Misspelling
by callbay
07/28/16 09:21 AM
Suggest an experiment?
by ToadU
07/28/16 08:39 AM
FCA to produce no *cars* in the US
by Hokiefyd
07/28/16 08:37 AM
Zero Emission Power Stations...
by Shannow
07/28/16 05:52 AM
200k!!!! 2005 legacy gt wagon manual transmission
by madRiver
07/28/16 05:38 AM
Adhesive protective patch in wheelwell
by dlundblad
07/28/16 05:02 AM
My Faith Has Been Restored
by bobbob
07/28/16 02:57 AM
Kohler Courage 15
by Commeres
07/28/16 02:13 AM
Windstar 2001 AC Low and High pressure reading
by pinjc
07/27/16 09:28 PM
Vacuum Pump Oil for rotary vane pumps.
by bunnspecial
07/27/16 09:22 PM
ST dino oil realistic OCI
by OILGEEK27
07/27/16 09:06 PM
Gas grills
by RN89
07/27/16 08:43 PM
donsladek, rummy, OILGEEK27, pinjc, Lee_C
58627 Registered Users
96 registered (adolan21, 09_GXP, AirgunSavant, 2015_PSD, 97 GTP, Andrei, 9 invisible), 1757 Guests and 12 Spiders online.
58627 Members
66 Forums
252347 Topics
Page 1 of 8 1 2 3 4 5 6 7 8 >
#3318298 - 03/20/14 06:27 PM Advantages of straight weight oil
Now Offline
Loc: Alabama
New member first post. I've been working in the industrial field since 1980 and was greasing cars and trucks since age 13 using the old huge single cylinder lift.
I did do a search.
Topic should read disadvantages of multi weight oil. What qualities does the oil forfeit to become multi-weight?
I know about cold starting and flow capability of multi-weight. I always allow my engines to warm up, before raw-hiding them.
Any links welcome.
Two ears, one mouth. Jack of all trades. Trust me.
#3318305 - 03/20/14 06:34 PM Re: Advantages of straight weight oil [Re: Now]
Hyde244 Offline
Loc: Ohio
Since straight weight oil doesn't have Viscosity Improvers, it will not sheer as readily.
However, the advantage of having a lower viscosity at start-up outweighs this factor, which is why multi grade oils are recommended for all modern light-duty engines. Multi-grade also has the benefit of better detergent development; that is, Pennzoil and Mobil 1's detergents are not seen in any single grade oils.
Simply put, multi grade oil carries many performance improvements that makes it the superior oil.
2007 Ford Focus ZX4 SES - 2.0L Duratec | 4F27E Auto | 92,000 miles
PU 5w20 | MC 910 | Castrol Mercon V
#3318312 - 03/20/14 06:39 PM Re: Advantages of straight weight oil [Re: Now]
Rand Offline
Loc: NE,Ohio
if the multigrade oil has no,a small amount of , or high quality VII then then there is really no advantage to single grade motor oils in most applications.
2015 Forester I-Premium 6MT
#3318326 - 03/20/14 06:51 PM Re: Advantages of straight weight oil [Re: Now]
fdcg27 Offline
Loc: OH
Even the straight grades aren't really straight.
The basestock will have its own VI, so even a straight grade will be thinner at cold start than it's SAE viscosity grade might lead you to think.
In your climate, you could probably run a 20W-20 winters and a 30 in summers with no ill effects in most engines.
There was a member here some years ago who ran an Amsoil straight 30 syn in a modern car (It was the old FWD 300M IIRC) with good results and we have at least one other member who ran 30 grade Delo for some time because he got it really cheap on clearance. He had good results as well.
I've sometimes thought that a few runs of a straight grade in a beater followed with a UOA might be very entertaining.
Want to try it?
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#3318330 - 03/20/14 06:55 PM Re: Advantages of straight weight oil [Re: Now]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Been running Delo 400 straight 30 in the GMC in my sig since AZ blew it out for 99 cents/gallon-other than not being able to start it unplugged this winter one morning (-15 degrees F.), no problems.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#3318331 - 03/20/14 06:57 PM Re: Advantages of straight weight oil [Re: Now]
Hyde244 Offline
Loc: Ohio
^ Any noticeable time length in start-up?
#3318347 - 03/20/14 07:15 PM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
Ahh, the good old Delo SAE30 days. I'm down to two gallons!
I started both diesel and gas engines below freezing. I didn't notice any change in cranking time.
2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2004 Malibu Maxx LT
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3318366 - 03/20/14 07:32 PM Re: Advantages of straight weight oil [Re: Now]
CourierDriver Offline
Loc: Tn.
In the 50s and early 60s that is all we had,,,never lost an engine in Tennessee over it,,,go figure.
If I told you to invest in something that would cost $24k,go down in value,cost over $2K a year to operate,you would say Im crazy,,,got a car??
#3318399 - 03/20/14 07:54 PM Re: Advantages of straight weight oil [Re: Now]
gfh77665 Offline
Loc: Southeast Texas
I have:
1) Mixed 30 with 10-30 in varying amounts
2) Ran straight 30
3) Even ran straight 40 (Im in TX summer and oil was almost free)
My 1997 Chevy truck never...even...noticed.
#3318450 - 03/20/14 08:39 PM Re: Advantages of straight weight oil [Re: Now]
JHZR2 Offline
Loc: New Jersey
In an engine that is run for very long times, essentially steady-state, I dont see a reason to use anything different. Uses like that might be boats or cross-country applications like greyhound busses.
IMO the shear-stability and better flow of a multigrade makes it the better option, these days at least. In some places with high continuous ambient conditions, it still may be the best.
If I truly drove non stop a lot, and could find a good monograde, I suspect it might be an interesting application. Perhaps ditto if I were driving a police car or taxi. For anything else? Not sure unless it was really needed for some other reason, and you didnt want to go syn.
Here is an interesting little thread I had a few years ago about MB's design considerations for monogrades:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2325682&page=all
#3318460 - 03/20/14 08:52 PM Re: Advantages of straight weight oil [Re: gfh77665]
turtlevette Offline
Loc: Massachusetts
Do you think it lubricates as well as a 0W in the first 10 minutes after startup below freezing?
Originally Posted By: gfh77665
I have:
2) Ran straight 30
I don't mean to single you out...
Why do you think it was free? We keep hearing things like "my engine likes it" or "my engine doesn't like it". There are all kinds of placebo effects going on here.
We could drain all the oil out of our engines and they'd start right up and run well for some time. Is that a like or dislike?
