Manual says every 10 K on oil changes
by ceast
05/03/16 02:42 PM
Brake fluid ageing?
by LucasDK
05/03/16 02:39 PM
If Anybody has 60K Lying around
by GumbyJarvis
05/03/16 02:03 PM
144$ lot of 48 Fl-400s/L20195 Eq Filters
by GumbyJarvis
05/03/16 01:29 PM
AT Whine
by DWC28
05/03/16 01:14 PM
GM AutoTrak II fluid
by nthach
05/03/16 12:49 PM
GM 2500HD 75w-90 or 75w-110
by Stewart Fan
05/03/16 12:03 PM
tire question
by Durango
05/03/16 12:02 PM
Winter's Over, Time to Start Next Year's Firewood
by doitmyself
05/03/16 11:54 AM
Heard of Hemi Tick- is there "Hemi Shudder"?
by JennyHemi
05/03/16 11:07 AM
Lost my mind, about to buy Genesis Coupe 3.8
by FutureDoc
05/03/16 10:27 AM
Tire Sizing Help
by coopns
05/03/16 10:23 AM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
95 registered (2010Civic, Al, 69GTX, 2009Edge, 901Memphis, 01rangerxl, 14 invisible), 1986 Guests and 241 Spiders online.
57779 Members
66 Forums
248413 Topics
Page 1 of 3 1 2 3 >
#3311517 - 03/14/14 09:01 AM body shop repaint vs factory?
flinter Offline
Loc: New Jersey
Hi,
When one has to have a body panel repainted at a top quality auto body shop, is that new
paint the exact same quality as the factory paint?
I ask this because I read that once a car is repainted, it's not of the same quality and
durability as the factory and is more prone to chips and cracking, no matter how skilled
the body shop is.
2015 Honda Civic EX sedan, Urban Titanium
Purchased with 4 miles on odometer
#3311521 - 03/14/14 09:04 AM Re: body shop repaint vs factory? [Re: flinter]
rockydee Offline
Loc: VA
Depends on the shop, and the paint they use. There are some awesome painters out there, that do better work than factory new.
#3311526 - 03/14/14 09:08 AM Re: body shop repaint vs factory? [Re: flinter]
flinter Offline
Loc: New Jersey
Ok, I ask because I recently had my front bumper repainted on my new 2013 Honda Civic due to a shopping cart big scratch. Its looked beautiful at first and the paint matched perfectly. This
was done is early December and I notice I already have several chips in the paint.
This was done by a AAA approved, very well respected shop in my town.
#3311528 - 03/14/14 09:11 AM Re: body shop repaint vs factory? [Re: flinter]
rockydee Offline
Loc: VA
Prep is everything, if they didn't prep it right it might look good and not last. Like I said it depends. Take her back, as long as it wasn't hit which might crack the job they should redo it. If they don't you'll know what kind of shop they run.
#3311529 - 03/14/14 09:11 AM Re: body shop repaint vs factory? [Re: flinter]
dparm Offline
Loc: Chicago, IL
Most good body shops will do a better job than OEM, in my experience.
2011 BMW M3 sedan ZCP
#3311551 - 03/14/14 09:33 AM Re: body shop repaint vs factory? [Re: flinter]
tightwad Offline
Loc: Texas
Factory paint is different from aftermarket paint in that it is formulated to be baked at very high temperature after application, which is not possible after the car is assembled. I agree that the body shop can do a much better job on an individual car than the factory can do on an assembly line. The body shop job can look much, much better, but I don't think it will have the long-term durability of a factory finish.
2007 Caddy DTS/Havoline Synth 5w-30/Mobil-1 O/F
1983 El Camino/Havoline 5w-30/ACDelco(non-E-core)
1956 Packard/Delo 15w-40/Wix
#3311553 - 03/14/14 09:38 AM Re: body shop repaint vs factory? [Re: flinter]
Texican Offline
Loc: Texas
I've worked in the auto collision industry for 15 years, a quality shop can do a better looking job than the factory. As far as chips go, they are going to happen no matter what factory or re paint. The factory paint is a little more resistant to them because the paint at the factory is baked on at over 600 degrees and is fully cured. A body shop can not produce that kind if heat in there paint booths and if they could most if the interior would melt. The re paint is softer but will eventually completely cure out. As to the remark about a shop be a quality shop just because they are a preferred shop for a insurance is a false statement. They are a preferred shop because they fix the car however the insurance tells them to, which is always the cheapest way possible. The shop goes along with this because the insurance will always funnel work to there shop.
