Rotella for 6.0L Gasser
by Joefuskie
Today at 04:40 PM
Pennzoil Platinum Euro 5W-40
by 1JZ_E46
Today at 04:21 PM
TGMO 0W20 7700 miles UOA
by micmac
Today at 03:45 PM
"Low Coolant" light doesn't vanish.
by OpenClose
Today at 02:07 PM
Is running "Engine flush" before a change legit?
by OpenClose
Today at 01:59 PM
Who Owns A Beater?
by Red91
Today at 01:09 PM
What prevents pics from being viewed on posts?
by daves66nova
Today at 12:42 PM
QS Filter Miles
by Yup
Today at 12:23 PM
Denso Irdium plug at 68k miles
by SHOZ
Today at 12:19 PM
Chrome bumpers from RockAuto. Good quality?
by mrsilv04
Today at 12:00 PM
Krown Rust Proofing illegal in U.S.
by Warstud
Today at 11:49 AM
fixing the t/a
by turtlevette
Today at 10:55 AM
Dmax7901, carver1, Handy7rick, sicilien, Crater_77
57738 Registered Users
92 registered (1JZ_E46, 2015_PSD, 2004tdigls, Astro14, Abakev, aquariuscsm, 8 invisible), 1707 Guests and 103 Spiders online.
57738 Members
66 Forums
248221 Topics
Page 1 of 2 1 2 >
#3312342 - 03/14/14 11:10 PM Very Dirty Ford 360 V8
dccarpenter Offline
Loc: VA
Hello,
I have a new to me '69 F350 flatbed dump with a original Ford v8 360 motor. I had a bad valve and just had the heads pulled to have them re-machined at the machine shop. When pulled the top end of the motor was extremely dirty, they are cleaning it out for me as best they can but I couldn't justify the $2,000 more to have the whole motor torn apart and rebuilt right now which is what they recommended (they recommended it not because they noticed any malfunction with the bottom end just because of the volume of sludge on the top end).
What kind of, if any, flushes or additives should I try to get this thing cleaned out some more? I'm willing to change the oil every 500 - 1000 miles or more if necessary as this truck probably won't see more than 1 day of use per week and a total monthly milage of 200-800.
#3312354 - 03/14/14 11:31 PM Re: Very Dirty Ford 360 V8 [Re: dccarpenter]
Chris142 Offline
Loc: apple valley, ca
Those fe's are always dirty under the valve covers.probly from years of se and sf oils. Ot: what was ford thinking when they designed that intake manifold?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3312364 - 03/14/14 11:45 PM Re: Very Dirty Ford 360 V8 [Re: dccarpenter]
crazyoildude Offline
Loc: New Jersey
valves burnt because of no lead in fuel ?
those engines ran no matter what
#3312374 - 03/15/14 12:14 AM Re: Very Dirty Ford 360 V8 [Re: dccarpenter]
DSparks Offline
Loc: Texas
If the motor is already back together with clean heads and the lifter valley still nasty there really isnt much you can do....I personally wouldnt run a flush unless you plan on pulling the pan and cleaning it and clean/replace the oil pump pickup/screen fairly soon thereafter...those flushes can be pretty nasty on the sludge and can do more harm than good and end up plugging up the pickup tube/screen...or leave it as is..drive it...sludge stays put..cross your fingers...change oil little more often....just my opinion....
#3312386 - 03/15/14 12:35 AM Re: Very Dirty Ford 360 V8 [Re: dccarpenter]
mattwithcats Offline
Loc: Virginia
Rotella T6 or Mobil1 Turbo Diesel
5W-40
Change the filter each time, and run only 500 miles first change, 1000 next, then by the owners manual...
Keep an eye on the oil pressure, oil pickup screen may need changing...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40
Purolator Synthetic PSL 14610
175/55R15 tires...
#3312429 - 03/15/14 02:26 AM Re: Very Dirty Ford 360 V8 [Re: dccarpenter]
rockydee Offline
Loc: VA
Your favorite oil with a 1 qt.MMO chaser for the win. Two project cars, some other misc uses over the years , and a POS my daughter bought when she moved out west for a job opportunity made me a believer.
#3312470 - 03/15/14 06:59 AM Re: Very Dirty Ford 360 V8 [Re: dccarpenter]
Oil Changer Offline
Loc: Michigan
You should justify the extra 2K. It will cost you that and more to do this again. Is this truck used professionally? How much revenue will you lose to more downtime?
#3312487 - 03/15/14 07:30 AM Re: Very Dirty Ford 360 V8 [Re: rockydee]
GreeCguy Offline
Loc: Elderly County, Florida
Ditto.