#3318475 - 03/20/14 09:10 PM Re: Advantages of straight weight oil [Re: Now]
artificialist Offline
Loc: Florida
Briggs And Stratton and Tecumseh engines often recommend using SAE30, and in extreme cold, multigrade syn is recommended.
Yes, there is Amsoil SAE30. It got the name because much like other SAE30 oils, there are no VIIs. However, since PAO basestocks already have a great viscosity index, some people have compared the oil to a 10w30.
A while ago, I did some research on the 1970s Pontiac 301 turbo engine. It called for SAE30 in all temperatures, and some people have said that the multi-viscosity oils would have a higher NOACK, and with the added heat of a turbo, that could be a huge problem.
Another reason SAE30 has an advantage over multigrade oil is that the API does not limit SAPS content the way it does in multigrade oils. That in mind, you would need to do a VOA to actually know if it is a high SAPS oil.
2010 Lancer Ralliart Sportback
#3318480 - 03/20/14 09:12 PM Re: Advantages of straight weight oil [Re: JHZR2]
Shannow Offline
Loc: Oz
Also without the temporary shear of VIIs (I believe that) you can run thinner straight weight KV100s than multis...
As an example, this makes sense...moreso to me than a 0W-20 in a 10W-30 application.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1174209
#3318482 - 03/20/14 09:14 PM Re: Advantages of straight weight oil [Re: turtlevette]
Shannow Offline
Loc: Oz
Do you think that someone who doesn't ever SEE freezing needs any more than SAE30's cold properties ?
#3318493 - 03/20/14 09:23 PM Re: Advantages of straight weight oil [Re: turtlevette]
gfh77665 Offline
No placebo effect here, I am referring to the clearance price I bought it out at. I bought 200+ qts for less that $150, when some convenience stores were closing out. Most all of it was Mobil 5000 or PYB.
The majority was 5-30 and 10-30, but it did include about 15-20 30's and 40's.
I use the multigrades in the winter, and use up the straight weights in the TX summer.
#3318501 - 03/20/14 09:32 PM Re: Advantages of straight weight oil [Re: Now]
Shannow Offline
Loc: Oz
turtlevette seems to have a misunderstanding of the "placebo" effect, thinking that the "placebo" effect is imagination, when it is actual, clinical changes, brought about by something that shouldn't have brought such changes.
#3318504 - 03/20/14 09:35 PM Re: Advantages of straight weight oil [Re: turtlevette]
Zaedock Offline
Loc: Massachusetts
Yep. It did a fine job too.
There is more to start up wear than oil flow. Delo SAE30 has a pour point of -24*F and behaves more like a 15W30.
10 minutes? Is it ideal, no - but nothing is going to blow up.
#3318505 - 03/20/14 09:40 PM Re: Advantages of straight weight oil [Re: Shannow]
turtlevette Offline
Loc: Massachusetts
Yes. Absolutely.
I think I see a pattern here. You have different "fan clubs" here. Thick oil, thin oil, and no/low VIIs. There's really no changing of anyone's mind that's going to happen.
#3318510 - 03/20/14 09:47 PM Re: Advantages of straight weight oil [Re: Now]
Shannow Offline
Loc: Oz
No, please explain how oil that's flowing in seconds is going to protect more than oil that's flowing in seconds...I'm interested.
#3318523 - 03/20/14 09:55 PM Re: Advantages of straight weight oil [Re: Shannow]
turtlevette Offline
Loc: Massachusetts
Unless the oil is in its viscosity sweet spot its in its "plastic" state and does not lubricate as well.
Also, do you think oil in a syrup like state is going to sling properly to lubricate the piston and rings?
Hello?
#3318531 - 03/20/14 10:03 PM Re: Advantages of straight weight oil [Re: Now]
Shannow Offline
Loc: Oz
Sorry, as usual, you are going to have to dumb your technical talk down to third grade level....
"syrup", "sweet spot", "sling" and "plastic" are new ones to me.
#3318535 - 03/20/14 10:07 PM Re: Advantages of straight weight oil [Re: Shannow]
turtlevette Offline
Loc: Massachusetts
You also have cavitation issues with thick cold oil.
#3318537 - 03/20/14 10:07 PM Re: Advantages of straight weight oil [Re: Now]
gregk24 Offline
Loc: FL, USA
The only advantage I can think of would be better shear stability, which is not a concern in modern multi viscosity oils so shear stability is a moot point. The modern multi weight oils are without a doubt the better oil
2012 Honda Accord EX-L
Taffeta White - Ivory
39,xxx miles
PPPP 0w20 / Fram Ultra
#3318539 - 03/20/14 10:09 PM Re: Advantages of straight weight oil [Re: turtlevette]
jrustles Offline
Loc: Ontario, Canada
>plastic
>syrup like state
>non-freezing climate
Slow down turt, think about what you're trying to say. Your imagination is running wild with all that sensationalism.
Yes. Absolutely.
When you find yourself part of a fan club, by perhaps being hyper-reactional and anti-the-other-guy to people who disagree with your way of thinking for instance, then you know getting off course. Just accept that other people's reality will not correspond with your imagination. smile
"No matter how paranoid or conspiracy-minded you are, what the government is actually doing is worse than you imagine" W.Blum
#3318642 - 03/21/14 03:03 AM Re: Advantages of straight weight oil [Re: Shannow]
Shannow Offline
Loc: Oz
For those that haven't looked at the link, GMan ran 20W-20 in his car that is definitely not a beater, and posted UOAs.
#3318644 - 03/21/14 03:18 AM Re: Advantages of straight weight oil [Re: Now]
Merkava_4 Offline
Loc: Clovis, CA
I gotta question for you guys: Why is SAE30 often labelled HD30 ?
#3318660 - 03/21/14 05:26 AM Re: Advantages of straight weight oil [Re: fdcg27]
Shannow Offline
Loc: Oz
To be a "straight" weight, the lubricant has to be "Newtonian", and typically/always devoid of polymeric thickeners.
So, regardless of VI, a "straight" weight will have an identical viscosity regardless of shear rate for a given temperature...if your crankshaft is spinning 1,000 RPM, 3,000 RPM, or 20,000 RPM, at 100C, your 11cst 30 will be 11cst at every rpm increment.
Until multigrades were developed, the concept of "HTHS" was irrelevant (more so "not yet needed"), the normal viscosity classifications applied, and worked everywhere.
Multigrades with polymeric VII are non newtonian, and have different viscosities at the same temperature depending on the shear rate of the oil...the viscosity in your bearing at 1,000, 3,000, or 20,000 will be different.
