2016 Camaro SS 5W-30 vs 5W-40
by mbar1
05/27/16 10:42 AM
Nissan Sentras
by Peakboy91
05/27/16 10:27 AM
ACDelco 75W-90 Syn Axle Lube, 13.7k mi OCI, 34k mi
by Emperors6
05/27/16 10:10 AM
Flux core welding wire
by Trotter
05/27/16 10:07 AM
Traveling Vietnam War Memorial in central Texas!!
by sasilverbullet
05/27/16 10:02 AM
What happened to Anco wiper blades
by grampi
05/27/16 07:21 AM
Full brand oil filter
by RRLJR
05/27/16 05:31 AM
Half Price GTX 15W-40 @ REPCO in Oz
by SR5
05/27/16 03:27 AM
1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
85 registered (adamrc, 66chevelle, ARCOgraphite, 901Memphis, Andrei, 69GTX, 5 invisible), 1789 Guests and 311 Spiders online.
57996 Members
66 Forums
249477 Topics
#3311031 - 03/13/14 08:14 PM Remote Diagnosis: Hard to turn in one direction
Vikas Offline
Loc: NorthEast
Maxima 2000 approx 200K miles; Out of blue I got call today that my son noticed it is very hard to turn to right and also makes "bird chirping" noises when turning right. After warm up, it was fine. To be fair, it has been unseasonably cold today and it was quite a swing in the temperature as of yesterday.
These vehicles are known to blow the high pressure hose and this vehicle is at least 100K miles over the normal life of that hose! But the reservoir level is fine and there is no leak that he can see or no puddle under the vehicle. That rules out the usual culprit.
I asked him to take it to mechanic and put it up on the lift. I can't see apart from an actual fault in rack and pinion ($$$$$$$) anything else that could lead to this behavior. Besides, most rack and pinion faults do end up in loss of fluid and ample evidence where it becomes obvious that rack needs to be replaced. I am also asking him to get the power steering system flushed.
#3311049 - 03/13/14 08:33 PM Re: Remote Diagnosis: Hard to turn in one direction [Re: Vikas]
Chris142 Offline
Loc: apple valley, ca
We used to call that morning sickness
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3311065 - 03/13/14 08:48 PM Re: Remote Diagnosis: Hard to turn in one direction [Re: Vikas]
Vikas Offline
Loc: NorthEast
But only one side?
#3311094 - 03/13/14 09:07 PM Re: Remote Diagnosis: Hard to turn in one direction [Re: Vikas]
Chris142 Offline
Yep
87 F250 delo 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#3311108 - 03/13/14 09:14 PM Re: Remote Diagnosis: Hard to turn in one direction [Re: Vikas]
Kruse Offline
Loc: Kansas
My mom had one on an 80s-something GM car that acted similar. GM cars of that era were notorious for the morning sickness that has been mentioned. There were some remanufacturers that actually resleeved the units they rebuilt.
Anyway, a new rack on her car fixed it.
#3311116 - 03/13/14 09:17 PM Re: Remote Diagnosis: Hard to turn in one direction [Re: Kruse]
spasm3 Offline
Loc: out there
Early cieras would do this, an internal leak in the rack and pinion. I fought this for a while until i just could not turn the wheel in freezing weather on a 86 model. New rack and pinion fixed it.
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#3311127 - 03/13/14 09:25 PM Re: Remote Diagnosis: Hard to turn in one direction [Re: Vikas]
artificialist Offline
Loc: Florida
You will need a replacement rack and pinion. Do not get the cheap rebuilds that are sprayed carelessly with black paint. You will have to replace it 1 year. I don't know if Nissan has reman PS racks, but if they do, I would choose that.
2010 Lancer Ralliart Sportback
#3311378 - 03/14/14 06:02 AM Re: Remote Diagnosis: Hard to turn in one direction [Re: Vikas]
Pop_Rivit Offline
Loc: Midwest
A couple minutes of research would tell you that it's most likely the steering rack. When the seals are getting old it starts to get hard to steer in one direction or "notchy". It normally gets progressively worse.
#3311384 - 03/14/14 06:10 AM Re: Remote Diagnosis: Hard to turn in one direction [Re: Vikas]
Trav Offline
Loc: MA, Mittelfranken.de
Sounds like the rack has given up the ghost.
#3311547 - 03/14/14 09:28 AM Re: Remote Diagnosis: Hard to turn in one direction [Re: Vikas]
Vikas Offline
Loc: NorthEast
Is there any snake oil worth trying in this case or too late? Surprisingly, I don't think there was any warning i.e. did not seem to have come on progressively.
Any seal rejuvenators such as ATP-205 or high mileage power steering fluid worth a try or would it make it worse?
The Maxima forum does not show power steering rack failure as a common problem on this model.
Edited by Vikas (03/14/14 09:29 AM)
#3311615 - 03/14/14 10:23 AM Re: Remote Diagnosis: Hard to turn in one direction [Re: Vikas]
Vikas Offline
Loc: NorthEast
I know many of you hate ScottyKilmer and his unorthodox repair methods but some of his wild claims have been validated by others. I also discovered q-bond through his video and that stuff was absolutely amazing for fixing plastics. So I do tend to trust ScottyKilmer more than some of you guys. He recommends Seafoam TransTune for cleaning the power steering rack and I might try this as a last ditch effort before getting rid of the car.
#3312037 - 03/14/14 05:16 PM Re: Remote Diagnosis: Hard to turn in one direction [Re: Vikas]
Trav Offline
Lubegurd PS additive may be worth a try.