There's two routes you can go in my opinion. Drop the pan and clean the bottom end of the motor including removing the oil pump and pick up screen, (you might even want to replace the pump while you're down there). Or, do a series of quick oil changes as stated above, (substitute one quart MMO for one quart oil). Change the filter with each oil change as well.
DO NOT use anything like "Gunk 5 Minute flush." Flushes like that are mostly kerosene or diesel fuel and they will dislodge chunks of sludge and clog your oil system leading to engine failure. I've seen it happen too often.
"Dyslexics are teople poo!!."
#3312500 - 03/15/14 07:44 AM Re: Very Dirty Ford 360 V8 [Re: rockydee]
dave5358 Offline
Loc: North Bend
+1. Run it with this mix for a thousand or so miles. Then drain the oil while the engine is very hot, and let it drain for an hour or so. Change the filter.
After that, just change the oil and filter regularly and use good oil.
2006 Forester XT
2008 Corolla LE
#3312518 - 03/15/14 08:15 AM Re: Very Dirty Ford 360 V8 [Re: dave5358]
DuckRyder Offline
Loc: Atlanta
If the heads are still off it wouldn't be a bad idea to restrict the rocker feed passages. Holley jets work and I wouldn't go any smaller than a 90 with stock rockers, but FE's pump a good bit of oil to the top end and the drain back isn't great.
As for cleaning, you can pull the pan with the engine in the truck, although I actually think it is easier to just pull the engine and that could help, but other than that I would not fret a lot about it and certainly not risk breaking lose any chunks. FEs will stand an incredible amount of abuse and still run fine.
If you do pull the pan, you might want to pick up an uprated oil pump drive shaft, the stock ones are not great.
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
  • 2012 Volkswagen Jetta TDi
#3312520 - 03/15/14 08:19 AM Re: Very Dirty Ford 360 V8 [Re: dccarpenter]
The_Eric Offline
Loc: Iowa
The best flush you'll ever buy, is to remove the oil pan and dig in...
Clean the lifter valley while the heads are away at the machine shop and remove the pan and clean that too. As GreeCguy said, pull the oil pump and pick up tube and clean/replace the assembly.
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#3312530 - 03/15/14 08:32 AM Re: Very Dirty Ford 360 V8 [Re: dccarpenter]
Shaman Offline
Loc: Frankfort, Kentucky
If the motor is on a stand right now, some kerosene in the oil pan and let it sit. It should dislodge stuff, and it would probably be a good time to do the oil pan gasket anyway. If not, disregard and do something like mentioned above.
#3312537 - 03/15/14 08:53 AM Re: Very Dirty Ford 360 V8 [Re: dccarpenter]
andyd Offline
Loc: Marshfield , MA
Yah, Here's the reality check. Either tear the engine down before putting it into use. Or nurse it along. Be aware that removing sludge may open clearances. I used to work for a guy who had a very basic Dodge D 300 with a dump bed. The worst part of the truck was the wheezy 318. But the entire truck had been gone through even though we just used it as mobile dumpster Check the brake lines to prevent unnecessary adventures. It is a 45 yr old Ford truck. You are going to have one thing mess up after another if you put this truck even into limited service.This is a DIYer's kind of truck. The 2 year/24,000 mile guaranty has expired. It wasn't intended to exist in the 21st century. Best of luck. thumbsup
Edited by andyd (03/15/14 09:00 AM)
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3312550 - 03/15/14 09:11 AM Re: Very Dirty Ford 360 V8 [Re: andyd]
dccarpenter Offline
Loc: VA
Thanks for the advice all, I've dropped the pan with engine in on several of my other trucks and while unpleasant it was doable so I don't mind doing that on this one if needed.
I'll give the MMO a shot with 750 mile changes for a bit.
The truck has either 115k or 215k miles on it, any recommendation on oil?
As for it being a DIY truck, that's why I got it. For a truck that will see once a week or once every two week duty I wasn't buying new. Maintaining one of these old warhorses is dirt simple and the parts are cheap. If the engine dies I can always just buy a 460 crate motor and get another 150k miles from it. I already repaired all the minimal rust, dump bed PTO works great, 6 new 10 ply tires on it, put in new exhaust, new belts, pertronix instead of points.
#3312565 - 03/15/14 09:29 AM Re: Very Dirty Ford 360 V8 [Re: dccarpenter]
Oil Changer Offline
Loc: Michigan
We ran SAE30 in ours on job sites that would make most of the BITOG populous faint. That was in SoCal and the engines would run from the time we arrived until the time we left. I can't ever remember changing the oil in them, just top off and maybe a filter (Wix) swap every year or two.
I would suggest T5 or 6.
P.S. I'll take heat for this but thinking flushes and additives are going to help is laughable.
Edited by Oil Changer (03/15/14 09:30 AM)
Page 1 of 2 1 2 >