That's why they introduced the HTHS concept, and requirement into J300...in the words of SAE
Quote:
To insure that polymer-containing oils do not create a situation in which the viscosity of the oil decreases to less than a specified limit, minimum values of HTHS viscosity are assigned to each of the non-W viscosity grades in Table 1. A
special situation exists regarding the SAE 40 grade. Historically, SAE 0W-40, 5W-40, and 10W-40 oils have been used
primarily in light-duty engines. These multigrade SAE 40 oils must meet a minimum HTHS viscosity limit of 3.5 mPa·s.
In contrast, SAE 15W-40, 20W-40, 25W-40, and 40 oils have typically been used in heavy-duty engines. The manufacturers of such engines have required HTHS viscosity limits consistent with good engine durability in high-load, severe service applications. Thus, SAE 15W-40, 20W-40, 25W-40, and single-grade 40 oils must meet a minimum HTHS viscosity limit of 3.7 mPa·s.
http://paservice.it/wp-content/uploads/2013/06/J300_201304.pdf
Out of interest, an SAE30 "newtonian" oil of around 10-11cst, KV100 typically will be around the 3.5-4cst at 150C...the original 2.9 for the 0, 5, and 10W-40s show how badly VII wasn't so good when developed...the current requirement for 3.5 for those same grades shows just how much modern VII have improved in recent years, in being able to meet those specs in (allegedly) every oil that you see holding the SAE ratings.
A High VI "straight weight", like Amsoil 30 can claim 10W, as it's cold temperature performance can meet those requirements...but it's still newtonian and can claim "straight"
#3318666 - 03/21/14 05:54 AM Re: Advantages of straight weight oil [Re: turtlevette]
Oil Changer Offline
Loc: Michigan
Congratulations! You just graduated BITOG academy.
#3318671 - 03/21/14 06:00 AM Re: Advantages of straight weight oil [Re: Now]
Loc: Tn.
aaaaaaaaaaaaaaaaaamen
#3318828 - 03/21/14 09:14 AM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
I found this cold viscosity info in my old files when some of us were messing with the Delo SAE30. I can't remember who calculated the numbers. It may have been Audijunkie.
Delo SAE 30
100c 12.1cST
40c 105 cSt
10c(50f): 726.5 cSt
5c(41f): 1102.3
0c(32f): 1731
-5c(23f): 2825.4
-10c(14f): 4809.1
-15c(5f): 8575.7
-20c(-4f): 16100.7
#3318838 - 03/21/14 09:23 AM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
This is a cool video. I made a similar pump to transfer used motor oil. It can fill a 55 gal drum in a couple of minutes.
Keep in mind WVO is quite viscous.
http://www.youtube.com/watch?v=8o52BYTEau4
#3318845 - 03/21/14 09:28 AM Re: Advantages of straight weight oil [Re: Now]
Paul3637 Offline
Loc: FL 2010 KS before that
Why waste this space.
The owners manual to my el cheapo YardMarchine non-self propelled mower says to use 5W30 synthetic for all temperature ranges. Why would anyone in this century bring up single weight oil. It is not for use in any passenger car made in the last 30 years.
Edited by Paul3637 (03/21/14 09:30 AM)
#3318850 - 03/21/14 09:31 AM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
It's a discussion forum.
Why waste space with useless posts?
#3318913 - 03/21/14 11:04 AM Re: Advantages of straight weight oil [Re: Shannow]
jrustles Offline
Very well stated. Thank you thumbsup
#3318969 - 03/21/14 11:53 AM Re: Advantages of straight weight oil [Re: Merkava_4]
A_Harman Offline
Loc: Michigan
HD30: High Detergency SAE 30 weight
In contrast with ND30, which is non-detergent.
There used to be a debate 40-50 years ago about detergent versus non-detergent oils. Some would say high detergent oils would not provide good wear protection, so ran non-detergent oils in their engines, and changed oil on short intervals to keep them from sludging.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3318984 - 03/21/14 12:06 PM Re: Advantages of straight weight oil [Re: Paul3637]
AP9 Offline
Loc: Chicago suburbs
I understand your point, but just because not many people use straight weight in motor vehicles anymore doesn't mean it's a useless discussion, not by any means. Some of us are here to learn, not just to accept things for what they are, and that's the spirit of this forum. For example, Shannow has provided some excellent information on this thread, specifically regarding the use of VIIs and viscosities changing under different shear on the oil.
Just my 2 cents.
2000 Ford Explorer XLT 4WD (4.0L OHV) - QSUD 5W-30/MC FL1A
1996 Chevrolet Impala SS - M1 0W-40/M1-201
#3318993 - 03/21/14 12:15 PM Re: Advantages of straight weight oil [Re: Paul3637]
edhackett Online   content
Loc: Sequim, WA
You obviously haven't read a Subaru owner's manual up until the introduction of the FB engine a couple of years ago. My 2008 specifically allows SAE 30 and SAE 40 for desert areas or heavy duty use.
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
#3319158 - 03/21/14 03:41 PM Re: Advantages of straight weight oil [Re: Now]
Loc: Tn.
I may try the straight 30 wgt this summer on my 3800. Have not run straight oil since the late 60s.
#3319203 - 03/21/14 04:46 PM Re: Advantages of straight weight oil [Re: Now]
Clevy Offline
Loc: Saskatoon canada
I've used amsoils straight 60 v-twin oil in my Harley and I liked it,other than cost. I'm going to use up what I've got left once summer hits.
2006 Charger RT
Miles x 2 per oil filter
#3319208 - 03/21/14 04:54 PM Re: Advantages of straight weight oil [Re: A_Harman]
Merkava_4 Offline
Loc: Clovis, CA
Thanks for answering my question. I thought HD meant Heavy Duty.
Does the HD30 have more detergents than 10W-30 ?
#3319275 - 03/21/14 07:03 PM Re: Advantages of straight weight oil [Re: Now]
Red91 Offline
Loc: Alabama, United States
This is actually a very interesting topic. My local Napa carries Delo SAE30 in quart bottles.....might try some in the GMC next oil change.
'15 Chevy Cruze LS
1.8 4 Cyl, 6 Speed Auto
QSUD 5/30, STP XL Filter
'92 Buick Roadmaster Wagon
5.7 V8, Auto
QS 20/50, LMMoS2, Napa Gold Filter
#3319406 - 03/21/14 09:38 PM Re: Advantages of straight weight oil [Re: Clevy]
Shannow Offline
Loc: Oz
Subject for another thread, but I don't think it's actually a straight weight.
