Difference between silicone caulking ?
by Merkava_4
Today at 06:15 PM
The Top Dexos2 Oil Available in the USA is What?
by Best F100
Today at 05:24 PM
Virgin Puro L14006 [Cut open]
by Run
Today at 05:13 PM
The 17 year cicada is here. (locust) PIC HEAVY.
by Rand
Today at 04:23 PM
How long is sealed coolant good for?
by addyguy
Today at 04:08 PM
4T65E 2006 Buick Lucerne Normal decel gear banging
by deanm11
Today at 03:41 PM
California drought and 3" fish delta smelt
by HTSS_TR
Today at 03:18 PM
High SAPS & DPF Re-Gen
by userfriendly
Today at 02:50 PM
Decent little string trimmer
by Papa Bear
Today at 02:24 PM
Pirelli
by borgward
Today at 02:10 PM
'88 Cadillac smog (Emission test) fails
by momo
Today at 01:59 PM
Towing what to look for?
by Camprunner
Today at 01:48 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
97 registered (04SE, bdcardinal, B320i, Bandito440, ag_ghost, Berny, 12 invisible), 1482 Guests and 326 Spiders online.
58013 Members
66 Forums
249572 Topics
Page 2 of 2 < 1 2
#3320523 - 03/23/14 05:28 AM Re: Additive to reduce oil conumption i n1998 Corolla [Re: BrettG]
demarpaint Offline
Loc: NY
I'd try a piston soak as already mentioned, and if you want to try an additive to clean things up give MMO or Kreen a shot.
With regards to a piston soak, I recently worked with Amsoil power foam again and I have to say it does one heck of a job cleaning up carbon. Next piston soak I do on an OPE I'm going to use that. I'd use it in a car w/oo hesitation but I don't need a piston soak.
God Bless Our Troops
#3320589 - 03/23/14 07:40 AM Re: Additive to reduce oil conumption i n1998 Corolla [Re: demarpaint]
Trav Offline
Loc: MA, Mittelfranken.de
The original GM Top Engine cleaner is one of the best in the business for piston soak, that would be my first choice.
Chrysler has a good one, so good in fact i see the local Subaru dealer buying it. (true)
Kreen and MMO may work okay but it will probably take a little longer.
A 15 min idle flush with Berrymans Chemtool will clean the rings quickly as will kreen over a short OCI, it may not all the junk and carbon but it should get a significant amount.
ARX will take longer than the car and maybe the driver will survive if at all, it will clean your wallet pretty good however.
This is just my personal experience using all these product at one time or another over the last 40 years as a working mechanic.
#3320680 - 03/23/14 09:25 AM Re: Additive to reduce oil conumption i n1998 Corolla [Re: BrettG]
friendly_jacek Offline
Loc: southeast US
Originally Posted By: BrettG
I used about quarts every 1500 miles (roughly).
Actually, it's not bad at all for 1998 1ZZ-FE. How many miles? City or hwy? What oils did you use and what OCIs?
#3320902 - 03/23/14 02:02 PM Re: Additive to reduce oil conumption i n1998 Corolla [Re: demarpaint]
rockydee Offline
Loc: VA
Sounds like a plan to me.
#3321169 - 03/23/14 06:11 PM Re: Additive to reduce oil conumption i n1998 Corolla [Re: BrettG]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
GC = German Castrol 0W-30. This one oil is different than others. On the front of the bottle it will say "European Formula". On the back somewhere near the bar code it will say "made in germany".
Italian tune up = taking it out and running it hard with high RPM's to blow out any gunk in the engine.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#3321382 - 03/23/14 09:09 PM Re: Additive to reduce oil conumption i n1998 Corolla [Re: JimPghPA]
BrettG Offline
Loc: WV
There was supposed to be a 2 in front of the quarts. If I put a lot of highway miles when driving to and from my girlfriends house (110 miles or so round trip), its closer to 2 quarts. When its just back and forth to work I dont use as much,
Ok thanks for the clarification for the newbie smile
#3321423 - 03/23/14 09:41 PM Re: Additive to reduce oil conumption i n1998 Corolla [Re: BrettG]
Loc: southeast US
I see. 1qt in 750 miles. The higher consumption you have, the less chance to reverse it by cleaning the rings, IMHO. The oil rings could be all worn out by now. I noticed when oil consumption started in mine (abruptly), there was way more debris on magnetic drain plug than normally.
