Ground effect
by mjoekingz28
02/13/16 04:36 AM
20w50 thick? i present to you Penrite's 50w70!
by FordCapriDriver
02/13/16 03:46 AM
08 caravan / oil seeping from spark plug
by Mark72
02/12/16 11:25 PM
Holley Accelerator pump probem
by nwjones18
02/12/16 10:56 PM
Sealant for threaded air hose fittings.
by BigD1
02/12/16 10:37 PM
on line data search programs - which is best?
by bmwjohn
02/12/16 10:11 PM
What size air compressor is needed
by ram_man
02/12/16 09:45 PM
DHS wants to force car owners to use OEM parts
by faltic
02/12/16 08:54 PM
Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
02/12/16 08:20 PM
Best Oil Analysis?
by countryboy9799
02/12/16 07:28 PM
Left my lights on and battery died.
by joegreen
02/12/16 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
02/12/16 07:18 PM
wdleighton1, RTS, jhmed80, engus, Rob_Pol
56902 Registered Users
19 registered (dmdx86, Char Baby, Ifixyawata, dec219644, bbhero, Andy636, 2 invisible), 465 Guests and 89 Spiders online.
56902 Members
66 Forums
244628 Topics
Page 5 of 8 < 1 2 3 4 5 6 7 8 >
#3320991 - 03/23/14 03:13 PM Re: Advantages of straight weight oil [Re: Now]
A_Harman Offline
Loc: Michigan
If we keep adding to this thread, we'll all go old school and run straight 30 in the summer, then switch to straight 10W in the winter. When was the last time anybody saw a straight W-grade on the shelf?
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3320993 - 03/23/14 03:16 PM Re: Advantages of straight weight oil [Re: Now]
Red91 Offline
Loc: Alabama, United States
My local NAPA has 30HD PYB, GTX, Delo, and Napa. Of course it is independent and is sort of auto/farm oriented.
'15 Chevrolet Cruze LS
1.8 4 Cyl, 6 Speed Auto
QSUD 5W-30, STP Extended Life S10246XL Filter
#3321056 - 03/23/14 04:25 PM Re: Advantages of straight weight oil [Re: Red91]
beanoil Offline
Loc: Midwest, Illinois
Originally Posted By: Red91
So the straight 30 did alright in your 5.4?
IMO, yes. No difference in starting or running. But I did not do a UOA, and my tow vehicles are just that, they tow. When they aren't hooked to the travel trailer, they sit. I drive about 3000 miles a year, from March to October, then it sets all winter. So I cannot tell you if the 30 weight would have worked at or below freezing. But 40 and above, no change in the truck's behavior.
beanoil: Tough under heat, real dirty afterwards.
#3321073 - 03/23/14 04:43 PM Re: Advantages of straight weight oil [Re: beanoil]
Clevy Offline
Loc: Saskatoon canada
That sounds like ideal conditions for using a straight grade.
And thanks for the links Shannow. You are certainly an asset to this forum and us less informed members.
2006 Charger RT
Miles x 2 per oil filter
#3321085 - 03/23/14 04:51 PM Re: Advantages of straight weight oil [Re: A_Harman]
Garak Offline
Loc: Regina, Saskatchewan, Canada
I don't even see any on my Imperial Oil sell sheets. Heck, they don't even sell a Mobil conventional 10w-40 or 20w-50 up here any longer, and all their monogrades are SAE 30 and SAE 40 HDEOs and two cycle diesel oils.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3321164 - 03/23/14 06:05 PM Re: Advantages of straight weight oil [Re: Now]
Red91 Offline
Would anyone here actually try a fill of monograde in an application where it's tolerated? Just for kicks.
#3321168 - 03/23/14 06:11 PM Re: Advantages of straight weight oil [Re: Red91]
Clevy Offline
I'm considering trying a 30 grade in my charger,just for xxxx and giggles.
2006 Charger RT
#3321189 - 03/23/14 06:29 PM Re: Advantages of straight weight oil [Re: Clevy]
Red91 Offline
What engine do you have in the charger?
#3321348 - 03/23/14 08:50 PM Re: Advantages of straight weight oil [Re: Red91]
KCJeep Offline
Loc: Mahzurrah!
I imagine my tractor engine Jeep would thrive on it. Seriously considering it for fun but I have some timing problems. I'd only consider it during summer and for any kind of telling results it would be better for it to be a second run UOA to get a real look at how it did. If I was due for an OCI now it would work, but I'm not. frown
Another reason why I don't usually run synthetics, you just have to wait to darn long to try something new!
2004 Jeep Grand 4.0 @ 130k Pennzoil HM 5w30 w/ 1 qt 10w40
Fram TG8A
KIA Sedona 55k, Chevy Lumina 182k, Chrysler Sebring 183k, Chrysler Concorde 111k
#3321363 - 03/23/14 08:56 PM Re: Advantages of straight weight oil [Re: Red91]
gfh77665 Offline
Loc: Southeast Texas
I have posted the following twice:
I have:
1) Mixed 30 with 10-30 in varying amounts
2) Ran straight 30
3) Even ran straight 40 (Im in TX summer and oil was almost free)
Even the 40 did fine in my 97 Chevy pickup.
People are STRESSING over nothing, viscosity wise.
#3321364 - 03/23/14 08:57 PM Re: Advantages of straight weight oil [Re: Clevy]
turtlevette Online   shocked
Loc: Massachusetts
I'm going to put 0W-16 when it comes out, in my corvette for the same reason.
#3321600 - 03/24/14 01:42 AM Re: Advantages of straight weight oil [Re: Red91]
Clevy Offline
5.7 litre hemi. With mds. I've already experimented with 40 grade oils in it and they slow down mds engagement by .025 of a second or so,so those folks who believe that you gotta run a 20 grade or the mds won't work take note that it's not true.
Surprisingly enough if you get on the throttle before the oil reaches 140f the ecu throws an oil too thick code.
I've got 5w-20 ultra in it right now. 8000 miles on the oil and I guess due to oxidative thickening it set a cel a few days ago when I got heavy into the pedal.
2006 Charger RT
#3321622 - 03/24/14 04:51 AM Re: Advantages of straight weight oil [Re: A_Harman]
Shannow Online   content
Loc: Oz
I've seen a 20W...somewhere in the not too distant past, now I'm wracking my brain for where exactly I saw it...it stood out
#3322745 - 03/25/14 07:34 AM Re: Advantages of straight weight oil [Re: Clevy]
Red91 Offline
So you think it would be alright in the summer on a monograde? I'm seriously very curious.
#3322904 - 03/25/14 10:16 AM Re: Advantages of straight weight oil [Re: Red91]
KCJeep Offline
Loc: Mahzurrah!
I do because I've done it before many years ago but I was very oil ignorant then and ran it into winter. Starts were pretty rough ha ha. I've been looking around and PYB HD30 is fairly available. So is Rotella. I also looked at the Castrol site and they say in regard to their HD 30 "for ambient temps over 40 degrees". So they seem to think HD30 is fine as long as it's 40 or above.
I am still 3-4k away from my next OCI, it will be summer then, I am torn between another fill of 10w40 PYB or a run of HD30 PYB. But I would rather have a prior run of PYB before I run the HD30 as a UOA would be more reflective of actual performance. But then I'd be getting into fall with HD30 which I don't really want to do. But a single run would not be worthless either.
Like you I am very intrigued by the higher HTHS and the stellar shear resistance.
Fram TG8A