#3319443 - 03/21/14 10:25 PM Re: Advantages of straight weight oil [Re: Merkava_4]
chainblu Offline
Loc: Florida
I do too. I'm actually looking at a bottle of ST HD-30 that I bought yesterday for my lawn mower. It says "Heavy Duty" at the top of the label and then "Heavy Duty Formulation" lower down. Nowhere on the bottle does it say "High Detergent", but I'm sure compared to a ND-30, it IS a high detergent oil.
#3319489 - 03/21/14 11:46 PM Re: Advantages of straight weight oil [Re: A_Harman]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
A_Harman - It is my understanding that HD means Heavy Duty. This was most certainly the case in Europe and Oceania in the 1950s-1960 and under the nomenclature used then by the API
There were variations of this Under the Mil and CAT requirements of the time. In those years Mobil, Castrol, Shell and Caltex-Chevron made lubricants for petrol engines that had similar "detergency" levels to some Heavy Duty lubricants
That said, I used Heavy Duty lubricants in many petrol engines (both mono and multigrade) and in fact Heavy Duty lubricants were specified by VW, Porsche and Mercedes Benz in that era. And I can confirm that many of their Engineers of the era also understood that HD meant Heavy Duty
I still use HDEOs in some petrol engines too
Regards
Doug
#3319521 - 03/22/14 03:48 AM Re: Advantages of straight weight oil [Re: Clevy]
Now Offline
Loc: Alabama
I bought about 8 quarts of SAE60 back in 1981. Bought a used 1976 FLH 1200 with 2800 miles and sold it 6 months later. Bike was not dependable to say it nicely.
I use full synthetic in all of my gas burners. I try to go way past the recommended factory interval. I've got 3 diesels that get delo 15w40. Somewhere years ago I read that straight weight oil is less likely to shear under adverse conditions. My Hondas (yes I like Hondas) are always driven between 10 and 30 miles due to our rural location.
Lots of good answers here. I know a lot about engines and oil, but for now I'm going to play dumb. I've got to allow my urine to build up for a week. I can't compete with some of these members. In case you didn't notice, there's a contest going on in this forum. LOL grin
#3319543 - 03/22/14 06:42 AM Re: Advantages of straight weight oil [Re: Paul3637]
Ducked Offline
Loc: Taiwan
Still quite popular in Taiwan, though now a bit harder to find on supermarket shelves. My 2nd hand Ford 2L DOHC Sierra came with 5 litres of Delvac straight 40, courtesy of the previous (Taiwanese) owner. Hydraulic tappets [US: "lifters" I think] too.
#3319666 - 03/22/14 10:39 AM Re: Advantages of straight weight oil [Re: Now]
KCJeep Offline
Loc: Mahzurrah!
Interesting thread. The UOA link posted was interesting as well. Kind of makes you wonder about all the "flow at start up" and "wear at start up" theories doesn't it?
I'll have to pay more attention but I "think" some HD30's tend to be non detergent whereas most SAE30's mirror there multi-weight counterparts in add pack but are straight weights. Not sure on that I'll have to look harder next time I am in the oil aisle.
I do know I ran SAE30 without issue in our 87 Chevy years ago without apparent issue. I didn't know a thing about oil then but it had consumption with 5w30/10w30's. I tried the straight 30 in it and zero consumption. I didn't know anything about oil back then but now you've got me wondering what a summer run of straight 30 would look like UOA wise in my Jeep! Blasted BITOG anyway ha ha.
2004 Jeep Grand 4.0 @ 133k Pennzoil HM 10w30 w/ 1 qt 10w40
Fram PH8A
KIA Sedona 62k, Ford Focus 116k, Chrysler Sebring 186k, Chrysler Concorde 120k
#3319690 - 03/22/14 10:58 AM Re: Advantages of straight weight oil [Re: KCJeep]
jrustles Offline
This is your last chance. After this, there is no turning back. You take the blue pill – the story ends, you wake up in your bed and believe whatever you want to believe. You take the red pill – you stay in Wonderland, and I show you how deep the rabbit hole goes. Remember, all I'm offering is the truth – nothing more.
#3319742 - 03/22/14 11:57 AM Re: Advantages of straight weight oil [Re: turtlevette]
Zaedock Offline
Loc: Massachusetts
I have a 5 or 6 year old UOA from my trail Jeep that was very good running the Delo SAE30. If memory serves, I ran about 1500 street miles (back when it was still street legal) and many gallons of fuel burned off road. My Fe number was 9 PPM. Actually, I believe sodium was elevated in that UOA as well, but potassium was 0 and we determined it was the salt treated dirt roads we were using. The 2nd and 3rd UOA's confirmed.
There are many factors that contribute to start up wear. Acid build up, condensation, cold internal components, etc. If the oil is pump-able, then typically adequate lubrication is provided. Obviously this is only to a point if it's flippn' cold out.
Hello?
Turtlevette's concerns do have validity. I have seen an old white paper where they tested multi-weights against straight cold start wear(5&10W30 vs SAE30) and the straight weight actually showed slightly less wear, but I can't remember the temperature of the test. I'm sure a modern test of a 5W30 vs a SAE30 consistently tested below freezing would show less wear with the multigrade. Whether or not the wear accounts to a decrease in the useful life of the engine is another matter.
In my personal use, I have used SAE30 below freezing and watched instant flow from the rockers (BuickGN did a similar "test" watching his Grand National with 20W50). I don't remember any weird noises and the UOA looked good (not that UOA's are a wear indicator, but we still use them as such). The issue I have noticed is the parasitic loss of having to pump SAE30 or even 10W40 vs the Grp III 5W30 oil I have settled on using in this vehicle. My last UOA was very good Fe wise, so why would I not take advantage of the better flow characteristics?
#3319770 - 03/22/14 12:39 PM Re: Advantages of straight weight oil [Re: Shannow]
KCJeep Offline
Loc: Mahzurrah!
Did I understand that right? Are you saying for example PYB SAE30 with a kv100 of 10.5 (like it's 5w/10w30 grade siblings) actually has an HTHS of about 3.5 instead of 3.0 or 3.1 for the others? That is very interesting information I had no idea.
Fram PH8A
#3319800 - 03/22/14 01:32 PM Re: Advantages of straight weight oil [Re: KCJeep]
Red91 Offline
Since you can still find SAE30, I don't see any reason not to use it if your application tolerates it. It's always nice to have alternatives.
