1991 Sierra rear brake squeel
by sr17
33 minutes 37 seconds ago
2015 Silverado Diff Fluid Change
by Realtech214
Today at 12:25 AM
Undercarriage Rust Management
by OpenClose
Yesterday at 11:31 PM
New used tires
by gfh77665
Yesterday at 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
Yesterday at 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
Yesterday at 10:54 PM
What Ohm antenna wire to use?
by daves66nova
Yesterday at 10:46 PM
Turtle Wax Passed The Test
by RevRider
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
Yesterday at 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
Yesterday at 10:13 PM
If you liked the Fram AirHog Filters
by rrounds
Yesterday at 10:07 PM
Most advanced oil on the shelf?
by Jetstreamz06
Yesterday at 09:41 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
27 registered (csx7006, bbhero, bdcardinal, Farmer, Gasbuggy, alcyon, 2 invisible), 634 Guests and 321 Spiders online.
57996 Members
66 Forums
249469 Topics
#3309564 - 03/12/14 03:44 PM pt cruiser using some oil
ram_man Offline
Loc: southern mo
Our cruiser seems to be using some oil when the dealer did the oil change it was filled half way up the safe range and it almost 1800 miles it's used Down to the add line. So half a quart in that time. I'm not overly worried being a saturn owner I understand some cars just do it. However if there is a way to fix it im all for it. Is there anything that could be causing this? Any common issues on these engines that cause consumption? Thanks everyone.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3309573 - 03/12/14 03:52 PM Re: pt cruiser using some oil [Re: ram_man]
Olas Offline
Loc: Manchester, England
Its either leaking oil or burning oil, try topping up with maxlife to see if that slows it down, if not, either fix it or pay someone else to!
smile
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3309580 - 03/12/14 03:57 PM Re: pt cruiser using some oil [Re: ram_man]
earlyre Offline
Loc: Lima, Ohio, USA
kind of... they have a slightly wonky PCV setup, that under the right conditions(WOT, Hard/Fast right turns, etc) can let liquid oil(not just vapors) out of the crankcase, and back to the intake.
very common for folks to add a catch can in the PCV line on Neons/PT's, esp if it's a Turbo.
Mine:
09 Mercury Sable : 6qts QSAD 5w20,WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts QSAD 5w30,WIX 51394
#3309596 - 03/12/14 04:14 PM Re: pt cruiser using some oil [Re: earlyre]
ram_man Offline
Loc: southern mo
The pcv valve is different than most I've dealt with to.
I don't think there is anything serious wrong. But maybe a pcv ? Didn't some have a tsb for a thing under the valve cover I forget the name some type of baffle that caused oil usage
#3309628 - 03/12/14 04:44 PM Re: pt cruiser using some oil [Re: ram_man]
mrsilv04 Offline
Loc: Illinois
For some odd reason, if the dealer switched to a different brand of oil, an engine will use more on that first change.
Don't ask me to explain it, but I've seen this myself when I switch brands of oil.
Whatever you do... do NOT speed through the town of Gauley Bridge, WV.
#3309646 - 03/12/14 05:02 PM Re: pt cruiser using some oil [Re: ram_man]
tomcat27 Offline
Loc: Midwest
My 96 Sebring with the 2.4 has always used a little oil. Maybe a quart every 2000-3000 miles. It did it new. It does it now with
200,000 miles.
2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1995 Jeep ZJ, 1970 Cougar, 2010 Vstar, 1989 Radian
#3309756 - 03/12/14 06:52 PM Re: pt cruiser using some oil [Re: ram_man]
gregk24 Offline
Loc: FL, USA
If its manageable just add oil when necessary. If it gets worse, start using a HM oil like Maxlife.
2012 Honda Accord EX-L
Taffeta White - Ivory
38,xxx miles
PPPP 0w20 / Fram Ultra
#3311149 - 03/13/14 09:40 PM Re: pt cruiser using some oil [Re: ram_man]
artificialist Offline
Loc: Florida
I help a friend with a 2004 Chrysler PT Cruiser, and his car always consumed oil. I replaced the PCV valve, and used 10w40 synthetic oil, and it made no difference.
That is so irritating! Many engines didn't consume oil years before this car was built.
2010 Lancer Ralliart Sportback
#3311540 - 03/14/14 09:21 AM Re: pt cruiser using some oil [Re: ram_man]
KitaCam Offline
Loc: SunnySouthFlorida
Why only half-way to F....? Why not all the way to F....?
1800 for a half-qt isn't bad at all...more than ideal, yes, but 3600 for a full quart might be just fine, depending on use and mileage on the car...
Edited by KitaCam (03/14/14 09:22 AM)
Kitacam is an 05 Camry LE/I4/MT; 3/16 @ 137,000....MaxLife Syn Blend 5w-30...with P1 filter
#3312029 - 03/14/14 05:03 PM Re: pt cruiser using some oil [Re: ram_man]
ram_man Offline
Loc: southern mo
The pcv was less than stellar so I replaced it also I forgot the dealer replaced the oil pressure switch. They may have lost some oil doing that job.
