Hello folks,
I have 2006 Nissan Sentra 1.8S Special Edition, with 923xx on odometer. I just got 90K inspection done and the mechanic suggested following things. I bought this car used when it had 72K on odometer and the past records are sketchy. He mentioned that the brake fluid is black (I don't know what color it should be), but he did not make any comments on other fluids (but they are suggested in service manual).
- Transmission Fluid flush (Estimate, including fluid - $140)
- Flush Brake system (Estimate-$90)
- Cooling System Flush (Estimate-$130)
- BG Fuel/Air Induction Service (Estimate-$140)
I have no idea on either of this stuff. Can you guys please help me figure out if I really need do this?
I read about Fuel/Air Induction service in the old threads, and noticed that nobody recommended it. (FWIW, I have used Techron twice in last 2 years.)
Service manual also suggests to replace oil at every 3000 miles, but I have read widely that you don't need it. I change it every 5000 or so miles. Hence this question.
Many thanks in advance.
