My $250 Saturn climbed Mt Washington
by eljefino
07/24/16 03:07 PM
Coolant change issue
by renegade_987
07/24/16 03:05 PM
Shell X100 30/40?
by FordCapriDriver
07/24/16 02:59 PM
Do you reuse ring gear bolts?
by buck91
07/24/16 02:54 PM
Wonder if anyone with NASCAR has noticed...
by mrsilv04
07/24/16 02:42 PM
Brake Pad Anti Rattle Clips
by Miller88
07/24/16 02:02 PM
Video: Napa Proselect 21334 cut open
by cronk
07/24/16 01:12 PM
what viscosity on a new build? 351W/408 street
by tomcat27
07/24/16 12:14 PM
What is this plant?
by skyactiv
07/24/16 11:16 AM
Recycling
by mjoekingz28
07/24/16 10:30 AM
Craftsman Action Bypass Lopper ~$11.70
by Sayjac
07/24/16 09:51 AM
2017 Fusion Hybrid
by AirgunSavant
07/24/16 09:50 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
80 registered (Abdulla, 09_GXP, bdcardinal, AandPDan, bbhero, barkingspider, 8 invisible), 2005 Guests and 9 Spiders online.
58578 Members
66 Forums
252193 Topics
#3318578 - 03/20/14 11:03 PM It is to laugh
double vanos Offline
Loc: Bisbee, Arizona
Just saw this on a Mazdaspeed forum - cut and paste job for y'all :
learn from this:
If you buy car new and start using synthetic from 0 miles....ur good as long as u stay synthetic
If you buy car new and start using regular from 0 miles....ur good as long as you stay regular
If you buy car used....its a hit or miss.
If you run regular for, idk, lets say 50k miles then decide to switch to synthetic, that's when you will have problems.
If you run synthetic for, idk, lets say 50k miles then decided to switch to regular, that's when you will have problems.
(And then there was this):
before every oil change seafoam your engine within 250 miles of changing your oil and use Rotella T6
end thread
I learned a lot there...All you bitogers that just run whatever is on sale, beware!
Svetlana Kapanina is harder core than Sabine Schmitz.
www.kapanina.com
#3318589 - 03/20/14 11:18 PM Re: It is to laugh [Re: double vanos]
wallyuwl Offline
Loc: Lexington, KY
They are right about this: it is important to stay regular.
#3318618 - 03/21/14 12:27 AM Re: It is to laugh [Re: double vanos]
stephen9666 Offline
Loc: USA
I text as much as the next guy, but I don't put much faith into a post on auto maintenance where the author couldn't take the time to spell out "you are" or "I don't know."
#3318620 - 03/21/14 12:39 AM Re: It is to laugh [Re: double vanos]
Darwin1138 Offline
Loc: Slimy Mudhole
I think that post is the modern version of this
Quote:
If you walk under a ladder, you will have bad luck
If a black cat crosses your path you will have bad luck
To open an umbrella in the house is to bring bad luck
A bird that comes in your window brings bad luck
Crossing your fingers helps to avoid bad luck and helps a wish come true
0W-20 or death!
#3318651 - 03/21/14 04:22 AM Re: It is to laugh [Re: wallyuwl]
Rick in PA Offline
Loc: Southeastern, PA
Perhaps I should add Citrucel to my oil change regime. wink
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
#3318681 - 03/21/14 06:17 AM Re: It is to laugh [Re: wallyuwl]
ARB1977 Offline
Loc: North Texas
LOL
2015 Tacoma 4.0L 30K (as of 5-24-16)
Mobil One EP 5W30 / Toyota filter
2008 CRV 2.4L 144K (as of 04-13-16)
Maxlife 5W20 / Fram TG filter
#3318715 - 03/21/14 07:35 AM Re: It is to laugh [Re: double vanos]
Miller88 Offline
Loc: Onondaga County
My Cherokee was run to 100K before it was switched to synthetic. Over the last 2 years, it seems I have done syn,conventional, syn, conventional.
Same with the Focus.
Guess neither of them will make 100K miles?
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3318738 - 03/21/14 07:56 AM Re: It is to laugh [Re: Miller88]
Anies Offline
Loc: NJ
Doesn't really matter what you use, just that you change it when it needs to be changed. Might get some burning or leakage depending on formulation but it generally evens out after a few oil changes.
Speaking of which, wife's Impreza is due for an oc. 6k miles on Cam2 stash o_O ruh-oh.
2012 Nissan Frontier SL V6 (mine)
2014 Ford Fusion SE w/Tech (wifey)
+Dealer Serviced
#3318754 - 03/21/14 08:12 AM Re: It is to laugh [Re: Darwin1138]
Benzadmiral Offline
Loc: Da Swamp
Quote:
. . . If a black cat crosses your path you will have bad luck
If that were true, I'd be dead now. My black cat crosses my path approximately 50 times a day!
-- Paul W. (The Benzadmiral)
('11 Buick Regal CXL, charcoal/cream, 2.4L NA)
http://benzadmiral-uncle.blogspot.com/
#3318807 - 03/21/14 08:59 AM Re: It is to laugh [Re: double vanos]
Rolla07 Offline
Loc: MTL, CANADA
The internet, where nonsense spreads its wings..lol
2007 Corolla Red Pearl 138k miles
Pennz Ultra 0w40 & Napa Proselect
#3318836 - 03/21/14 09:20 AM Re: It is to laugh [Re: Rolla07]
strat81 Offline
Loc: Nebraska
Clearly you've never sat at the counter at a service department, parts department, hardware store, gun shop, or bar.
There's plenty of nonsense floating around offline too.
Molon Labe
#3318880 - 03/21/14 10:10 AM Re: It is to laugh [Re: double vanos]
pandus13 Offline
Loc: Chicago,IL,USA
go crazy on them:
send them the link to synlube site
13 Mazda5
08 Toyota Yaris Sedan
04 Elantra (sold)
95 accent (sold)
95 mystique (sold)
97 concorde (gone)
#3318947 - 03/21/14 11:35 AM Re: It is to laugh [Re: double vanos]
jrustles Offline
Loc: Ontario, Canada
lol mazdaspeed forum
I'm not surprised; no shortage of bozos there. The seafoam thing isn't a bad idea, though- keep those ports clean.
Edited by jrustles (03/21/14 11:36 AM)
"No matter how paranoid or conspiracy-minded you are, what the government is actually doing is worse than you imagine" W.Blum
#3319924 - 03/22/14 04:08 PM Re: It is to laugh [Re: double vanos]
MCompact Offline
Loc: KY
This reminds me of the idiot on an Abarth forum who claimed adding ATF to conventional oil made the mixture a synthetic oil...
Mine:
2014 M235i
1999 Wrangler Sahara
1995 318ti Club Sport
1996 Speed Triple
Wife's:
2004 X3 2.5i
Son's
2009 328i
Buy what makes you smile...
