20W-50 for a hydraulic pump in a hydrostatic trans
by ford46guy
2 minutes 37 seconds ago
new castrol edge high mileage synthetic
by hiflo
17 minutes 55 seconds ago
Just an interesting question
by southernjeeper
Today at 01:52 AM
Value power Walmart battery acid flying out
by bbhero
Today at 12:44 AM
Leased 2013 Ford Suv With19,882 Miles Original Oil
by crazyoildude
Yesterday at 10:35 PM
Steak-House Burgers
by sleddriver
Yesterday at 09:53 PM
Got into an accident.
by bdcardinal
Yesterday at 09:42 PM
Its coming here more and more
by CourierDriver
Yesterday at 08:40 PM
Interpreting oil pressure vs engine RPM
by Emperors6
Yesterday at 08:39 PM
$4 Fram Ultra - Blain's F&F
by Poohbah
Yesterday at 08:21 PM
Toolbox - Pliers
by greasegunn
Yesterday at 08:09 PM
ProSelect Oil Filter????
by qwerty1234
Yesterday at 08:05 PM
jerryg, 1971tr350, Mak712, Lex4TDI4Life, cdub76
57988 Registered Users
24 registered (Char Baby, bbhero, asand1, alcyon, cobra7279, 3 invisible), 512 Guests and 335 Spiders online.
57988 Members
66 Forums
249413 Topics
Page 2 of 2 < 1 2
#3316444 - 03/19/14 12:58 AM Re: Battery completely dead ... but at 9V? [Re: Miller88]
MNgopher Offline
Loc: Lakeville, MN
9V is way dead. Anything under 12V is pretty well dead, and you should be planning on buying a new battery. Our previous 88 Cherokee did the same thing. Left a door slightly open, lights on all night, and dead as a doornail. The battery limped on for two months, then kicked the bucket.
#3316626 - 03/19/14 08:41 AM Re: Battery completely dead ... but at 9V? [Re: Miller88]
rshaw125 Offline
Loc: Raleigh ,NC CSA
Put it on a 2 amp charge for a day. Remember the alternator is not designed to charge a dead battery. Drive it and then check voltage with engine off. Should be around 12.75 volts if fully charged.
2012 Porsche Carrera S
1995 Plymouth Voyager
#3316732 - 03/19/14 10:21 AM Re: Battery completely dead ... but at 9V? [Re: Miller88]
Vikas Offline
Loc: NorthEast
I think the guys who did that want your NEW battery!
#3316810 - 03/19/14 11:08 AM Re: Battery completely dead ... but at 9V? [Re: rshaw125]
wrcsixeight Offline
Loc: california
The vehicle in question probably has a ~75 amp hour battery.
10.5 volts is considered 100% discharged. If the battery in question were still healthy, at still near full capacity when it was drain to 9v, it would require anywhere from 110 to 125% the energy removed from it. Lets say 125%
94 amp hours 94 amp hours divided by 2 amps is 47 hours.
If the charger used does not recognize the battery because of the 9v factor, the battery should be paralleled to a known good battery and then charged until its resting voltage is high enough that the charger will recognize it..
Since the battery in question is likely has nowhere near full capacity remaining, a day at 2 amps might be enough to bring it near full charge.
If this theoretical 2 amp charger does not raise the voltage into the mid 14's it is likely it will never
LA 318 Roller Cam
M1 0w-40
M1-301 Filter
#3316937 - 03/19/14 12:21 PM Re: Battery completely dead ... but at 9V? [Re: Barkleymut]
Miller88 Offline
Loc: Onondaga County
Originally Posted By: Barkleymut
Google tells me that he is very close to Syracuse NY
Yup. I live in the city of Syracuse. A mini detroit. Per capita, we have worse crime!
Anyway, I let it until the morning. Then let it sit for a while and checked voltage. 12.6.
That's higher than what it is after the Jeep sits for a few days. I have some parasitic draw that I need to get sorted out. It'll kill a battery on its own if left for 2 or 3 weeks.
I'm going to continue charging it. I'm sure I *could* have jumped it off of the Focus, but if it's that low, I don't want to risk the 14 year old alternator.
I'm going to let it charge at 2 amps overnight again and see what happens.
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3317379 - 03/19/14 07:47 PM Re: Battery completely dead ... but at 9V? [Re: Miller88]
redbone3 Offline
Loc: Reno, NV
Originally Posted By: Miller88
Electrolyte levels are good and it didn't freeze.
Up to about 10.6 volts. I have it on the 2 amp charge. I try to avoid 6 amp charge.
6 amps won't hurt anything and it will charge faster.
2014 Passat Wolfsburg, 1995 Miata.
#3317801 - 03/20/14 07:55 AM Re: Battery completely dead ... but at 9V? [Re: Miller88]
Miller88 Offline
Let it do the 6 amp charge for 6 hours last night. Getting there! It's holding voltage higher than it does in the Jeep. Hopefully letting it run again tonight on the 6 am charge I'll be fully charged.
#3320160 - 03/22/14 07:49 PM Re: Battery completely dead ... but at 9V? [Re: Miller88]
Da Game Offline
Loc: Chicago
Here is one from Associated Equipment that will recharge a battery down as low as 1v. Thats the override switch.
http://associatedequip.com/product/model-9640/
This Interacter will charge also as low as 1v.
http://interacter.com/products/industrial-commercial-series-specs/
Both made in the USA.
Page 2 of 2 < 1 2
