new HDM part number for lacrosse headlamp recall
by lucerne06
19 minutes 35 seconds ago
snapper blade control is stiff
by edwardh1
23 minutes 21 seconds ago
is my extension cord bad?
by motor_oil_madman
34 minutes 39 seconds ago
Done with Sandisk USB Sticks
by JHZR2
47 minutes 16 seconds ago
Pineapple Margaritas
by sleddriver
55 minutes 30 seconds ago
Replacing Drywall In The Bathroom (Insulation)
by Warstud
Today at 07:56 PM
351W build with a flat tappet
by ssregal39
Today at 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
Today at 07:12 PM
Car's models of 1990 and now
by HTSS_TR
Today at 07:02 PM
Another dealer oil change story
by mclasser
Today at 06:36 PM
Diagnosing HEI ignition module and ignition system
by Fsharp
Today at 05:58 PM
Spark such way?
by yvon_la
Today at 05:48 PM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
100 registered (AIRJAC3, 2015_PSD, 4WD, 69GTX, 74DartSport, 04SE, 7 invisible), 1567 Guests and 137 Spiders online.
58023 Members
66 Forums
249614 Topics
#3312258 - 03/14/14 09:38 PM Castrol Edge 10w-60, 14k,'09 BMW M3
brian_fantana Offline
Loc: WA
I know my lead is high at 18. I'm hoping my switch to castrol 0w40 will improve my lead count. Other M3 drivers have switched to a 0w40 oil and cut their lead levels in half. I'm going to pull a sample at 5k and see if my numbers improve.
Code:
Oil Castrol      10w-60
Miles in use     14k
Miles            42k
Sample Taken     3/14/14
ALUMINUM	7
CHROMIUM	0
IRON	        11
COPPER          4
LEAD	        18
TIN	        0
MOLYBDENUM	150
NICKEL       	0
MANGANESE	1
SILVER        	0
TITANIUM        29
POTASSIUM	2
BORON     	28
SILICON     	5
SODIUM      	5
CALCIUM    	2480
MAGNESIUM	176
PHOSPHORUS	786
ZINC         	922
BARIUM     	0
SUS Viscosity @ 210F	91.6
cSt Viscosity @ 100C	18.37
Flashpoint in F	415
Fuel %	                <0.5
Antifreeze %	         0.0
Water %	                 0.0
Insolubles %	         0.1
TBN	                 2.5
#3312263 - 03/14/14 09:41 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
dparm Offline
Loc: Chicago, IL
When you say Castrol Edge 10w60, which one are you talking about? There's Castrol Edge Sport and Castrol Edge Professional TWS.
2011 BMW M3 sedan ZCP
#3312280 - 03/14/14 10:02 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: dparm]
Loc: WA
Edge professional. I may need to edit that for clarity.
'09 E90 M3 DCT
Castrol Edge 10w60
#3312285 - 03/14/14 10:04 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
147_Grain Offline
Loc: USA
That 10W-60 is one thick oil to use over the winter months. Agree that a 0W-40 is more appropriate to help you "get the lead out".
#3312308 - 03/14/14 10:30 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
HTSS_TR Online   content
Loc: Lake Forest, CA
Thicker oil doesn't mean it protects the engine better than correct grade(thinner oil)
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3312341 - 03/14/14 11:10 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
jigen Offline
Loc: Pennsylvania
Was any make-up oil added? How long was the oil in use?
'14 Mazda6 0w20 Pennzoil Platinum
'14 Focus ST 5w30 Castrol Edge Extended
'15 Grand Caravan 5w20 Castrol Edge
#3312383 - 03/15/14 12:28 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: HTSS_TR]
jaj Offline
Loc: Vancouver, Canada
Castrol Edge or TWS 10w-60 is the only "correct" oil for this engine.
#3312385 - 03/15/14 12:35 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: jigen]
Loc: WA
Yes, I added 2qts of 10w60 edge pro in 14k.
'09 E90 M3 DCT
Castrol Edge 10w60
#3312390 - 03/15/14 12:39 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
901Memphis Offline
Loc: Northern Kentucky
18 lead ain't too bad. What about Mobil 1 0W40?
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3312407 - 03/15/14 01:26 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: 901Memphis]
Loc: WA
Probably a better oil from all I've read than castrol. To be honest I bought off on "designed for BMW" castrol advertises and feeling a bit of remorse after reading more comps. after I pulled the trigger. Just really hoping to cut those lead levels in half or more.
'09 E90 M3 DCT
Castrol Edge 10w60
#3312448 - 03/15/14 05:07 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
Gokhan Offline
Loc: Los Angeles, California
Interesting that high viscosity caused higher bearing wear -- opposite of what you would think. I wonder if that was because the oil flow was insufficient due to high viscosity.
Could it also be that OCI was too long and TAN got to high, causing bearing corrosion? TAN increase is strongly correlated with lead corrosion and wear. I emphasize that TBN alone is fairly useless to determine used-oil condition and both TBN and TAN are needed. Unfortunately Blackstone misleads people to believe that knowledge of TBN is sufficient.
Here is some previous discussion. See the Chevron/Oronite reference linked there as well:
TBN, TAN, Ca, Mg, base-oil quality, oil life
1985 Toyota Corolla LE, 4A-LC engine, ~ 263,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3312546 - 03/15/14 09:10 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: jaj]
dparm Offline
Loc: Chicago, IL
In North America, BMW now allows LL-01 oils in the S65. Many of us have switched to Mobil 1 0w40.
#3313070 - 03/15/14 08:13 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
Gokhan Offline
I can't imagine any modern gasoline road engine requiring anything thicker than M1 0W-40 SN, which has 3.8 cP HTHSV.
#3313586 - 03/16/14 11:51 AM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: dparm]
nickolas84 Offline
Loc: Greece
Make that, LL-01 is the only correct oil for this engine.
#3348633 - 04/20/14 10:01 PM Re: Catrol Edge 10w-60, 14k,'09 BMW M3 [Re: brian_fantana]
Jtgrant Offline
Loc: GA
If you aren't tracking this car a lot with really high oil temps, the Mobil1 0w-40 is a great alternative. Even if you track the car with the Mobil1 0w-40 it is still a great choice. I would also recommend using the Mobil1 15w-50, especially when you can catch the Mobil1 on sale. I'm a BMW Master Tech, the S65 engine is extremely reliable mechanically. The only issues we really see is the low pressure fuel sensor failures, idle actuators and throttles failing. Other than that, they are really well made engines. It is crazy how bad our non M V8s are compared to the Motorsport V8 engines. The S62 and S65 are the best production V8s BMW has ever made. I really do not like seeing that the new generation M3/M4's will have turbo charged Inline 6 engines. Don't get me wrong I love inline 6 BMW engines, but we all know BMW has a lot of issues with turbo chargers and our High pressure fuel systems.
