I have a 2002 Mitsubishi Eclipse, the previous owner replaced the wiring harness for both headlights and I think there might be an issue with the wiring. When the low beams are on the left headlight looks normal but the right headlight is a bright focused beam, with the highbeams on, the left headlight sppears to go to high beam and the right headlight doesnt appear to do anything. There is a black a white and a red wire on the harness. Should I switch the red and white wire to see if that fixes the issue?
Thanks!
Thanks!
