My2011 forester uses the high beams(h9) for DRL and runs them at lower voltage.. to lower the brightness.
This is a bad idea because you will eventually get a sooty buildup inside the bulbs from not being run hot enough.
Then when you actually need your high-beams they wont be as bright as they could have been.
Pic=1000words
This picture isn't perfect the orange is actually MUCH MORE Visible in real life ie: the photo doesn't look as bad as it actually is.
Whats missing from the photo is the fact that the sides are all partially coated just not Quite as bad as the tip
Compare the bottom right on the bulb-side (nearly clear) to the top-side, and left side of the bulb and you will start to see the discoloration.
Pic=1000words