'15 Chevy Cruze LS
5.7 V8, Auto
#3319824 - 03/22/14 02:02 PM Re: Advantages of straight weight oil [Re: Zaedock]
jrustles Offline
That is a awesome video, those gear style pumps are no joke thumbsup
#3320069 - 03/22/14 06:20 PM Re: Advantages of straight weight oil [Re: KCJeep]
Shannow Offline
Loc: Oz
Yep, got only a couple minutes at the moment, but if you read the paper in the technical section on cylinder wall hydrocarbon emissions, there's a bit in the middle on temporary shear.
http://www.savantlab.com/images/TBS_Paper_-_SAE_2008-01-1621_The_Expanding_Dimensions....pdf
is a good read.
But in short, look up PDS' for straight weights, even lowly mineral oils like
http://products.lelubricants.com/Asset/8420-8450.pdf
And you can see that all this bunk about "20s that are really 30s", and "30s that are really 40s" is just waffle.
#3320255 - 03/22/14 09:03 PM Re: Advantages of straight weight oil [Re: Now]
beanoil Offline
Loc: Midwest, Illinois
I got in on the Delo buy at AZ too. I'm down to my last 5 gallons. I've run it in a 95 Chevy half ton 350, a 99 F250 5.4 Triton, a 2k Focus, my 03 6.0 Powerstroke, and Honda powered pressure washer, Briggs powered push mower, and my Kohler powered L&G tractor. There is a member here that has run a blend of 30 and 40 weight straight weight in his motorcycle with very good UOA results. There is nothing wrong with straight weights until the weather turns bitter cold. Multigrades are better then.
beanoil: Tough under heat, real dirty afterwards.
#3320265 - 03/22/14 09:11 PM Re: Advantages of straight weight oil [Re: beanoil]
Red91 Offline
So the straight 30 did alright in your 5.4?
'15 Chevy Cruze LS
5.7 V8, Auto
#3320284 - 03/22/14 09:22 PM Re: Advantages of straight weight oil [Re: Shannow]
jrustles Offline
I gotta set some time aside, just sit down and open up that technical paper forum. So much to go over in that forum, thanks to yourself and the other upstanding members.
is a good read.
#3320296 - 03/22/14 09:31 PM Re: Advantages of straight weight oil [Re: Now]
KCJeep Offline
Loc: Mahzurrah!
Thanks Shannow!
Fram PH8A
#3320498 - 03/23/14 03:18 AM Re: Advantages of straight weight oil [Re: Now]
Shannow Offline
Loc: Oz
I'm learning heaps being around here, and loving it.
My formal teaching was back in the late '80s, from some really clued up guys, one memorable bloke in IC engines pointed out that engines really needed three oils, one for bearings, one for pistons, and one for cams...unfortunately such an idea would never wash.
It's all about compromise in design and intent, and the more you can find out, the better decision you can make (however, a follow the manual is pretty close to the mark)
With the 'net available, there's no reason not to learn something new every day...I lay in the bath yesterday (hope it's not TMI) with a cup of coffee, and read that 2008-01-1621 paper over and over...saved it a week to get the time to absorb it (and the mineral bath salts). Those docs can give you a good bite sized understanding of another nuance in the game.
#3320505 - 03/23/14 03:57 AM Re: Advantages of straight weight oil [Re: CourierDriver]
Merkava_4 Offline
Loc: Clovis, CA
In my Buick owners manual, it says 30 weight is OK if 10W-30 is not available, but to switch back to 10W-30 as soon as possible. I'm thinking it would only be critical in cold weather below 40* F.
#3320980 - 03/23/14 03:04 PM Re: Advantages of straight weight oil [Re: Now]
KCJeep Offline
Loc: Mahzurrah!
I am visualizing July weather and straight 30 PYB in my sump. Hmmm.....
Fram PH8A
#3320991 - 03/23/14 03:13 PM Re: Advantages of straight weight oil [Re: Now]
A_Harman Offline
Loc: Michigan
If we keep adding to this thread, we'll all go old school and run straight 30 in the summer, then switch to straight 10W in the winter. When was the last time anybody saw a straight W-grade on the shelf?
#3320993 - 03/23/14 03:16 PM Re: Advantages of straight weight oil [Re: Now]
Red91 Offline
My local NAPA has 30HD PYB, GTX, Delo, and Napa. Of course it is independent and is sort of auto/farm oriented.
'15 Chevy Cruze LS
5.7 V8, Auto
#3321056 - 03/23/14 04:25 PM Re: Advantages of straight weight oil [Re: Red91]
beanoil Offline
IMO, yes. No difference in starting or running. But I did not do a UOA, and my tow vehicles are just that, they tow. When they aren't hooked to the travel trailer, they sit. I drive about 3000 miles a year, from March to October, then it sets all winter. So I cannot tell you if the 30 weight would have worked at or below freezing. But 40 and above, no change in the truck's behavior.
#3321073 - 03/23/14 04:43 PM Re: Advantages of straight weight oil [Re: beanoil]
Clevy Offline
That sounds like ideal conditions for using a straight grade.
And thanks for the links Shannow. You are certainly an asset to this forum and us less informed members.
2006 Charger RT
#3321085 - 03/23/14 04:51 PM Re: Advantages of straight weight oil [Re: A_Harman]
Garak Offline
Loc: Regina, Saskatchewan, Canada
I don't even see any on my Imperial Oil sell sheets. Heck, they don't even sell a Mobil conventional 10w-40 or 20w-50 up here any longer, and all their monogrades are SAE 30 and SAE 40 HDEOs and two cycle diesel oils.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3321164 - 03/23/14 06:05 PM Re: Advantages of straight weight oil [Re: Now]
Red91 Offline
Would anyone here actually try a fill of monograde in an application where it's tolerated? Just for kicks.
'15 Chevy Cruze LS
5.7 V8, Auto
#3321168 - 03/23/14 06:11 PM Re: Advantages of straight weight oil [Re: Red91]
Clevy Offline
I'm considering trying a 30 grade in my charger,just for xxxx and giggles.
2006 Charger RT
#3321189 - 03/23/14 06:29 PM Re: Advantages of straight weight oil [Re: Clevy]
Red91 Offline
What engine do you have in the charger?
'15 Chevy Cruze LS
5.7 V8, Auto
#3321348 - 03/23/14 08:50 PM Re: Advantages of straight weight oil [Re: Red91]
KCJeep Offline
Loc: Mahzurrah!
I imagine my tractor engine Jeep would thrive on it. Seriously considering it for fun but I have some timing problems. I'd only consider it during summer and for any kind of telling results it would be better for it to be a second run UOA to get a real look at how it did. If I was due for an OCI now it would work, but I'm not. frown
Another reason why I don't usually run synthetics, you just have to wait to darn long to try something new!
