lubriplate 1200-2
by buffalobob
07/30/16 02:49 AM
How do you politely say no to people?
by motor_oil_madman
07/30/16 12:39 AM
To change or not?
by ram_man
07/29/16 11:55 PM
Nozzle Flow Versus Pressure/Viscosity
by Shannow
07/29/16 11:20 PM
Camaro "How its Made" TV show Observations
by SumpChump
07/29/16 11:08 PM
Wondering if sitting with few quick starts degrad
by corndogzombie
07/29/16 10:51 PM
whole hog cook w/ pics
by 04SE
07/29/16 10:12 PM
redo a/c in 1994 dakota 2wd
by bmwjohn
07/29/16 09:37 PM
How to post UOA's on here?
by motor_oil_madman
07/29/16 09:34 PM
Remanns Brand Remanufactured engines
by TiredTrucker
07/29/16 09:11 PM
Best long lasting door hinges lurbicate ?
by MetalSlug
07/29/16 08:59 PM
How do you clean trunk area (not inside the trunk)
by MetalSlug
07/29/16 08:57 PM
jractk, LatitudeDancer, AKN, NickGB, Marcusd1979
58645 Registered Users
21 registered (Duke, bamorris2, Boczech, FordCapriDriver, 3 invisible), 841 Guests and 10 Spiders online.
58645 Members
66 Forums
252429 Topics
#2811575 - 11/23/12 01:52 PM Isuzu NRP Diesel oil recommenation
kenpoed Offline
Loc: Pennsylvania
Stupid question, I cant seem to find any info in the owners manual whether the oil should be synthetic or conventional. All it states for the 2013 Isuzu NRP is that it should contain "CJ-4" and support "DPF"
Where can I find a site that will tell me the type of oil and filter for this truck unit? Thanks
#2811582 - 11/23/12 02:07 PM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
dparm Offline
Loc: Chicago, IL
Amsoil website should be able to help. You can pick your manufacturer and engine type to get the recommendation.
2011 BMW M3 sedan ZCP
#2811744 - 11/23/12 06:06 PM Re: Isuzu NRP Diesel oil recommenation [Re: dparm]
kenpoed Offline
Loc: Pennsylvania
I appreciate the link, unfortunately it does not give any help on the Isuzu model.
#2812204 - 11/24/12 07:04 AM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
m37charlie Offline
Loc: Alaska
Virtually any heavy duty diesel oil sold in auto parts stores, Walmarts, etc will have an API rating in the back or front label of the container, which these days will be "CJ4", at least in the US. This by definition "supports DPF".
You don't need expensive Amsoil products for this engine especially if you plan to follow the mfgs recommendation on oil changes. Save the $$ and perhaps use synthetic for the differential.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#2812615 - 11/24/12 03:11 PM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
The book does not even mention a viscosity? That's lousy support. I can ask Amsoil if you like.
Just as a point of reference the Amsoil OE Diesel line is about $5/qt.
#3320730 - 03/23/14 10:30 AM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
Red91 Offline
Loc: Alabama, United States
I believe any 15W-40 or 10W-30 HDEO will work. The newest spec is DPF safe.
'15 Chevy Cruze LS
1.8 4 Cyl, 6 Speed Auto
QSUD 5/30, STP XL Filter
'92 Buick Roadmaster Wagon
5.7 V8, Auto
QS 20/50, LMMoS2, Napa Gold Filter
#3320857 - 03/23/14 01:15 PM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
simplistic Offline
Loc: Tennessee
I have owned 3 of these npr with diesel engines. Any of the 3 big players (rotella, delo, and delvac) will b fine. I ran which ever one was cheaper.
As far as viscoity it the manuel don't show it (though its n there some where) look on the driver's sun viser. It's on the back side and it shows anything from 5w30 to 40wt and the temps that each is acceptiable. though 15w40 has almost as big of temp alowence as 10w30. You can run either with out problem.
These engines are basiclly 1/2 of a durmax engine. I ran mine hard and only did routine mantiance nothing more.
03ccsb,2500hd 200k+ Durmax/Allison,PURE POWER FILTERS,Bilstin Shocks,Aux Springs,Swiss Cheese Air box Fram Tough Guard,BF Goodwrench K/O
#3475741 - 09/06/14 01:35 PM Re: Isuzu NRP Diesel oil recommenation [Re: kenpoed]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
I try to stay away from the synthetic with those trucks, because of the signature oil leak that develops at the back of the cylinder heads of pretty much all of them. The synthetic just makes it worse.
Rotella T5 10/30 or the NAPA Heavy Duty "Premium" 15/40 is what I've always used, and the trucks I service are at or above 250k miles. The engines themselves are solid. The EGR valves are another story. laugh
2007 Lincoln Navigator M1 0w-40/FU
1968 Charger R/T / Supercharged 440 VR1/DBL7349
2007 Ram 3500 4x4 / Cummins 6.7 /DBL7349
2015 Porsche 911 C4S PDK
