Oil filtration and circulation question
by Doublehaul
13 minutes 26 seconds ago
Anyone ever replaced brake fluid on Honda Pilot?
by Islandvic
35 minutes 16 seconds ago
Unused WIX 51372-051815C2 cut & post
by WellOiled
Today at 08:37 PM
-31 this morning...without the wind chill!
by Doublehaul
Today at 08:00 PM
Cleaning Throttle body, necessary service now?
by Colt45ws
Today at 07:33 PM
[Cut Open] Ford OE (FL500S equivalent) 4948mi
by DuckRyder
Today at 07:20 PM
[Cut Open] Fram XG3600 - 9098mi
by DuckRyder
Today at 07:16 PM
T rated General Altimax tires on 2012 Corolla?
by Corollaman
Today at 07:00 PM
Best container to store tools underground ?
by Merkava_4
Today at 06:45 PM
ESET antivirus - 3 years for $20
by greenjp
Today at 06:00 PM
Fram Ultra XG9972 11k Miles
by SF0059
Today at 06:00 PM
Antonin Scalia is dead
by skyactiv
Today at 05:04 PM
Formula413, Cruzingoose, klob, beaglefet, bsmith3
56907 Registered Users
103 registered (2015_PSD, ammolab, andyd, AlienBug, anonobomber, 90crvtec, 12 invisible), 1263 Guests and 106 Spiders online.
56907 Members
66 Forums
244664 Topics
#3312258 - 03/14/14 09:38 PM Castrol Edge 10w-60, 14k,'09 BMW M3
brian_fantana Offline
Loc: WA
I know my lead is high at 18. I'm hoping my switch to castrol 0w40 will improve my lead count. Other M3 drivers have switched to a 0w40 oil and cut their lead levels in half. I'm going to pull a sample at 5k and see if my numbers improve.
Code:
Oil Castrol      10w-60
Miles in use     14k
Miles            42k
Sample Taken     3/14/14
ALUMINUM	7
CHROMIUM	0
IRON	        11
COPPER          4
LEAD	        18
TIN	        0
MOLYBDENUM	150
NICKEL       	0
MANGANESE	1
SILVER        	0
TITANIUM        29
POTASSIUM	2
BORON     	28
SILICON     	5
SODIUM      	5
CALCIUM    	2480
MAGNESIUM	176
PHOSPHORUS	786
ZINC         	922
BARIUM     	0
SUS Viscosity @ 210F	91.6
cSt Viscosity @ 100C	18.37
Flashpoint in F	415
Fuel %	                <0.5
Antifreeze %	         0.0
Water %	                 0.0
Insolubles %	         0.1
TBN	                 2.5
#3312263 - 03/14/14 09:41 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
dparm Offline
Loc: Chicago, IL
When you say Castrol Edge 10w60, which one are you talking about? There's Castrol Edge Sport and Castrol Edge Professional TWS.
2011.5 BMW M3 saloon ZCP
Castrol Edge Professional TWS 10w60 + Mahle OX 254D3
#3312280 - 03/14/14 10:02 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: dparm]
Loc: WA
Edge professional. I may need to edit that for clarity.
'09 E90 M3 DCT
Castrol Edge 10w60
#3312285 - 03/14/14 10:04 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
147_Grain Offline
Loc: USA
That 10W-60 is one thick oil to use over the winter months. Agree that a 0W-40 is more appropriate to help you "get the lead out".
#3312308 - 03/14/14 10:30 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
HTSS_TR Offline
Loc: Lake Forest, CA
Thicker oil doesn't mean it protects the engine better than correct grade(thinner oil)
'94 Lexus LS400
'00 MB E430
'04 Honda S2000
'06 Volvo V70
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3312341 - 03/14/14 11:10 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
jigen Offline
Loc: Pennsylvania
Was any make-up oil added? How long was the oil in use?
'14 Mazda6 0w20 Pennzoil Platinum
'14 Focus ST 5w30 Castrol Edge Extended
'15 Grand Caravan 5w20 Factory Fill
#3312383 - 03/15/14 12:28 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: HTSS_TR]
jaj Offline
Loc: Vancouver, Canada
Castrol Edge or TWS 10w-60 is the only "correct" oil for this engine.
#3312385 - 03/15/14 12:35 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: jigen]
Loc: WA
Yes, I added 2qts of 10w60 edge pro in 14k.
'09 E90 M3 DCT
Castrol Edge 10w60
#3312390 - 03/15/14 12:39 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
901Memphis Offline
Loc: Northern Kentucky
18 lead ain't too bad. What about Mobil 1 0W40?
2002 Buick Century 118k - Built 4T65e - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317
#3312407 - 03/15/14 01:26 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: 901Memphis]
Loc: WA
Probably a better oil from all I've read than castrol. To be honest I bought off on "designed for BMW" castrol advertises and feeling a bit of remorse after reading more comps. after I pulled the trigger. Just really hoping to cut those lead levels in half or more.
'09 E90 M3 DCT
Castrol Edge 10w60
#3312448 - 03/15/14 05:07 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
Gokhan Offline
Loc: Los Angeles, California
Interesting that high viscosity caused higher bearing wear -- opposite of what you would think. I wonder if that was because the oil flow was insufficient due to high viscosity.
Could it also be that OCI was too long and TAN got to high, causing bearing corrosion? TAN increase is strongly correlated with lead corrosion and wear. I emphasize that TBN alone is fairly useless to determine used-oil condition and both TBN and TAN are needed. Unfortunately Blackstone misleads people to believe that knowledge of TBN is sufficient.
Here is some previous discussion. See the Chevron/Oronite reference linked there as well:
TBN, TAN, Ca, Mg, base-oil quality, oil life
1985 Toyota Corolla LE, 4A-LC engine, ~ 263,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3312546 - 03/15/14 09:10 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: jaj]
dparm Offline
Loc: Chicago, IL
In North America, BMW now allows LL-01 oils in the S65. Many of us have switched to Mobil 1 0w40.
#3313070 - 03/15/14 08:13 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
Gokhan Offline
I can't imagine any modern gasoline road engine requiring anything thicker than M1 0W-40 SN, which has 3.8 cP HTHSV.
#3313586 - 03/16/14 11:51 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: dparm]
nickolas84 Offline
Loc: Greece
Make that, LL-01 is the only correct oil for this engine.
#3348633 - 04/20/14 10:01 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
Jtgrant Offline
Loc: GA
If you aren't tracking this car a lot with really high oil temps, the Mobil1 0w-40 is a great alternative. Even if you track the car with the Mobil1 0w-40 it is still a great choice. I would also recommend using the Mobil1 15w-50, especially when you can catch the Mobil1 on sale. I'm a BMW Master Tech, the S65 engine is extremely reliable mechanically. The only issues we really see is the low pressure fuel sensor failures, idle actuators and throttles failing. Other than that, they are really well made engines. It is crazy how bad our non M V8s are compared to the Motorsport V8 engines. The S62 and S65 are the best production V8s BMW has ever made. I really do not like seeing that the new generation M3/M4's will have turbo charged Inline 6 engines. Don't get me wrong I love inline 6 BMW engines, but we all know BMW has a lot of issues with turbo chargers and our High pressure fuel systems.