Fram PH8A
#3321363 - 03/23/14 08:56 PM Re: Advantages of straight weight oil [Re: Red91]
gfh77665 Offline
I have posted the following twice:
I have:
2) Ran straight 30
Even the 40 did fine in my 97 Chevy pickup.
People are STRESSING over nothing, viscosity wise.
#3321364 - 03/23/14 08:57 PM Re: Advantages of straight weight oil [Re: Clevy]
turtlevette Offline
Loc: Massachusetts
I'm going to put 0W-16 when it comes out, in my corvette for the same reason.
#3321600 - 03/24/14 01:42 AM Re: Advantages of straight weight oil [Re: Red91]
Clevy Offline
5.7 litre hemi. With mds. I've already experimented with 40 grade oils in it and they slow down mds engagement by .025 of a second or so,so those folks who believe that you gotta run a 20 grade or the mds won't work take note that it's not true.
Surprisingly enough if you get on the throttle before the oil reaches 140f the ecu throws an oil too thick code.
I've got 5w-20 ultra in it right now. 8000 miles on the oil and I guess due to oxidative thickening it set a cel a few days ago when I got heavy into the pedal.
2006 Charger RT
#3321622 - 03/24/14 04:51 AM Re: Advantages of straight weight oil [Re: A_Harman]
Shannow Offline
Loc: Oz
I've seen a 20W...somewhere in the not too distant past, now I'm wracking my brain for where exactly I saw it...it stood out
#3322745 - 03/25/14 07:34 AM Re: Advantages of straight weight oil [Re: Clevy]
Red91 Offline
So you think it would be alright in the summer on a monograde? I'm seriously very curious.
'15 Chevy Cruze LS
5.7 V8, Auto
#3322904 - 03/25/14 10:16 AM Re: Advantages of straight weight oil [Re: Red91]
KCJeep Offline
Loc: Mahzurrah!
I do because I've done it before many years ago but I was very oil ignorant then and ran it into winter. Starts were pretty rough ha ha. I've been looking around and PYB HD30 is fairly available. So is Rotella. I also looked at the Castrol site and they say in regard to their HD 30 "for ambient temps over 40 degrees". So they seem to think HD30 is fine as long as it's 40 or above.
I am still 3-4k away from my next OCI, it will be summer then, I am torn between another fill of 10w40 PYB or a run of HD30 PYB. But I would rather have a prior run of PYB before I run the HD30 as a UOA would be more reflective of actual performance. But then I'd be getting into fall with HD30 which I don't really want to do. But a single run would not be worthless either.
Like you I am very intrigued by the higher HTHS and the stellar shear resistance.
Fram PH8A
#3322911 - 03/25/14 10:24 AM Re: Advantages of straight weight oil [Re: Now]
dlundblad Offline
Loc: Midwest
In the summer heat at least, I wonder if it would be beneficial to buy PYB HD 30 weight to use as that 6th quart or as a top off oil.
Didnt AZ have some on clearance for $5 per 5 qt jug??
2003 Grand Cherokee 4.0 PYB 10w30/ PH16
2002 Volvo S60 2.4T M1 0w40/ Mahle ox149d
#3323431 - 03/25/14 05:47 PM Re: Advantages of straight weight oil [Re: KCJeep]
Red91 Offline
I'm looking at Delo SAE30 from my local NAPA. I'd be running it in a '91 GMC Sierra with a TBI 5.7. Probably all seasons due to the fact that it's a second vehicle/beater, and it will probably not even see 500 miles a year any longer. I'm sticking with 5W-30 in the Dakota.
'15 Chevy Cruze LS
5.7 V8, Auto
#3323784 - 03/26/14 12:24 AM Re: Advantages of straight weight oil [Re: Now]
friendly_jacek Offline
Loc: southeast US
When a boating store went out of business several years ago, they had a huge clearance on marine 15W40 and 40 oils (under a buck per qt). They look like repackaged HDEO. Not being sure which is better for my boat, I typically blend them and this comes closer to the 25W40 Mercruiser specifies for the engine, LOL.
However, one time I used straight 40 only and it was a pain to drain the cold oil during late fall. The oil was ridiculously thick in ambient temps.
#3323813 - 03/26/14 03:32 AM Re: Advantages of straight weight oil [Re: dlundblad]
Shannow Offline
Loc: Oz
PYB SAE30 used to be available down here, and had become a significant part of my normal purchasing, using it in my BJ42, and J-Car wagon (before I used 25W-70 in it one winter to demonstrate that it wouldn't blow it up). The PYB had up to date "S" specs.
Alas, the only generally SAE30s that are typically available are Delvac 1330, which I tend not to use (would be all over 1630), and various lawnmower oils, which I resorted to with my E30, running a fill of Caltex mower oil (Delo 500 at the time).
Note, that in every case, the 30 was thinner at 100C than the recommended for my vehicle in the manual...but was relying on hths, not KV100.
#3323866 - 03/26/14 07:01 AM Re: Advantages of straight weight oil [Re: Shannow]
supercity Offline
Loc: Australia
RX Mono 30 should be easy enough to get. It's sold in 5L jugs
#3323931 - 03/26/14 08:05 AM Re: Advantages of straight weight oil [Re: supercity]
Ducked Offline
Loc: Taiwan
I read an article online a while ago that suggested straight weight oil offered better corrosion protection to light aircraft engines (which sit idle for long periods) because it was retained on the parts better.
Failure rates were allegedly higher with multigrades.
Since my car sits idle for long periods, that'd be a reason to use it. Its got a mixture of CPC straight 40 and Delvac 15/40 in it at the moment, but summer is just around the corner.
Can't find the article now, unfortunately.
#3323947 - 03/26/14 08:17 AM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
I ran the Delo SAE30 because I bought a butt load of it for $.99/gallon. If that deal didn't exist, I wouldn't purposely go out and buy a SAE30 when 5W30 is typically the same price and offers superior performance in most cases.
#3323955 - 03/26/14 08:25 AM Re: Advantages of straight weight oil [Re: Ducked]
Zaedock Offline
Loc: Massachusetts
Not really. I doubt you run an air cooled, opposed, dry sump engine that burns leaded av gas.
My vehicles sit for extended periods outside and 5W30 has more than been up to the task, especially if your interval extends into the winter months.
#3323958 - 03/26/14 08:26 AM Re: Advantages of straight weight oil [Re: Now]
Ducked Offline
Loc: Taiwan
#3323961 - 03/26/14 08:34 AM Re: Advantages of straight weight oil [Re: Zaedock]
Ducked Offline
Loc: Taiwan
I'm in Taiwan, but I have heard of these "winter months" of which you speak.
