Early review on 2015 Chrysler T&C
by badtlc
06/28/16 07:25 AM
New car storage
by JoelB
06/28/16 07:17 AM
How often should I change my oil.
by Greatwhite7
06/28/16 07:01 AM
'91 Mazda B2600i transfer case and trans oil?
by Jason280
06/28/16 03:59 AM
How to cut power to breaker box ?
by Merkava_4
06/28/16 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
06/28/16 01:07 AM
OK, before I lube it ...
by BrocLuno
06/28/16 12:53 AM
Toyota Japan Fluid SDS
by SXE10
06/27/16 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
06/27/16 11:25 PM
Considering a differential swap
by buck91
06/27/16 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
06/27/16 09:51 PM
Car Acronyms
by Marco620
06/27/16 09:46 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
72 registered (Benzadmiral, 69GTX, bbhero, AirgunSavant, 2015_PSD, Astro14, 9 invisible), 1375 Guests and 9 Spiders online.
58295 Members
66 Forums
250920 Topics
Page 1 of 2 1 2 >
#3316698 - 03/19/14 10:03 AM Does treating rust cause it to accelrate?
carguy996 Offline
Loc: Illinois
I have a 2002 Eclipse and the passenger rocker panel has a weld that is starting to rust. Normally I would just treat it with POR-15 but over the weekend I happened to see my old 2006 Mazda 6 that I sold in 2012. That car had a bad pinch weld on the passenger rear wheel well and dogleg that I had touched up with POR 15 in the spring of 2012. 2 years later the whole wheel arch and dogleg was a rusty mess with a hole about the size of a golf ball in the dogleg. Does trying to treat the rust cause it to accelrate? We had 1 mild winter and 1 severe winter between Spring 2012 and now. I dont want to treat the rust on the Mitsubishi if I am only going to accelrate it into a major body rot issue in the near future. Has anyone had a similar experience? I completed the 3 step clean, prep, paint process with the POR-15 on the Mazda and then top coated the POR-15 with black automotive paint.
2016 Nissan Rogue SL AWD 2.5 (M1 0w/20
2014 Honda Odyssey Touring Elite 3.5 (M1 0w/20)
2005 Chrysler Sebring Convertible 2.7 (SynPower 5w20)
#3316708 - 03/19/14 10:08 AM Re: Does treating rust cause it to accelrate? [Re: carguy996]
Turk Offline
Loc: MN
I think it does!!
Never had external rocker panel rust visible and the Winter before I sprayed Amsoil HDMP on. Drove the Sierra "just some" last Winter.
Last Spring, there was A LOT of external rust after the treatment!!
Never before! It went up exponentially.
NO WAY am I using that stuff again.
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#3316715 - 03/19/14 10:11 AM Re: Does treating rust cause it to accelrate? [Re: carguy996]
Phishin Offline
Loc: Indiana
It all depends on how you pre-treat the rust.
If you use the Phosphoric acid/Zinc oxide "pre-treatment" and keep the rust wet for several hours, it will help "kill" the rust. If you just scrape the loose stuff off and POR-15 over it, I don't see how the rust could stop.
2010 Accord-LX K24: PU 5w30
2009 Subaru Forester 2.5X: M1 TDT
1990 Chevy K1500 350TBI: Frankenbrew
2008 Ruckus 50ccGET: M1R Mix
#3316746 - 03/19/14 10:27 AM Re: Does treating rust cause it to accelrate? [Re: carguy996]
Wilhelm_D Offline
Loc: Tacoma, WA
It depends on the "treatment".
If you wind up encapsulating active rust and moisture you'll make it worse in the long run. A good example would be the "rubberized undercoating" sprayed over existing rusted areas. You'll be able to rip the coating off in a few months and find water under it.
On the other hand if eliminate the moisture and create either a strong bond impermeable barrier or a sacrificial coating of some sort, you may reduce or stop the rust.
Your description of the Mazda sounds like the POR surface-coated something that was working from the inside out. You would have been better finding the source of the moisture fueling the rust, fixing that, and then after drying it coating the inside of the wheel arch and dogleg with something along the lines of a waxy oil.
#3316782 - 03/19/14 10:48 AM Re: Does treating rust cause it to accelrate? [Re: Wilhelm_D]
expat Offline
Loc: Canada
Agree!
Edited by expat (03/19/14 10:49 AM)
#3316789 - 03/19/14 10:52 AM Re: Does treating rust cause it to accelrate? [Re: Turk]
demarpaint Offline
Loc: NY
Originally Posted By: Turk
I think it does!!
That scares me. I touched up a cleaned up small rust spot under my Buick with Amsoil HDMP in the fall. I'm going to have to take a look. My experiences with products that use some form of oil slow rust down. Maybe over the weekend if I remember I'll have a look.
God Bless Our Troops
#3316890 - 03/19/14 11:49 AM Re: Does treating rust cause it to accelrate? [Re: carguy996]
grampi Offline
Loc: OH
Once it starts it's my belief nothing will stop it...I have a couple vehicles now that have rust around the rear wheel wells...every spring and fall I grind off as much of the rust as I can get off, spray the areas with a Rustolium primer, then cover with the factory color...it of course comes back, but this at least seems to slow it down a bit...
Edited by grampi (03/19/14 11:50 AM)
#3316933 - 03/19/14 12:14 PM Re: Does treating rust cause it to accelrate? [Re: grampi]
doitmyself Offline
Loc: MI
I've had very mixed results with rust converters and if you research the internet, you will find out the same (military tests). It is not the silver bullet the marketing claims to be.
