Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
Troy Bilt Pony
by OSUFan86
02/10/16 06:43 PM
$1.33 for a GALLON of 87!
by Vern_in_IL
02/10/16 06:30 PM
Eating out, beware you all
by CourierDriver
02/10/16 06:13 PM
Best Sponge For Washing Cars
by George7941
02/10/16 06:08 PM
BlueKelah, threeeightteen, TOADchunks, Longo9596, Roadrunner77z
56889 Registered Users
49 registered (akela, Astro14, bdcardinal, Ben Boyle, 87sammy, bbhero, 5 invisible), 756 Guests and 191 Spiders online.
56889 Members
66 Forums
244530 Topics
Page 2 of 2 < 1 2
#3309369 - 03/12/14 12:34 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: andrewjoelpeters]
cptbarkey Offline
Loc: texas
good luck, i started on a similar path of hobby repairs and it has been very satisfying.
#3309682 - 03/12/14 05:39 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: andrewjoelpeters]
eljefino Offline
Loc: ME
I don't think you have to go as deep as the head gaskets.
If the cylinder walls are rusty, you're going to pop the pistons out the top anyway, scuffing in the process. So you might as well scuff the pistons by trying to turn it over.
I would do the timing belt though and cam cover/ oil pan gaskets. Probably a distributor o-ring of some sort.
I bet the junkyard owner is tickled. "Someday my ship will come in and I'm gonna sell that tercel motor..."
#3309765 - 03/12/14 06:57 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: expat]
TFB1 Offline
Loc: VA
Originally Posted By: expat
Originally Posted By: Propflux01
I would check carb first. Then fill with oil and spin it over and see what it does. If you get pressure then give it a source of fuel and try to start it. If it runs, then you can spend $$ on seals and gaskets
You might end up using the carb from your old Oil Burner.
Agreed, I'd swap and then maybe try the orig after the engine is running properly... More than likely though, I'd rebuild it before I tried it...
As others mentioned replace/swap anything with rubber, if it has a mechanical fuel pump I wouldn't trust it as old diaphragms often rupture, that'll dump the crankcase full of gas and ruin a good engine in short order...
#3310013 - 03/12/14 10:31 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: eljefino]
andrewjoelpeters Offline
Loc: NM
I think you're probably right! At first he saw my out of state area code and told me he wasn't interested in shipping it because he likes to deal in person, but when I told him I'm actually nearby, it sounded like he was getting pretty excited.
Originally Posted By: TFB1
...if it has a mechanical fuel pump I wouldn't trust it as old diaphragms often rupture, that'll dump the crankcase full of gas and ruin a good engine in short order...
To the best of my knowledge 1st generation Tercels had an in-take fuel pump--would there be second one mounted to the engine itself?
#3311139 - 03/13/14 09:33 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: andrewjoelpeters]
artificialist Offline
Loc: Florida
Valve seals on Tercels were weak. Replacing them now makes perfect sense. I worked on a carb'd 1989 Tercel, and the camshaft driven fuel pump had to replaced. Typically you see a cam driven fuel pump on a carb engine but there are exceptions. It isn't common, but some carb engines do have an in tank pump.
I suggest replacing the water pump. The bearings might seize.
I am sure that your engine has a maze of vacuum hoses, since it is a carb engine with smog devices. You probably need to replace all of them, unfortunately, most plastic parts connected those hoses will crack.
2010 Lancer Ralliart Sportback
#3311204 - 03/13/14 10:19 PM Re: Junkyard Engine Cleanup -- Gaskets? [Re: andrewjoelpeters]
morris Offline
Loc: ks, wichita
while its out in the open pop the old freeze plugs and replace with brass. and do a back yard clean out of the water jackets.
Page 2 of 2 < 1 2
