microGreen Memorial Day Sale
by DBMaster
30 minutes 29 seconds ago
Biomed Tech internship - Osceola, FL
by Mr Nice
42 minutes 41 seconds ago
New Car - First OCI Subaru Outback
by Oldswagon
Today at 02:43 PM
using many cans of crc intake cleaner good?
by ziggy
Today at 02:37 PM
Mazda's RX Vision with rotary engine won't happen
by HTSS_TR
Today at 01:45 PM
Oil shearing vs fuel dilution
by Popsy
Today at 01:31 PM
Told SiriusXM to Pound Sand
by Garak
Today at 01:22 PM
CB install '98 F250ld
by asand1
Today at 12:53 PM
Kohler K532 Engine John Deere 400
by Bighorn2500
Today at 12:41 PM
Champion C165 cut open, 9000km
by turboseize
Today at 12:30 PM
F1 - 2016 Monaco Grand Prix
by gofast182
Today at 11:39 AM
Mazda 3 drain and fill
by jay929
Today at 11:38 AM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
82 registered (2010Civic, another Todd, 2009Edge, 97f150, asand1, 7 invisible), 1979 Guests and 352 Spiders online.
57973 Members
66 Forums
249394 Topics
#3309881 - 03/12/14 08:41 PM bolt help needed, Caliper bolts for front brakes
EvanD Offline
Loc: well traveled
I am going for a brake job project. Completely replacing the front brakes on my grand prix GTP.
I am upgrading to f-body brakes calipers, rotors and brembo pads. I got almost everything in the mail so far.
I am missing the bolts from the spindles to the brake brackets.
I need 2002 camaro brake bolts
Anyone have any help as to the thread pitch size grade bolt??
Where to purchase online???
Edited by evandostert (03/12/14 08:42 PM)
Silverado SS Driving this one till the wheels fall off currently 200K mods=about every bolt on possible
2001 gtp pace car 40k miles work beater
#3309886 - 03/12/14 08:43 PM Re: bolt help needed, Caliper bolts for front brakes [Re: EvanD]
Chris142 Offline
Loc: apple valley, ca
Autozone or napa?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3309888 - 03/12/14 08:46 PM Re: bolt help needed, Caliper bolts for front brakes [Re: EvanD]
Chris142 Offline
The st oil worked well in my 62 pete. Last i heard the nt280b was still haulin dirt
87 F250 delo 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#3309890 - 03/12/14 08:46 PM Re: bolt help needed, Caliper bolts for front brakes [Re: EvanD]
EvanD Offline
Loc: well traveled
the only had the bolts from caliper to bracket. I need spindle to bracket
#3309898 - 03/12/14 08:51 PM Re: bolt help needed, Caliper bolts for front brakes [Re: EvanD]
cknight49090 Offline
Loc: south haven mi
Join the grand prix forum all the info is there.I believe you have to retap what you have to 14mm but that's off the top of my head.You have 12 mm now and need 14mm they have some direct fit bolts but I don't know the part number.Before you had to use spacers.
Edited by cknight49090 (03/12/14 08:55 PM)
#3309907 - 03/12/14 09:01 PM Re: bolt help needed, Caliper bolts for front brakes [Re: EvanD]
Trav Offline
Loc: MA, Mittelfranken.de
I have done this upgrade a few times on my own cars. The OEM bolts for the original bracket are M14x2, the Camero uses M12x1.75.
Some of these kits want you to use a 14mm to 12mm bushings. Just drill and tap the F body bracket which is identical and has the same amount of meat as the W body for the original W body M14 bolts.
You will need a drill press, a good 12mm drill and a quality M14x2 tap. Easy job, torque the M14 bolts to IIRC 135lb (check that number).
Also look at 2" longer front lines, the OEM will work but they can be tight.
#3309944 - 03/12/14 09:43 PM Re: bolt help needed, Caliper bolts for front brakes [Re: Trav]
Trav Offline
I should have said identical in measurement. If you look at the W and F body bracket you will see the identical mounting bosses with enough material on the F body to enlarge the holes without going thinner at the mounts than the original.
#3309984 - 03/12/14 10:15 PM Re: bolt help needed, Caliper bolts for front brakes [Re: EvanD]
JHZR2 Offline
Loc: New Jersey
Usually those bolts are replacement items, no?
#3310055 - 03/12/14 11:19 PM Re: bolt help needed, Caliper bolts for front brakes [Re: JHZR2]
Trav Offline
Yes and no. He is putting Camaro brakes on a Grand Prix.
The spindle on the GP has 14 mm holes in it and the caliper bracket is threaded for M14
The Camero uses 12 mm holes and M12 bolts which would be sloppy in the GP spindle.
You can buy M12 bolts and use a 14mm to 12mm reducer so you can use the 12mm bolts.
Both the M14 and M12 bolts are readily available from any GM dealer.
IMHO its a lot easier just to drill and tap the holes in the bracket. This allows the use of the original size bolts and the correct torque for the M14 bolts that came with the car.
#3310653 - 03/13/14 01:25 PM Re: bolt help needed, Caliper bolts for front brakes [Re: EvanD]
EvanD Offline
Loc: well traveled
Yes the bolts are thread size M12x1.75 not sure of length they have 40, 60,80mm all avail on amazon need grade 12.9
I hate tapping holes. I am just a weekend mechanic. So I would rather just use the sleeves.
I already have sleeves. Just need bolts and brake banjo fittings. I hate shopping would much rather troll the internet for parts. I usually save $$$$ too.
Edited by evandostert (03/13/14 01:25 PM)
#3310667 - 03/13/14 01:38 PM Re: bolt help needed, Caliper bolts for front brakes [Re: EvanD]
Trav Offline
M14 X 2 X 41 is the original
You need M12x1.75x41. 40mm should be fine.
Edited by Trav (03/13/14 01:39 PM)
#3311109 - 03/13/14 09:15 PM Re: bolt help needed, Caliper bolts for front brakes [Re: EvanD]
EvanD Offline
Loc: well traveled
http://arp-bolts.com/kits/ARPkit-detail-b.php?RecordID=2978
So far found these but can not find exact grade or bolt. I don't trust grade 8 for brakes.
#3311395 - 03/14/14 06:38 AM Re: bolt help needed, Caliper bolts for front brakes [Re: EvanD]
Trav Offline
You could always just buy 2001 F body bolts from an online GM dealer or give the brackets to a machine shop, spend the same money and use the originals from the GP.
Figure $5-6 a hole.
