Wishing for shut off and cold atf level checks-
by Lapham3
02/11/16 07:01 AM
1997 Gand Marquis
by fordman65
02/11/16 03:50 AM
Better micron rating than a 40u for a 4967/14476?
by ziggy
02/11/16 02:59 AM
Weapon Shield
by Ws6
02/11/16 12:33 AM
Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
biyogo, Jandry, BlueKelah, threeeightteen, TOADchunks
56891 Registered Users
55 registered (aquariuscsm, Atesz792, 2009Edge, B767capt, AlienBug, 04SE, 6 invisible), 839 Guests and 148 Spiders online.
56891 Members
66 Forums
244533 Topics
#3312785 - 03/15/14 02:18 PM Are all VW spec'd 507 oils compatible?
DCRamsey Offline
Loc: North Carolina
Would you guess that all VW approved 507 oils are compatible?
#3312835 - 03/15/14 03:11 PM Re: Are all VW spec'd 507 oils compatible? [Re: DCRamsey]
dparm Offline
Loc: Chicago, IL
Compatible with what? Each other? Non-507 oils?
If they're API certified, they have to be mixable with other API oils.
2011.5 BMW M3 saloon ZCP
Castrol Edge Professional TWS 10w60 + Mahle OX 254D3
#3312850 - 03/15/14 03:29 PM Re: Are all VW spec'd 507 oils compatible? [Re: DCRamsey]
AlienBug Online   content
Loc: Connecticut
No guessing involved. If the oil meets VW504/507 then they are compatible. In fact, VW considers them identical.
Don
2005 Ford Freestyle SEL, 151k, Motorcraft 5w20 synblend, Motorcraft filter
2007 Ford Fusion SE 2.3l, 118k, Mobil 1 EP 0w20, Motorcraft filter
#3312861 - 03/15/14 03:38 PM Re: Are all VW spec'd 507 oils compatible? [Re: dparm]
DCRamsey Offline
Loc: North Carolina
dparm, it didn't occur to me that my question wasn't clear. Compatible with other 507 spec'd oils. Based of the replies, I'm guessing a 507 rated oil is compatible with other brands of 507 rated oils.
#3312996 - 03/15/14 06:37 PM Re: Are all VW spec'd 507 oils compatible? [Re: DCRamsey]
dparm Offline
Loc: Chicago, IL
Yes, you can mix other 507 oils. Is it optimal? No.
