Lawnmower Won't Start When Engine Hot
by jkon
2 minutes 42 seconds ago
Rheology of Viscosity Modifiers and ULV Lubricants
by Solarent
2 minutes 55 seconds ago
Block heater leaks, Use sealant on expansion plug?
by Colt45ws
9 minutes 21 seconds ago
85 octane... Wth?
by horse123
32 minutes 33 seconds ago
Fram XG2 Bypass Valve
by Canadastang
49 minutes 22 seconds ago
'02 VW Cabrio -- Pros & cons?
by Benzadmiral
Today at 08:27 AM
Early review on 2015 Chrysler T&C
by badtlc
Today at 07:25 AM
New car storage
by JoelB
Today at 07:17 AM
How often should I change my oil.
by Greatwhite7
Today at 07:01 AM
'91 Mazda B2600i transfer case and trans oil?
by Jason280
Today at 03:59 AM
How to cut power to breaker box ?
by Merkava_4
Today at 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
Today at 01:07 AM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
86 registered (757guy, Alfred_B, ag_ghost, Al, 69GTX, 9 invisible), 1667 Guests and 8 Spiders online.
58295 Members
66 Forums
250924 Topics
#3312785 - 03/15/14 02:18 PM Are all VW spec'd 507 oils compatible?
DCRamsey Offline
Loc: North Carolina
Would you guess that all VW approved 507 oils are compatible?
#3312835 - 03/15/14 03:11 PM Re: Are all VW spec'd 507 oils compatible? [Re: DCRamsey]
dparm Offline
Loc: Chicago, IL
Compatible with what? Each other? Non-507 oils?
If they're API certified, they have to be mixable with other API oils.
2011 BMW M3 sedan ZCP
#3312850 - 03/15/14 03:29 PM Re: Are all VW spec'd 507 oils compatible? [Re: DCRamsey]
AlienBug Offline
Loc: Connecticut
No guessing involved. If the oil meets VW504/507 then they are compatible. In fact, VW considers them identical.
Don
2005 Ford Freestyle SEL, 158k, Motorcraft 5w20 synblend, Motorcraft filter
2007 Ford Fusion SE 2.3l, 125k, Mobil 1 EP 0w20, Motorcraft filter
#3312861 - 03/15/14 03:38 PM Re: Are all VW spec'd 507 oils compatible? [Re: dparm]
DCRamsey Offline
Loc: North Carolina
dparm, it didn't occur to me that my question wasn't clear. Compatible with other 507 spec'd oils. Based of the replies, I'm guessing a 507 rated oil is compatible with other brands of 507 rated oils.
#3312996 - 03/15/14 06:37 PM Re: Are all VW spec'd 507 oils compatible? [Re: DCRamsey]
dparm Offline
Loc: Chicago, IL
Yes, you can mix other 507 oils. Is it optimal? No.
