Originally Posted By: lucerne06
what coolant is used in a 04 sentra? the coolant in now is green in color...and does nissan call for anything special ..like...no silicates, etc..??
The color is completely irrelevant.
Nissan, Toyota, Mazda, Honda, Hyundai, Isuzu, etc all use some version of a HOAT (hybrid organic acid technology) that is silicate free and borate free. It uses phosphate instead of silicate. It also contains no 2-EHA, which is used in - for example - Dexcool as the Asians believe it comprises elastomers and gaskets.
The only common aftermarket product is Zerex Asian Vehicle Antifreeze. However, it is a 50/50 premix with demineralized water, so using it for a full flush and fill is something of a problem.
Since they are basically all the same, you can buy any of the current Asian OEM coolants by price alone and use it in the Nissan.
