Originally Posted By: artificialist
Originally Posted By: dailydriver
Originally Posted By: antiqueshell
Most later model European cars (early 90s and afterwards) require a dedicated power steering fluid and you should NEVER use ATF unless the owner's manual specifically calls for it. One of the most common is Pentosin CHF-11S, or CHF 202, they are both correct.
Another equivalent is Febi 06161 which is the alternate supplier to most of the major manufacturers.
There is also the equivalent Ravenol P.S. fluid, but GOOD LUCK in trying to find that ANYWHERE in North America!
You might not be able to get it from stores, but you can get it from websites that specialize in European car parts. I got some Ravenol products from blauparts.com
Yes, but they carry VERY VERY little of the Ravenol line up.
I have convinced them to get a few cases of the excellent Ravenol MTF-2 for me to try in my T56 by telling them that ALL of the manual Getrags in Bimmers from '97 on spec an MTF-2 gearbox fluid.
If anyone is interested they will have it in stock by the middle-end of May.
I have not seen this Ravenol product (nor ANY others) on ANY site, save for Blauparts'.
