Saved a puppy
by barkingspider
08/24/16 10:39 PM
Slick 50
by CrackyWainwright
08/24/16 09:28 PM
Bmw twin power 5w30
by BTLew81
08/24/16 09:08 PM
Older car but low mileage. Change or not?
by Martin10
08/24/16 08:07 PM
F1 - 2016 Belgian Grand Prix
by gofast182
08/24/16 07:55 PM
Ethernet card uograde needed?
by NHHEMI
08/24/16 07:27 PM
2012 Suzuki DL1000 VStrom Oil Recommendations
by RHALL
08/24/16 07:24 PM
Audio/Micro Adapter Help
by coopns
08/24/16 07:18 PM
Purolator boss 2222 6,200 miles
by gabriel9766
08/24/16 06:49 PM
Fram Ultra paint peeling
by Run
08/24/16 06:26 PM
Cell phone mount suction cup doesn't stick
by mclasser
08/24/16 06:02 PM
2008 Nissa Versa 110,000 miles second report.
by Datarock
08/24/16 05:07 PM
ShadowSix, warfire, Brutus232, gojoneeded, jimmyangst
58911 Registered Users
56 registered (Americana, 79sunrunner, AZjeff, AntsinmyEyes, 29662, 5 invisible), 1242 Guests and 7 Spiders online.
58911 Members
66 Forums
253515 Topics
Page 1 of 2 1 2 >
#3312232 - 03/14/14 09:22 PM Long pedal travel after brake line replacement?
faramir9 Offline
Loc: PA
So, the brake line (not the whole line, but a good portion of it) on my 14-year-old Saturn rusted to the point it needed to be replaced to pass inspection---not to mention safety.
Local shop installed new brake lines, transferred fluids, car passed inspection, etc. Good job---but now the brake pedal travels farther before stopping power engages. I noticed this straight away, and at first put it down to the usual adjustment period with new brakes. It has not gotten better after three days, though, so I start to worry.
I am pretty sure it is not simply air in the lines. I know what that feels like. This is just....farther pedal travel. The stopping power is perfectly fine, once it engages, but it takes longer to engage.
My plan is to take it back to the shop on Saturday to see what they think. First thing is to check for air and bleed the lines, if needed, I would think---but as noted I don't think that's the issue.
Is this something I should worry about, or am I crazy? (Or both?)
Thanks.
2000 Saturn SL1, 1.9 SOHC
Pennzoil HM 5w-30, TF-335 filter
Nokian WRG3 185/65R14
#3312250 - 03/14/14 09:33 PM Re: Long pedal travel after brake line replacement? [Re: faramir9]
expat Offline
Loc: Canada
I'm thinking the rear brakes need adjustment (if they have been disturbed)
Try pulling the hand brake on and off multiple times.
#3312255 - 03/14/14 09:36 PM Re: Long pedal travel after brake line replacement? [Re: faramir9]
901Memphis Offline
Loc: Northern Kentucky
Does it have ABS? Those ABS boxes can be tricky to bleed.
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3312264 - 03/14/14 09:41 PM Re: Long pedal travel after brake line replacement? [Re: 901Memphis]
faramir9 Offline
Loc: PA
No ABS. Rear drums. I read on SaturnFans that 3rd-gen S-series require a specific method to bleed the brakes, different from the earlier S-series cars. Not sure I understood that one---but I will mention it to the guys at the shop.
#3312265 - 03/14/14 09:42 PM Re: Long pedal travel after brake line replacement? [Re: expat]
faramir9 Offline
Loc: PA
Will try it. Thanks.
#3312286 - 03/14/14 10:05 PM Re: Long pedal travel after brake line replacement? [Re: faramir9]
Donald Offline
Loc: Upstate NY
Backing up and applying the brakes should adjust it.
But the place that did your brakes should have adjusted the rear brakes.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3312291 - 03/14/14 10:11 PM Re: Long pedal travel after brake line replacement? [Re: faramir9]
eljefino Offline
Loc: ME
They messed it up. Make 'em get on it.
Have a backup plan to leave the car there. Lots of rusty bleeders and other issues. They could have seen a rusty bleeder and said, naaaah, not touching that. frown
#3312301 - 03/14/14 10:21 PM Re: Long pedal travel after brake line replacement? [Re: faramir9]
mene Offline
Loc: winter park, Fl.
