Microgreen Oil Filter 50% Off Discount Code
by kohnen
05/26/16 11:24 AM
by kohnen
05/26/16 11:23 AM
Mobil Delvac 1 ESP 5w-40 for 2011 TDI?
by ruleof72
05/26/16 10:49 AM
Husquvarna YTH2046 riding mower
by Donald
05/26/16 10:47 AM
Any machinists?
by NavyVet88
05/26/16 09:28 AM
new XG750R flat-tracker
by Mik
05/26/16 08:55 AM
Walmart Supertech 5w20 full synthetic $8.12
by paulswagelock
05/26/16 08:51 AM
Thoughts on M1 V-Twin 20-50 Oil?
by ZZman
05/26/16 08:07 AM
Real Estate Rates
by AirgunSavant
05/26/16 06:30 AM
15w-40 in my boat, is diesel oil OK?
by chriscpmtmp
05/26/16 05:47 AM
20W-50 for a hydraulic pump in a hydrostatic trans
by ford46guy
05/26/16 03:48 AM
new castrol edge high mileage synthetic
by hiflo
05/26/16 03:32 AM
Rdyno, Darsahn, jerryg, 1971tr350, Mak712
57990 Registered Users
92 registered (AirgunSavant, ARCOgraphite, badtlc, 1JZ_E46, AZjeff, Atesz792, 7 invisible), 1789 Guests and 310 Spiders online.
57990 Members
66 Forums
249424 Topics
Page 1 of 2 1 2 >
#3319259 - 03/21/14 06:35 PM Better gas mileage with stiffer suspension.
Nayov Offline
Loc: ME
Well, why not? Shock absorbers (struts) soak up energy and turn it into heat which is wasted energy. When a car bobs up and down while going down the road, it cost energy to lift the car. Anyone who's ridden a dual suspension bicycle knows that it saps energy from the rider.
So taking this to the absurd level, would a car with no suspension render better fuel mileage? I know it would be undriveable, so it's for illustrative purposes only.
I got to thinking about this after I replaced all 4 struts on my car. It now rides dramatically harder and I'm wondering if I will see better fuel mileage.
#3319262 - 03/21/14 06:40 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
zzyzzx Online   content
Loc: Baltimore, Maryland, USA
This seems unlikely to me.
#3319263 - 03/21/14 06:43 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
yonyon Offline
Loc: NJ, USA
It seems to me that a softer suspension would be the way to go (less energy lost compressing the suspension) for fuel economy over bumps but realistically it isn't going to add up to much. It really isn't all that much energy wasted.
For the suspension to provide a real-world benefit to fuel economy you want a setup that reduces or eliminates the need to brake before cornering. That will save you a lot more wasted energy than gliding over bumps.
#3319266 - 03/21/14 06:47 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
PandaBear Offline
Loc: Silicon Valley
Compare to aerodynamics and rolling resistance, suspension loss is nothing.
A stiffer suspension means your car will bump higher and then bonce a bit stiffer than softer suspension, just how long will those "bonce around" turns into heat, but they all turns into heat eventually.
The only way I see it is a harder suspension reduce comfort, and force the driver to slow down to be more comfortable. It is like saying speed bump reduce speed and make your drive more fuel efficient.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#3319273 - 03/21/14 06:57 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
yonyon Offline
Loc: NJ, USA
This discussion has me wondering if those BMW control arm bushings that always break might be designed to do that. The front wheels, when hitting a bump while the bushings are broken, get shoved rearward and accelerate upwards more slowly so as to change less forward motion to upwards motion, then they snap up over the ridge of the bump. UFO
#3319278 - 03/21/14 07:05 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
Trajan Offline
Loc: SE PA
A shock absorber is a mechanical device designed to smooth out or damp shock impulse, and dissipate kinetic energy.
Nothing more. Nothing less.
Lack of harm is not proof of benefit.
There are in fact two things, science and opinion; the former begets knowledge, the later ignorance. Hippocrates
#3319286 - 03/21/14 07:14 PM Re: Better gas mileage with stiffer suspension. [Re: Trajan]
Nayov Offline
Loc: ME
Yes, but I would add that dissipated energy (heat) is wasted and it costs fuel, but I do concede that the amount is in all probability immeasurable.
#3319289 - 03/21/14 07:16 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
Burt Offline
Loc: texas
I have a hard time seeing how vertical motion/energy is converted into horizontal motion/energy by a stiffer suspension.
Kind of like hitting a hammer up or down on your car and expecting it to move forward.
2011 RX350 38k miles
2015 Fiesta SFE eco-boost 7k miles
#3319299 - 03/21/14 07:28 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
Trav Offline
Loc: MA, Mittelfranken.de
Go a step further and remove the shocks totally. Use the bouncing motion of the springs to run a generator to charge the batteries in a hybrid system. LOL
No. Stiffer struts wont improve fuel economy unless its a Nissan Maxima then it might get 20% more.
#3319314 - 03/21/14 07:42 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
spasm3 Offline
Loc: out there
If you have to slow down more to corner and turn due to the body roll with no or really soft shocks, you will consume more energy getting back up to speed. Verses coasting at a faster rate around corners/s turns and using less fuel to accelerate from a higher exit speed due to better suspension.
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#3319345 - 03/21/14 08:07 PM Re: Better gas mileage with stiffer suspension. [Re: Trav]
Nayov Offline
Loc: ME
It's been done! Well, a car powered road generator.
"The Road Surface Generator device is a revolutionary new device that incorporates current technology by utilizing the motion and weight of vehicles to produce clean, economical and ecologically sound electrical current. The Road Surface generator relies on kinetic energy produced by moving vehicles then transferred via a simple device located on surfaces that connect to a turbine generator to produce energy."
http://www.google.com/patents/US20080106103
#3319353 - 03/21/14 08:20 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
JHZR2 Offline
Loc: New Jersey
You're assuming that you're converting potential energy of fuel to potential energy of ride height.
Perhaps a bouncy car has a worse aerodynamic profile, but I doubt it is much.
I can see savings from taking curves faster, as forward momentum can be wasted and is valuable.
#3319369 - 03/21/14 08:38 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
Trajan Offline
Loc: SE PA
How is it wasted? Shock absorbers do not power or draw power from the engine.
#3319382 - 03/21/14 09:01 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
Merkava_4 Offline
Loc: Clovis, CA
The more you keep the car in a straight line, the better the fuel mileage will be.
A car getting tossed around from stiff suspension is going to affect its straight line.
#3319401 - 03/21/14 09:28 PM Re: Better gas mileage with stiffer suspension. [Re: Nayov]
Donald Online   content
Loc: Upstate NY
It the suspension makes a difference at all, the wind and how much coffee the driver has had probably make double the difference as suspension.
Its pretty hard to accurately measure MPG unless you use a flow meter like Consumer Reports does.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
Page 1 of 2 1 2 >