#3321493 - 03/23/14 10:40 PM Re: Additive to reduce oil conumption i n1998 Corolla [Re: BrettG]
panthermike Offline
Loc: Phoenix, AZ
1 quart every 750 miles is about where our old '00 Corolla was at when we traded it in. The suggestion of a Kreen piston soak is a good one. I can tell you from experience that nothing I put in the crankcase solved or reduced this problem. Unfortunately I didn't know much about piston soaks when we had the '00, plus it was starting to run rough and pinged constantly so it would have been too late anyways. Had 167K when traded in.
I would run some Kreen in the oil for 1K miles, do a piston soak and then change your oil afterwards.
'16 Ram Sport 1500;FF 1K
'15 Lincoln MKC; PP 5w30 21K
'77 F250 "Ol Yeller"; Kendall/Mos2
'98 ES300; ML/Biotech 201K
#3321544 - 03/23/14 11:47 PM Re: Additive to reduce oil conumption i n1998 Corolla [Re: BrettG]
BrettG Offline
Loc: WV
I'm definitely going to try some kind of piston soak. I have nothing to lose. What's so puzzling is this car runs so well. I get great gas mileage, there no valve noise or pinging. Doesn't smoke. I have plenty of power and no check engine light pertaining to a bad cylinder or anything like that. If I could rebuild this motor, id keep the car until it fell apart. It had 156k on it and still runs so well.
#3321548 - 03/23/14 11:49 PM Re: Additive to reduce oil conumption i n1998 Corolla [Re: BrettG]
JHZR2 Offline
Loc: New Jersey
Sounds like my 318i.
#3321553 - 03/23/14 11:58 PM Re: Additive to reduce oil conumption i n1998 Corolla [Re: sprintman]
Clevy Offline
Loc: Saskatoon canada
Originally Posted By: sprintman
2 bottles Auto-Rx Plus in a non ester oil (new filter) and run it 6-8,000 miles. If the engine runs cold fix that first.
Great idea if he wants to spend more to achieve less then a piston soak.
Seafoam costs what in America,5 bucks,and results are immediate.
Or he can wait til the tenth day of never for arx to work,at a significantly higher cost.
Sounds like a great idea.
Op. Trav is an expert. Follow his directions. And you'll get results.
2006 Charger RT
Miles x 2 per oil filter
#3321686 - 03/24/14 07:39 AM Re: Additive to reduce oil conumption i n1998 Corolla [Re: BrettG]
JHZR2 Offline
Loc: New Jersey
^if there are small ports that are clogged, I can't see how arx would help regardless. Different issue needs different approach.
#3391874 - 06/07/14 11:58 PM Re: Additive to reduce oil conumption i n1998 Corolla [Re: BrettG]
KeMBro2012 Offline
Loc: California
2 schools of thought, here, and I've tried both on a 99 and 2000 with the same issue. Here's what I can offer: The issue with 1ZZ's of this era is that the oil return holes in the pistons aren't sufficient and eventually clog up; in most cases, it has nothing to do with the rings until (and unless) it's been let go for too long.
Knowing this crucial piece of information, you can deduce that the most important first step is to restore oil flow. Since we're talking about (hopefully only partially) clogged passageways (the oil return holes), that means thinner, not thicker, oil. I had luck with Pennzoil Platinum 0w20 in the 99 (completely stopped consumption in 2 OCIs, no consumption when I sold it a year later) and Pennzoil Ultra 5w20 in the 2000 (they don't make a 0w20 Ultra or I'd have used it).
In the 2000, I greatly reduced the consumption, but didn't stop it. In this case, I was able to clear out the oil return holes but I either have stuck or cracked rings (this hypothesis is backed by compression numbers; and I'm leaning toward stuck since the numbers weren't that bad). I'm currently running Rotella T6 (which is a 5w40 HDEO) to try and clean that up; I'm also performing another experiment using canola oil, so any further results I could report on that front won't be valid in your case (e.g. ignore most of this paragraph, it's really just informational and not at all suggesting you follow this path).
Basically, assuming your oil return holes aren't completely clogged, the most likely case is you need to run something thinner for a while (1-2 OCI) to begin clearing out the clogged oil return holes before any additive, cleaner, or heavy duty oil will even be able to touch the issue. If that slows, but doesn't completely stop the consumption, then you should use a cleaning additive to attempt to free possibly-stuck rings.
And, of course, once you've managed to stop the consumption, consider switching back to the recommended 5w30. Oh, and don't be gentle with it just because it's sick; it's important to get it moving, or you'll only be contributing to the problem. cool
Page 2 of 2 < 1 2
