IntIron]
440Magnum Offline
Loc: Texas
I tend to run Rotella T6 (5w40 synthetic) in all my OPE. No complaints, the last one I had to open up (non oil-related problem) was absolutely spotless inside. Bore and bearings all looked great. Most OPE now seems to call for an Xw30, but I've never had a problem going to T6 even though its an Xw40- cold starts (relatively speaking- we don't have much below 20F nights here, and only a few times a year) are not an issue thus far. And it makes me feel a little more secure on the 100+ F summer days.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3322036 - 03/24/14 01:07 PM Re: Oil for Engine Driven Welder [Re: IntIron]
Doog Offline
Loc: North Coast
Rotella T5 10w30 will do just fine.
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
#3322628 - 03/24/14 11:19 PM Re: Oil for Engine Driven Welder [Re: IntIron]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
Intiron - Welcome to BITOG
What you have been doing is just fine - keep doing it with confidence
Regards
Doug
#3344686 - 04/16/14 03:20 PM Re: Oil for Engine Driven Welder [Re: IntIron]
tig1 Offline
Loc: Illinois
For gas powered welders like yours M1 10-30 is a good choice. I use this oil in all my OPE including my 5KW gen.
2007 Ford Fusion 183,000 miles
M1 0-20 AFE
2007 Ford Focus 155,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#3352006 - 04/24/14 02:04 PM Re: Oil for Engine Driven Welder [Re: IntIron]
camelCase Offline
Loc: Southeastern, USA
I'd run Rotella T6. The 5W40 will give you the cold start pumpability but will have a thicker oil film on the higher end. Portable engines typically don't have the tightest tolerances and wear pretty weirdly sometimes. The 40wt is just 1 step higher, but can greatly increase the oil wedge's load holding capacity.
Plus - it's hard to beat the bang for buck value fo Rotella T6.
#3377327 - 05/21/14 12:07 PM Re: Oil for Engine Driven Welder [Re: IntIron]
bulwnkl Offline
Loc: Arizona
We ran Kendall Super-D III in our Lincoln Ranger 9s for a very long time. When I was operating in Yuma and Kendall was not reasonably available, I put in an alternative, high-quality 15W40 all-fleet oil. Those Ranger 9s never smoked or had any troubles at all, despite having tough lives on the farms.
"A government big enough to give you everything you want is a government big enough to take from you everything you have." --Gerald Ford
#3880788 - 10/10/15 12:23 AM Re: Oil for Engine Driven Welder [Re: IntIron]
JR Offline
Loc: Michigan born but my heart bel...
Two onan powered units. They get 15w-40, 20w-50, and 10w-40 is usede usually.
The older one uses a little oil from one cylinder. It holds 4+QTS.
The newer on gets hdeo and a fl-1a.
Both have a million hours. Former commercial now are rental units.
If your using m1, I would stay with it. I would opt for the hm formula. Higher a/w and etc. Also a 5w-xx would be better for cold weather, frequent starts, and ect.
The 24hp Kohler 7000series on cud zero turn has 35hrs. Kohler 10w-30 to be dumped for m1 truck and SUV 5w-30 and call it broke in. It will see syn oil only.
Harvey