Re "5W30 has been more than up to the task" I could say straight 40 was more than up to the task in my Sierra, but you wouldn't know what, if anything, that meant, either.
#3323990 - 03/26/14 08:56 AM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
While SAE40 is up to the task, there is no reason to use a lubricant that thick in your location.
#3324063 - 03/26/14 10:33 AM Re: Advantages of straight weight oil [Re: Now]
KCJeep Offline
Loc: Mahzurrah!
Well PYB HD30 is available here at a bunch of locations, but I have yet to find a jug to keep the costs down. Napa does have it "on sale" for $3.59 a quart though I'd like to do better. Rotella SAE30 is available at Tractor Supply in jugs but I want to run PYB, it has been my favorite lube in the Jeep thus far.
I will look at Autozone.
Fram PH8A
#3324126 - 03/26/14 11:42 AM Re: Advantages of straight weight oil [Re: Now]
KCJeep Offline
Loc: Mahzurrah!
Okay here's a related question. Why is the TBN on PYB HD30 about 7 when the TBN on PYB 5w30 is almost 10? According to Pennzoil the HD30 still has detergents and anti wear additives, it even has the "removes up to 40% of sludge on the first change" advertising stuff on it.
Fram PH8A
#3324236 - 03/26/14 01:28 PM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
Not sure why TBN is lower compared to it's multi-weight counterpart.
The Delo SAE30 TBN from '05 is 10.1.
#3324242 - 03/26/14 01:31 PM Re: Advantages of straight weight oil [Re: dlundblad]
gfh77665 Offline
I have done that for years. I always felt it would combat the shearing that naturally occurs.
#3324453 - 03/26/14 04:36 PM Re: Advantages of straight weight oil [Re: Now]
KCJeep Offline
Loc: Mahzurrah!
I am still intrigued, found an interesting thread from '09 on straight weights.
SAE 30 BITOG thread
Fram PH8A
#3324543 - 03/26/14 06:08 PM Re: Advantages of straight weight oil [Re: KCJeep]
Red91 Offline
I figure part of being a part of this forum is a willing to experiment. smile
'15 Chevy Cruze LS
5.7 V8, Auto
#3324764 - 03/26/14 09:08 PM Re: Advantages of straight weight oil [Re: Zaedock]
Ducked Offline
Loc: Taiwan
True, though I'm not sure how those factors affect the analogy, if at all.
The difference in the oils is perhaps more relevant.
As I understand it (I havn't researched this and could easily be wrong) straight aviation lubricants for piston engines are typically of higher viscosity (eg Aeroshell range goes from 65 to 120) and non-(metallic)-detergent. These properties might reduce drain-down and increase corrosion protection relative to the automotive equivalents.
Edited by Ducked (03/26/14 09:11 PM)
#3324822 - 03/26/14 09:57 PM Re: Advantages of straight weight oil [Re: Red91]
KCJeep Offline
Loc: Mahzurrah!
This place is terrible for that I can't get in all the fiddling I want to do, it's the BITOG curse. Leaning hard towards a run of PYB HD30 for curiosity's sake though.
Fram PH8A
#3324829 - 03/26/14 10:03 PM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
Fiddling is cool. Having done the SAE30 thing, I'll be fartn' around with 5W20 in my Jeep 2.5L powered buggy this summer. I may do a build thread if there is interest.
#3324835 - 03/26/14 10:15 PM Re: Advantages of straight weight oil [Re: Ducked]
Zaedock Offline
Loc: Massachusetts
*sigh* - the analogy is that your application is completely different and not comparable to your vehicle use or the type of fuel it burns (oil is contaminated by combustion byproducts).
I have been working on engines for over 20 years. I have completed engine replacement with both rebuilt and used units. In the extreme cases, I have pulled apart engines that sat on a shelf for a decade and the inside was coated with oil. You are looking for a "protection" that is not needed. Run the recommended viscosity and enjoy your vehicle.
#3324850 - 03/26/14 10:29 PM Re: Advantages of straight weight oil [Re: Zaedock]
Red91 Offline
That will be a nice read. Always exciting to see what we come up with through experimentation.
'15 Chevy Cruze LS
5.7 V8, Auto
#3324856 - 03/26/14 10:33 PM Re: Advantages of straight weight oil [Re: Ducked]
Loc: Sequim, WA
Aviation single grade oil viscosity is on a different scale than SAE automotive oils. Divide by 2 to get the equivalent SAE viscosity. 100 = SAE 50. The multi-grades are on the SAE scale.
Ed
#3324933 - 03/27/14 01:06 AM Re: Advantages of straight weight oil [Re: Now]
Merkava_4 Offline
Loc: Clovis, CA
Straight grade oil is the real deal. Heavy duty stuff. No artificial thickeners added.
#3325189 - 03/27/14 10:15 AM Re: Advantages of straight weight oil [Re: Red91]
il_signore97 Offline
Loc: Toronto, Ontario, Canada
I've tried SAE30 in several vehicles just for kicks. Mind you, I should qualify that. I used Amsoil's fully synthetic ACD SAE30, which by nature of it's synthetic base stocks, can qualify for 10W30's cold temp pumpability. So essentially, it can be considered a VII-free, synthetic 10W30 oil that is properly categorized as an SAE30.
My impressions vs. the typical syn 0W30 or syn 5W30 that I've normally used prior to that in the particular vehicles in question... I noticed no difference whatsoever in driveability. Summer cold starts were identical as expected, and winter cold starts had a very very slightly slower cranking speed compared to the usual 0W30 (again, to be expected). No funny noises. Quiet and smooth engine running. Was looking to identify any wear metal changes in UOA, but I don't think it made any difference in that regard.
So in short, after many runs in different vehicles, I haven't felt the need to run it again. I'm not sure if there would have been long term benefits or detriments of using it. Even in my lawn and garden equipment I usually use 5W30 syn and call it a day (especially for the genset and snow blower that will be started in very cold weather - I'm not concerned about the lawnmower so much).
il_signore97
'09 Mercedes-Benz C300 Sport Calcite White 6-spd M/T
#3325287 - 03/27/14 11:44 AM Re: Advantages of straight weight oil [Re: Zaedock]
KCJeep Offline
Loc: Mahzurrah!
Of course there is interest!
My guess would be your iron will be relatively normal and your aluminum will skyrocket if you run a 5w20. The two Jeep UOA's with a 20 grade that I've seen exhibited that trend.
