Seeking comments. I'm locked into electric because there are no gas lines where I live. Not really feasible to install a tank + line just to cook on.
I've seen the smooth top electric ranges and the halogen ones. Problems with scratching from pans over time? A neighbor has an electric Jenn-Air glass top. Very nice. Problem is I don't need the 'air' part as I have a true overhead vent already installed. My favorite cast iron skillet has a small ridge around the perimeter that would prevent it from sitting flat on such a top. Of course, I could fix that will a belt sander...
Induction, while expensive, sounds very effective and efficient. Most of my cookware is compatible, save for two commercial aluminum skillets. However, they're already warped from use and unfortunately, I can no longer use them. Too bad.
How do you like induction?
