Back in 1990 I bought a new Dodge W250 Diesel it was everything I could have hoped for and NEVER disappointed me. It always did what I asked of it, never failed me. I loved that truck but it had 1 issue that bothered me.
After taking a corner the steering would not return to center, I had to physically straighten the wheels.
I tried several different greases with no luck.
I then read a Mobil Brochure about their industrial greases.
One grease that caught my attention had Moly in it. It was recommended by Cat for loader pins & bushings and was said to reduce steering effort in vehicles with kingpins.
I ordered a case and after greasing the front end the steering would return to center on its own.
I have used Moly fortified grease for everything since then.
That truck moved loads that at the time were unheard of for a 3/4 ton. I grossed 22,000lbs (certified scale) pulling a 5th wheel with a load of stone up our mountain at times very concerned that my goose neck trailer was going to stretch & fail. Never did that again.
I still have the trucks running gear with the original u-joints in the rear driveshaft. They are still smooth & tight after 250,000 miles.
I would highly recommend grease with Moly!!
Ducati996
