My Faith Has Been Restored
by bobbob
07/28/16 02:57 AM
Kohler Courage 15
by Commeres
07/28/16 02:13 AM
Windstar 2001 AC Low and High pressure reading
by pinjc
07/27/16 09:28 PM
Vacuum Pump Oil for rotary vane pumps.
by bunnspecial
07/27/16 09:22 PM
ST dino oil realistic OCI
by OILGEEK27
07/27/16 09:06 PM
Gas grills
by RN89
07/27/16 08:43 PM
Supercharged Subaru BRZ
by clinebarger
07/27/16 07:52 PM
Side can opener ?
by ST2008
07/27/16 07:48 PM
Pennsoil ULTRA not available
by JXW
07/27/16 07:41 PM
2005 Civic randomly stalls when taking off from a
by Avery4
07/27/16 07:36 PM
2003 Saturn L200 oil choice
by car51
07/27/16 07:30 PM
Good hour meter for small engines?
by motor_oil_madman
07/27/16 07:07 PM
donsladek, rummy, OILGEEK27, pinjc, Lee_C
58627 Registered Users
20 registered (bbhero, Chewie, Blokey, AnthemBassMan, DeanLutz72, 1 invisible), 806 Guests and 13 Spiders online.
58627 Members
66 Forums
252341 Topics
Page 2 of 2 < 1 2
#3311682 - 03/14/14 11:17 AM Re: Gas coming out of tank while filling [Re: Tom NJ]
hsd Offline
Loc: NE
The charcoal canister can not cause overflow during filling as it only functions when the system is sealed up (gas cap is installed).
#3311978 - 03/14/14 04:14 PM Re: Gas coming out of tank while filling [Re: Tom NJ]
1 FMF Offline
Loc: CT
when i had the back of my 2006 gmc sierra apart, i found that there's a valve in the filler neck of the fuel tank that's spring loaded and stays shut unless a force acts from outside to push it inward, such as fuel when filling. the purpose of it is to prevent fuel from coming out in case of a rollover. i believe all gas tanks have this, and also makes it nearly impossible to siphon gas out of the tank because it will block any hose from making it through. my guess is that valve is sticking or not opening all the way preventing any significant volume of fuel from entering the tank quickly. otherwise everything else is sealed, the evap canister and purge valves are always closed unless commanded open by the pcm. your vent for when filling the tank is a separate small hose that runs alongside the big fill hose and goes to the filler neck thing up on the body where your gas cap is. if you look where you insert the gas pump into that fill neck, there will be a separate small hole there, that's the vent which works when filling the tank because the gas cap is off. but when the gas cap is on then the fuel system is completely sealed.
Edited by 1 FMF (03/14/14 04:16 PM)
#3311989 - 03/14/14 04:22 PM Re: Gas coming out of tank while filling [Re: Tom NJ]
1 FMF Offline
Loc: CT
also gas with ethanol is quite a solvent, also attracts water, and over time can dry out that plastic valve and make it stick or corrode/rust the metal spring. using some kind of oil, like marvel mystery oil, which you can run with little problem in the fuel, shoot that down the fill neck every now and then to coat that anti-siphon valve and it may get better. otherwise if it's integrated into the plastic tank then you're looking at a new fuel tank.
but don't dump a pint of mmo down the fill neck just before filling up with gas and wash all the mmo down, that'll defeat the purpose.
Page 2 of 2 < 1 2
