Tried a quick search...was a little too cumbersome.
Anyways, these are likely easy questions.
Any DIY Impreza oil changers out there? First question is probably more general: If I ramp up the front end of the car will all the oil drain out of the pan? Or does it need to be level for a complete drain?
Second, will the ramps work (clearance) for the Impreza Sport Limited with the spoilers?
I'm not new to oil changes, but this is the first car I've had to raise. I'm coming from a 2010 Xterra OR and a 2004 Tacoma SR5/TRD before that, and I was skinny enough to slide under those without jack stands/ramps.
Thanks!
Thanks!
