Hyundai filter 26300-35503 10PK for 35.40 FREE S&H
by GumbyJarvis
04/30/16 01:10 AM
Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
Fllow the DOT's
by WyrTwister
04/29/16 07:23 PM
Auto Rx?
by coopns
04/29/16 06:54 PM
Rotella for 6.0L Gasser
by Joefuskie
04/29/16 04:40 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
26 registered (bbhero, Defiant1, Atesz792, Duffyjr, Blkstanger, bdcardinal, 1 invisible), 617 Guests and 127 Spiders online.
57748 Members
66 Forums
248232 Topics
Page 6 of 8 < 1 2 3 4 5 6 7 8 >
#3322911 - 03/25/14 10:24 AM Re: Advantages of straight weight oil [Re: Now]
dlundblad Offline
Loc: Midwest
In the summer heat at least, I wonder if it would be beneficial to buy PYB HD 30 weight to use as that 6th quart or as a top off oil.
Didnt AZ have some on clearance for $5 per 5 qt jug??
2003 Jeep Grand Cherokee / 4.0 / 180k
PYB 10w40 w/ 16% 5w20 / Fram TG16
2002 Volvo S60/ 2.4t / 150k
Mobil 1 0w40 / Mahle OX 149 D
#3323431 - 03/25/14 05:47 PM Re: Advantages of straight weight oil [Re: KCJeep]
Red91 Offline
Loc: Alabama, United States
I'm looking at Delo SAE30 from my local NAPA. I'd be running it in a '91 GMC Sierra with a TBI 5.7. Probably all seasons due to the fact that it's a second vehicle/beater, and it will probably not even see 500 miles a year any longer. I'm sticking with 5W-30 in the Dakota.
'15 Chevy Cruze LS
1.8 4 Cyl, 6 Speed Auto
QSUD 5/30, STP XL Filter
'92 Buick Roadmaster Wagon
5.7 V8, Auto
QS 20/50, LMMoS2, Napa Gold Filter
#3323784 - 03/26/14 12:24 AM Re: Advantages of straight weight oil [Re: Now]
friendly_jacek Offline
Loc: southeast US
When a boating store went out of business several years ago, they had a huge clearance on marine 15W40 and 40 oils (under a buck per qt). They look like repackaged HDEO. Not being sure which is better for my boat, I typically blend them and this comes closer to the 25W40 Mercruiser specifies for the engine, LOL.
However, one time I used straight 40 only and it was a pain to drain the cold oil during late fall. The oil was ridiculously thick in ambient temps.
#3323813 - 03/26/14 03:32 AM Re: Advantages of straight weight oil [Re: dlundblad]
Shannow Online   content
Loc: Oz
PYB SAE30 used to be available down here, and had become a significant part of my normal purchasing, using it in my BJ42, and J-Car wagon (before I used 25W-70 in it one winter to demonstrate that it wouldn't blow it up). The PYB had up to date "S" specs.
Alas, the only generally SAE30s that are typically available are Delvac 1330, which I tend not to use (would be all over 1630), and various lawnmower oils, which I resorted to with my E30, running a fill of Caltex mower oil (Delo 500 at the time).
Note, that in every case, the 30 was thinner at 100C than the recommended for my vehicle in the manual...but was relying on hths, not KV100.
#3323866 - 03/26/14 07:01 AM Re: Advantages of straight weight oil [Re: Shannow]
supercity Offline
Loc: Australia
RX Mono 30 should be easy enough to get. It's sold in 5L jugs
#3323931 - 03/26/14 08:05 AM Re: Advantages of straight weight oil [Re: supercity]
Ducked Offline
Loc: Taiwan
I read an article online a while ago that suggested straight weight oil offered better corrosion protection to light aircraft engines (which sit idle for long periods) because it was retained on the parts better.
Failure rates were allegedly higher with multigrades.
Since my car sits idle for long periods, that'd be a reason to use it. Its got a mixture of CPC straight 40 and Delvac 15/40 in it at the moment, but summer is just around the corner.
Can't find the article now, unfortunately.
#3323947 - 03/26/14 08:17 AM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
I ran the Delo SAE30 because I bought a butt load of it for $.99/gallon. If that deal didn't exist, I wouldn't purposely go out and buy a SAE30 when 5W30 is typically the same price and offers superior performance in most cases.
2012 F150 Ex-cab 5.0L/2004 Malibu Maxx LT
1992 YJ "The Heep"/1994 Olds Cutlass Ciera 3.1/auto
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3323955 - 03/26/14 08:25 AM Re: Advantages of straight weight oil [Re: Ducked]
Zaedock Offline
Loc: Massachusetts
Not really. I doubt you run an air cooled, opposed, dry sump engine that burns leaded av gas.
My vehicles sit for extended periods outside and 5W30 has more than been up to the task, especially if your interval extends into the winter months.
#3323958 - 03/26/14 08:26 AM Re: Advantages of straight weight oil [Re: Now]
Ducked Offline
Loc: Taiwan
#3323961 - 03/26/14 08:34 AM Re: Advantages of straight weight oil [Re: Zaedock]
Ducked Offline
Loc: Taiwan
I'm in Taiwan, but I have heard of these "winter months" of which you speak.
Re "5W30 has been more than up to the task" I could say straight 40 was more than up to the task in my Sierra, but you wouldn't know what, if anything, that meant, either.
#3323990 - 03/26/14 08:56 AM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
While SAE40 is up to the task, there is no reason to use a lubricant that thick in your location.
#3324063 - 03/26/14 10:33 AM Re: Advantages of straight weight oil [Re: Now]
KCJeep Offline
Loc: Mahzurrah!
Well PYB HD30 is available here at a bunch of locations, but I have yet to find a jug to keep the costs down. Napa does have it "on sale" for $3.59 a quart though I'd like to do better. Rotella SAE30 is available at Tractor Supply in jugs but I want to run PYB, it has been my favorite lube in the Jeep thus far.
I will look at Autozone.
2004 Jeep Grand 4.0 @ 131k Pennzoil HM 5w30 w/ 1 qt 10w40
Fram TG8A
KIA Sedona 57k, Ford Focus 114k, Chrysler Sebring 184k, Chrysler Concorde 115k
#3324126 - 03/26/14 11:42 AM Re: Advantages of straight weight oil [Re: Now]
KCJeep Offline
Loc: Mahzurrah!
Okay here's a related question. Why is the TBN on PYB HD30 about 7 when the TBN on PYB 5w30 is almost 10? According to Pennzoil the HD30 still has detergents and anti wear additives, it even has the "removes up to 40% of sludge on the first change" advertising stuff on it.
Fram TG8A
#3324236 - 03/26/14 01:28 PM Re: Advantages of straight weight oil [Re: Now]
Zaedock Offline
Loc: Massachusetts
Not sure why TBN is lower compared to it's multi-weight counterpart.
The Delo SAE30 TBN from '05 is 10.1.
#3324242 - 03/26/14 01:31 PM Re: Advantages of straight weight oil [Re: dlundblad]
gfh77665 Offline
Loc: Southeast Texas
I have done that for years. I always felt it would combat the shearing that naturally occurs.
