Cheap brake fluid tester working properly?
by LucasDK
05/28/16 04:00 AM
Help finding specific oil.
by Mickxalix
05/28/16 02:28 AM
Found at Walmart: STP Multipurpose Motor Treatment $1.50
by MrQuackers
05/28/16 01:36 AM
Mobil 1 5w50 now FS too
by BobFout
05/27/16 11:55 PM
Front brakes for 1991 GMC Sierra 2500
by sr17
05/27/16 11:35 PM
7200 Miles
by Yup
05/27/16 11:08 PM
Result; 5 additives tested in a lab
by DrAdmin
05/27/16 09:25 PM
What are advantages of rotation ?
by HTSS_TR
05/27/16 09:22 PM
Arthritic joints
by Eddie
05/27/16 08:55 PM
Trouble Installing Filter
by Astro_Guy
05/27/16 08:09 PM
Kia P0138 Code From Old Amsoil Stabilizer ??
by Quadrasteer
05/27/16 07:43 PM
Micro Guard Filter
by Jason1221
05/27/16 07:38 PM
troutwest66, AIRJAC3, bpete65, LEVY, Timmytimmy
58000 Registered Users
25 registered (dlundblad, Char Baby, Bandito440, crazyoildude, bdcardinal, 2 invisible), 486 Guests and 334 Spiders online.
58000 Members
66 Forums
249510 Topics
#3320651 - 03/23/14 08:48 AM 1954 Flatheads and gas in oil.
Plumber Offline
Loc: USA
Both my 54 Plymouths have the 230ci flathead. One car is manual, the other Powerflite 2 speed automatic. Both carbs are different.
I always get gas that is leftover in the manifolds when shut off leeching into the valves then into the oil pan.
it is such a common thing the factory manual mentions it, and explains that the oil cap expels some of the gas in vapor form....But, you may want to change the oil more frequently.
Which oil would be better at handling oil/gas mixing?
#3320656 - 03/23/14 08:51 AM Re: 1954 Flatheads and gas in oil. [Re: Plumber]
Red91 Offline
Loc: Alabama, United States
I would say a 30HD would be adequate. Probably any multigrade HDEO would do as well.
'15 Chevy Cruze LS
1.8 4 Cyl, 6 Speed Auto
QSUD 5/30, STP XL Filter
'92 Buick Roadmaster Wagon
5.7 V8, Auto
QS 20/50, LMMoS2, Napa Gold Filter
#3320659 - 03/23/14 08:59 AM Re: 1954 Flatheads and gas in oil. [Re: Plumber]
spasm3 Offline
Loc: out there
Amsoil makes a 5w 30 hdeo.
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#3320666 - 03/23/14 09:09 AM Re: 1954 Flatheads and gas in oil. [Re: Plumber]
eljefino Offline
Loc: ME
In the 80s cars had some sort of solenoid in the carb that either closed it beyond idle or shut off fuel, to keep the engine from sucking fuel down after spark was shut off. Not sure if it's part of the ISC or what.
Seems it wouldn't work well in the fuel line though, as the carb bowl would have enough to supply fuel to the oil during spin-down.
Do you want to stay 100% stock? A PCV system would be easy to rig up. Do you have a road draft tube?
#3320675 - 03/23/14 09:21 AM Re: 1954 Flatheads and gas in oil. [Re: Plumber]
Astro14 Offline
Loc: Virginia Beach
I'm guessing it's just vented to the atmosphere. I also suspect that the engine called for a -40 in summer...it was built in the days of single viscosity oil...
My personal recommendation for this would be a 15W40 HDEO. Something that you buy on sale for about $12/gallon and change often. Good zinc levels, covers all seasons in which you'll run this engine and it has good viscosity for fuel dilution. Cheap enough to change when the dipstick starts smelling like gasoline...
Edited by Astro14 (03/23/14 09:22 AM)
32 Packard 15W40
90 4Runner 10W40 Edge
92 300E 0W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
#3320713 - 03/23/14 10:10 AM Re: 1954 Flatheads and gas in oil. [Re: Plumber]
toneydoc Offline
Loc: War Eagle
No oil itself will really HANDLE this for a long time which is why they suggest changing it frequently. Gasoline readily breaks down oil. I use gas to remove oil from surfaces from time to time and it breaks down the oil easily. Use a decent quality oil and change the oil frequently. Especially if you crank and drive them often.
1994 Jeep 146k Castrol 0w40
2014 Camry 14k TGMO 0w20
2010 Sebring 39k Valvoline 5w30
2014 HD Ultra 16k Valv20w50
2012 Toyota Rav4 22k Mobil 1 0w30AFE
#3320842 - 03/23/14 12:59 PM Re: 1954 Flatheads and gas in oil. [Re: toneydoc]
Plumber Offline
Loc: USA
The vapors are vented. There is a draft tube. I figure any gas leftover in the manifold is the culprit. The engine mounts at a slant, so any remaining gas will drain back.
#3320935 - 03/23/14 02:22 PM Re: 1954 Flatheads and gas in oil. [Re: Plumber]
flanso Offline
Loc: Manhattan
The solenoids that became common in the 1970s were used to decrease the throttle opening, when the car was shut off, to prevent run on. They did not shut off the fuel supply to the carb. Carburetors from that era used steel inlet needles against brass seats and that design is prone to leak. If you can find modern carb kits for those carbs, the kits will likely have viton, or other synthetic, needle tips that will dramatically reduce fuel leakage into the carb throat after shut down. You can observe the leaking by getting the car up to operating temperature, then shutting it off, remove the air cleaner and then observe the nozzle in the center of the venturi with a flashlight. You'll probably see a very slow, small drip, drip...
#3322335 - 03/24/14 06:49 PM Re: 1954 Flatheads and gas in oil. [Re: Plumber]
artificialist Offline
Loc: Florida
In the "European car oil section" I read about Renewable Lubricants Biosyn, and there were reports of it handling fuel dilution better than the other oils in use.
That in mind, it seems that numerous cars with carb engines ran for ages with conventional oil changed every 3000 miles, so long as the engine was a good design.
2010 Lancer Ralliart Sportback