Edited by Texican (03/14/14 09:39 AM)
2015 Kia Forte 5 2.0 GDI QS Synblend 5W30 and OEM filter
2015 Kia Optima 2.4 GDI Factory Fill
Troy Bilt w/Honda GVC 160 1/2 QSGB & 1/2 QS synblend
#3311563 - 03/14/14 09:45 AM Re: body shop repaint vs factory? [Re: flinter]
gofast182 Offline
Loc: NJ
If I understand correctly, in addition to the baking process, body shops may also use a different brand of paint/clear than the OE does. It could be PPG, BASF, DuPont, etc. Each having a different hardness characteristic than the other.
2006 S2000 - Berlina Black - PU 10w30, PCX-004
2015 TLX V6 Tech - Graphite Luster - Dlr Fill, PLM-A02
2011 MDX Tech - Aspen White - Dlr Fill, PLM-A01
#3311585 - 03/14/14 10:06 AM Re: body shop repaint vs factory? [Re: gofast182]
Texican Offline
Loc: Texas
Correct, the shops do use different brands of paint from the factory in some cases, there has been times in the past when a paint company forms a relationship with a factory just like the oil company's do. Also when it comes to color the factory had over 200 different tints to make there colors, as with aftermarket paints like PPG and others they only have around 60-70 tints to work with. That's why some colors are harder to match than others.
#3311619 - 03/14/14 10:24 AM Re: body shop repaint vs factory? [Re: flinter]
flinter Offline
Loc: New Jersey
Texican, thanks for your expertise on this.
#3311620 - 03/14/14 10:26 AM Re: body shop repaint vs factory? [Re: flinter]
NHGUY Offline
Loc: USA
Paint that chips off plastic is an indicator of lack of prep,lack of plastic/flex primers/and lack of flex agents in the paint/clear.Some bodyshops are in a hurry to cycle thru and cut many corners.A paintjob is only as good as the painter/body shop.A down n dirty job wont hold up.Cant blame the paint when that happens.
#3311628 - 03/14/14 10:32 AM Re: body shop repaint vs factory? [Re: flinter]
The Critic Offline
Loc: Walnut Creek, CA
I've found that I can easily spot most aftermarket repaints due to the inability to full match the OEM orange peel texture. And body shops tend to leave sanding pigtails, horrific buffer holograms, etc.
As far as the quality of aftermarket refinishing, the aftermarket is generally not able to cure the paint at the same temperatures as the factory. qwertydude can comment more specifically on this, as he can explain how the aftermarket finishes are inferior to the OEM finish in terms of the UV inhibitors.
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#3311633 - 03/14/14 10:35 AM Re: body shop repaint vs factory? [Re: Texican]
rockydee Offline
Loc: VA
So true, so very true.
#3311634 - 03/14/14 10:35 AM Re: body shop repaint vs factory? [Re: flinter]
440Magnum Offline
Loc: Texas
Factory paint is interesting these days. Its come a long way from the problems factories had back in the 90s changing to more environmentally friendly paint processes. It would be almost impossible to top most factory paint in terms of adhesion and rust protection, but the finish is mediocre at best even on high-end cars (except insane high-end things that are still hand-assembled). Everything is robot-sprayed, and even though the coverage and adhesion are superb, orange-peel to some degree or another seems to be the standard these days. A competent body and paint shop can do FAR better than the factory in terms of appearance- getting that "one inch thick" look with a perfectly smooth surface is easier now than ever with the base/clear process and then finish blocking and polishing the clear.
Its funny how peoples' standards have changed, too. A few Lexus, Cadillac, and Benz factory paint jobs might look "perfect" until you walk around a few well-done re-paints where a lot of care has been taken on the final block/polish.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3311693 - 03/14/14 11:26 AM Re: body shop repaint vs factory? [Re: flinter]
rjundi Offline
Loc: USA
Robots paint your vehicle in perfect conditions with a computer making sure it precisely is done.
Humans do after work in conditions set by humans.
Choose your shop wisely.
I always wondered on my WRX(purchased brand new) why one panel looked slightly off. I found at sale time(90k/9years latter) it was repaired before sold in a vehicle history I dug up for next buyer. The shop who did work is known for really high quality work locally.
Page 1 of 3 1 2 3 >