Fram PH8A
#3329920 - 04/01/14 05:34 AM Re: Advantages of straight weight oil [Re: edhackett]
Ducked Offline
Loc: Taiwan
Ed
Like gear oil viscosities aren't comparable with engine oil? (Never understood why they do that, but I suppose there's no one to stop them.)
Thanks. That means the analogy is closer than I thought.
(But of course not the same, because its an analogy.)
(Sigh)
#3329924 - 04/01/14 05:41 AM Re: Advantages of straight weight oil [Re: Now]
Shannow Offline
Loc: Oz
The aeros are started, and then usually run for a while, not a 2 minute jaunt down to the street.
The "advantages" of high VI don't play out in that sort of application...
#3335609 - 04/07/14 08:44 AM Re: Advantages of straight weight oil [Re: Shannow]
Ducked Offline
Loc: Taiwan
I don't do 2 minute jaunts down the street. I have a bicycle.
(It takes straight weight oil too.)
But sure, in general, aero engines have a much less demanding role than car engines, but my original point was the alleged enhanced corrosion resistance of higher viscosity straight weight oils for (aero} engines that sit idle for long periods.
Whatever the design and operational differences, I'd have thought that sitting idle is going to be rather similar in a car and an aircraft engine.
#3335617 - 04/07/14 08:53 AM Re: Advantages of straight weight oil [Re: Ducked]
Ducked Offline
Loc: Taiwan
Wandering around B+Q a while ago and noticed the following:-
OE/HDO-30 Lubricating oil, Internal Combustion Engine. Combat/Tactical Service MIL-PRF-2104E
Presumably thats a straight 30 weight oil. This was in the section that displays welding sundries and such, and I'd guess generators might spec a straight 30 oil.
I quite favor straight oils here, especially in a motorcycle, but have only used 40W (which might be rather high) because thats all I've found readily available. It wasn't expensive at 400NT a gallon, though it was only a little toy American gallon, so not as cheap as I at first thought.
Its not unusual in the UK for an oil to give its milspec on the label, but thats ALL this stuff had. Otherwise plain white plastic jerrycan, no brands/logos/pretty colours. Not B+Q's normal style at all.
Apparently made (or at least sold/packaged) by Chemical Specialist and Developments, Inc, Conroe TX 77305. I wondered if it might be fake, though you'd think B+Q would buy in enough bulk that they'd check supplier bonafides. There were a few typos on the label, but not beyond the usual run of industrial illiteracy. Health and safety stuff was a bit over the top, but that's not implausible for a US company.
Company website says they are mostly a defence contractor, (which fits) and not much else apart from "mission statements" and similar [censored].
Having checked it out a bit I went back a week or so later to get some for the "not summer", but it'd gone, and (of course) no one knew what I was talking about.
On the same shelf there were tins of Nyco Grease GN10. Looked it up. Its a general purpose AVIATION grease, made by a French company, and specified for extreme low temperature use (presumably at altitude).
I have no clue as to what it was doing on the shelf in B+Q in Taiwan.
Not important, but these little mysteries intrigue me. Stuff like this is why women find me such a fascinating conversationalist.
Edited by Ducked (04/07/14 08:57 AM)
#3335754 - 04/07/14 12:13 PM Re: Advantages of straight weight oil [Re: Now]
KCJeep Offline
Loc: Mahzurrah!
Well I was going to do a run of SAE30 this summer. Now I've been transferred at I will suddenly be extreme short tripping my Jeep. Not thinking that's the scenario for a straight weight.
I dunno maybe it'd be better?
Fram PH8A
#3335794 - 04/07/14 01:11 PM Re: Advantages of straight weight oil [Re: Now]
pavelow Offline
Loc: Orange Park, FL
Who uses straight weight oils in 2014? I can't see any use for them except for in lawnmowers and other small engines? lol
06 Pontiac GTO LS2
08 Chevy TrailBlazer SS LS2
#3335819 - 04/07/14 01:40 PM Re: Advantages of straight weight oil [Re: pavelow]
kschachn Offline
Loc: Upper Midwest
I don't even use it for them, I see no excessive consumption on M1 0W-30 so what's the point? Why make it any harder than it needs to be?
1994 BMW 530i, 206K
1996 Honda Accord, 218K
1999 Toyota Sienna, 350K
2000 Toyota ECHO, 255K
#3336039 - 04/07/14 05:08 PM Re: Advantages of straight weight oil [Re: Now]
hattaresguy Offline
Loc: CT
I used to use straight weights in lawn mowers but now even the little engines are all calling for 10w30.
Unless its for an old engine or an air compressor straight weights are obsolete.
A lot of the old timers run them in their boats but I don't see what advantage they offer over any of the modern 15w40's. Certainly not cost 15w40's are always cheaper.
Edited by hattaresguy (04/07/14 05:08 PM)
#3336160 - 04/07/14 07:00 PM Re: Advantages of straight weight oil [Re: Now]
zamadison Offline
Loc: California
I could see a straight weight oil being best in an application where an engine was run continuously for long periods of time and not shut down and restarted very often at all.
Perhaps a generator of some sort?
#3336227 - 04/07/14 08:06 PM Re: Advantages of straight weight oil [Re: Now]
kschachn Offline
Loc: Upper Midwest
Meh, I have an 8kW standby generator (Briggs twin) using 0W-30, and it runs now and then when the power fails. I really don't have to add any oil between changes which is usually twice a year.
1994 BMW 530i, 206K
#3337341 - 04/08/14 10:40 PM Re: Advantages of straight weight oil [Re: zamadison]
Ducked Offline
Loc: Taiwan
I could see straight weight oils being best in an application where they never see low temperatures (due to climate or preheat), where the oil is subject to sheer (all applications, but especially motorcycles) where the alleged high startup wear (alleged because although I've seen the numbers quoted a lot, and they are plausible, I've never seen a source for them) is less of an issue due to the above, or due to the use of a prelube system, where the engine sits idle for long periods of time, or where the inferior (?) lubrication of polymeric viscosity modifiers is an issue.
Thats potentially A LOT of applications, but I don't know what the advantages (if any) are ACTUALLY, because I've seen hardly any evidence.
Either way, it's probably out there, but I havn't seen it. A lot of it is probably secret.
Someone on here recently (I thought it was in this thread, but I can't find it) posted a response along the lines of "or do you think multigrades are just a worthless marketing ploy" as if that was inconceivable.
I don't think they're just a marketing ploy, but "worthless marketing ploy" is, in a commercial context, a contradiction, like military intelligence.
If a marketing ploy is effective, it'll be anything but worthless to the people who implement it, regardless of any technical merit.