Surface rust can be stopped. Rust starting from the inside of the pinch weld seams is another story. Applying a topical treatment of POR-15 or anything to this internally started rust will just seal in the moisture and and allow the rust to continue developing.
The oil products like Krown claim that they penetrate these seams and drive/seal out the moisture and oxygen.
Moisture and salt in the red area......a topical surface treatment on the outside will not stop the rust.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#3316986 - 03/19/14 01:02 PM Re: Does treating rust cause it to accelrate? [Re: carguy996]
KrisZ Offline
Loc: Toronto, Canada
The only successful rust repair that I had good luck so far with is to repair and paint the area as usual, and then treat it with oil rustproofing compound. Preferably annually.
For hard to reach areas or just general repairs where the rust cannot be guaranteed to be 100% removed, forget POR15, rubber undercoating or any other such product. Oil or grease coating that penetrates all crevices and repels water is the only solution that is long term and cost effective. It's a perfect solution for fender well and pinch weld rust.
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#3317006 - 03/19/14 01:20 PM Re: Does treating rust cause it to accelrate? [Re: carguy996]
supton Offline
Loc: NH
Doesn't it matter how the metal was prepped initially? Seems like the better method is to use some sort of zinc underlayer, or similar. I noticed on my Jetta that initially a paint chip would leave unrusted metal. It would take a long time (like a year plus) before it would start rusting. I did some grinding on a fender, and I swear the rust on that metal is vastly worse than the rust on the hood. BUT then again the rust I'm looking at likely dries much slower than the hood.
I happened to look at the wheelwheel on my truck this weekend, and noticed rust! on the frame. I don't know if the FF dried out, washed off or I just missed it (or some combo). I think though the problem was poor paint adhesion: it was a weld point, long bead for a suspension bracket.
2011 Toyota Camry, base, 6spd manual, 116k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 126k, his
#3317082 - 03/19/14 02:33 PM Re: Does treating rust cause it to accelrate? [Re: carguy996]
carguy996 Offline
Loc: Illinois
Sounds like I would have been better off leaving the pinch weld alone versus trying to repair it on my old Mazda. I think I will just live with the bubble on the rocker, I dont want to treat it only to have no rocker panel left in the spring. Is there any successful product to use for pinch weld rust? A friend of mine has a pristine 2001 model year vehicle where the pinch weld is starting to rust on the right rear. The previous owner sprayed caliper paint over the rust. Is there a neutralizer/product that could be sprayed into the pinch weld to attempt to stop the rust or at least slow it down? This particular vehicle is way to nice to start rusting and would like to help my friend out if possible.
#3317150 - 03/19/14 03:52 PM Re: Does treating rust cause it to accelrate? [Re: carguy996]
JHZR2 Offline
Loc: New Jersey
There are different approaches.
POR 15 cures to a hard shell in the presence of moisture. However it is UV sensitive, and its only as good as its bonding and interface. There can be poor contact points where moisture can enter in and continue the oxidation.
I too have seen with HDMP the rust underneath. I believe the issue is that any place where the film is potentially peturbed, moisture can get underneath and stay trapped. Ditto for any that is under there before. And, regardless of how "self healing" it may be claimed, I have my doubts.
I personally feel that waxy coatings are only to be used in enclosed spaces, like inside door skins or inside rockers. Anyplace where there is the potential for damage should get a high tack oil, like Krown.
Applications may differ for certain things, like the cast iron suspension parts that wont necessarily rust away that bad under the car. But for sheet metal and similar components, no waxy coatings, IMO, only stuff that truly will creep and self-heal. Fluid film is an intermediate product that is likely OK too.
For the OP, I'd use a product like Krown or Carwell or corrosion x standard (HD is waxy). Both can be ordered online. These will drip, travel, and move into the rust and the weld, fully wetting the surface with the oil and inhibitor.
#3318574 - 03/20/14 10:55 PM Re: Does treating rust cause it to accelrate? [Re: JHZR2]
expat Offline
Loc: Canada
Again I agree.
I have also had success with a Wire rope lube* applied inside to pinch welds and seams.
* the type that sprays on thin to penetrate, but sets like a viscus Tar.
#3320042 - 03/22/14 06:04 PM Re: Does treating rust cause it to accelrate? [Re: carguy996]
FXjohn Offline
Loc: NE Indiana
the best you can do is slow rust down so your vehicle is all worn out before the rust gets to be a big issue. I just touch up the areas with rustoleum and krown or fluid film throughout the year and it makes a huge difference. it just doesn't get much worse. usually by the time you notice the rust, it is because sand and water are trapped in areas. when the holes appear, powerwash them clean and apply the spray paint and then the krown. most often it is wheel arches, cab corners and rocker panels
#3320067 - 03/22/14 06:19 PM Re: Does treating rust cause it to accelrate? [Re: carguy996]
SLCraig Offline
Loc: London, ON, Canada
I would treat it.. We are talking about a Mazda here, nothing else rusts as fast as a Mazda, and this is well known in areas where we get road salt.
I applied Fluid Film all over the rear fender wells of my folks car a few years ago and the rust barely got worse as long as I kept treating it every few months.
I can't imagine that not doing anything is better than at least trying.
At least keep the car washed, if nothing else.
2010 Civic SI sedan 6MT
SynPower 5w30 | Fram Ultra | Pennzoil MTF
Page 1 of 2 1 2 >