Thanks.
Rear brake drums need adjustment that's all, find the specific way for your car in a Saturn forum, many work with the handbrake like it was said, others backing up also recommended, others just adjust every time you apply the brakes, the adjustments are usually very little per stroke so you might have to pull that parking brake 20 times, "no joking" or reverse and brake "hard" 20 times, but to be honest the brake shop should have adjusted the brakes, my concern is that if they did that job that way Who will make sure they do it properly this time?
1984 Dodge Caravan. 461K miles (replaced by the 2000, body rusted badly)
2004 Chrysler Town & Country. 131K miles
2000 dodge caravan 2.4L 214K. miles
#3312319 - 03/14/14 10:38 PM Re: Long pedal travel after brake line replacement? [Re: faramir9]
JHZR2 Offline
Loc: New Jersey
Air bubble left in there???
#3312358 - 03/14/14 11:36 PM Re: Long pedal travel after brake line replacement? [Re: JHZR2]
Doog Offline
Loc: North Coast
Your brake system may have an electric proportioning valve/pump in the system for the rear wheels. But first adjust the rear brakes. Then if you have the electric valve bleed the rear brakes with the ignition key in the on position and see if that does it.
The difference between a beer and your opinion is that I asked for a beer... well except for just now..Coffee2
#3312498 - 03/15/14 07:42 AM Re: Long pedal travel after brake line replacement? [Re: faramir9]
asand1 Offline
Loc: Oregon coast
Air in the lines still.
Nissan/Infinity/Mazda Manuals
1996 Maxima 310K
1998 F250ld
#3312553 - 03/15/14 09:16 AM Re: Long pedal travel after brake line replacement? [Re: faramir9]
2009Edge Offline
Loc: Texas
Could it be a master cylinder problem?
#3312633 - 03/15/14 11:01 AM Re: Long pedal travel after brake line replacement? [Re: faramir9]
Sierra048 Offline
Loc: Georgia
Thanks.
I did a complete brake job on my old 2002 Toyota Tundra with front disc and rear drums. I had the same problem. I had already done a brake fluid flush and there was no air in the lines. I thought I had done a thorough job of re-installing the new rear brake shoes so I was really confused. For me, as it turns out, it was a simple matter of readjusting the rear brakes since I didn't adjust them as good as I thought I had. Everything was fine after readjustment.
2014 Nissan Frontier
2014 GMC Sierra 1500
#3312651 - 03/15/14 11:28 AM Re: Long pedal travel after brake line replacement? [Re: faramir9]
eljefino Offline
Loc: ME
The rear drums on these turn into a rusty mess and there's no good rim flange to hammer them off. Your mechanic was lazy. Someone needs to pull the drums and look around inside.
These cars don't have electric prop valves or anything fancy. The adjusters freeze all the time. Not sure if the hand brake or backing up clicks them.
But where things felt good going in and worse coming out, it seems like a hydraulic issue. They could have gorked the master cylinder by pumping all the way down to the floor bleeding your lines and having the piston seal go into "uncharted territory." They could still have air in the lines. Whatever, if you have faith in this shop have them fix it. If you don't, get your money back.
#3312914 - 03/15/14 04:44 PM Re: Long pedal travel after brake line replacement? [Re: eljefino]
faramir9 Offline
Loc: PA
Thanks for all the advice. Today I planned to take the car back to the shop to have them check it, but got tired of sitting in stopped traffic and turned around instead. (Woulda been 15-20 minutes for a less-than-2-mile trip.)
On the way home I made a few hard stops, though not from high speed. When I got home and parked, I applied and released the parking brake more than a dozen times, then stomped on the brake pedal a few more times.
That helped some. It's better now than it was before, anyway. The pedal feels firmer, if you know what I mean. I plan a repeat treatment on Sunday; if that does not improve things still more, I will take it to the shop on Monday....but it looks like the rear brakes just needed to be 'pumped' and adjusted.
Been there, done that with many new brake jobs, (pads, rotors, shoes) over the years---but upon reflection this is the first time I had brake lines replaced outright in heap long time. Live and learn.
Page 1 of 2 1 2 >
