BW-44-44 Transfer Case special fluid
by -SyN-
11 minutes 16 seconds ago
mini inspection camera for androi phone
by bmwjohn
24 minutes 4 seconds ago
Cause of noisey serpentine belt
by 007
50 minutes 48 seconds ago
Purolator Boss 14610 C and p
by bbhero
Today at 01:33 PM
Ear hair - remove, ignore, trim ???
by Mr Nice
Today at 01:04 PM
Best Oil for [censored] Intek 19 HP Mower
by beadvised
Today at 12:43 PM
by bbhero
Today at 12:42 PM
Was the original Mobil 1 a Straight 20?
by Gene K
Today at 12:23 PM
Valvoline Maxlife 0w20 Synth blend?
by HKPolice
Today at 12:11 PM
Walmart Canada (GTA) Valvoline MaxLife 0w20 $18.88
by HKPolice
Today at 11:49 AM
Makita B04510 Palm Sander - Fix?
by user52165
Today at 11:41 AM
Red Arrows
by Whitewolf
Today at 11:20 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
79 registered (86cutlass307, -SyN-, 360kid, 69GTX, 007, 2015_PSD, 10 invisible), 2012 Guests and 11 Spiders online.
58257 Members
66 Forums
250798 Topics
#3310448 - 03/13/14 10:55 AM wd 40
waltywalt Offline
Loc: ny
When I was a kid I would spray my entire bike after washing it. The bikes never rusted. Im wondering if that would be a good idea for the car before winter. Now im not saying spray the glass and sensitive areas but a good coating under the car cant hurt right.
#3310462 - 03/13/14 11:11 AM Re: wd 40 [Re: waltywalt]
shDK Offline
Loc: Denmark
Being partly a rust remover. Ain,t wd40 containing acid? I would think a spray of thin wax spray would be better
#3310464 - 03/13/14 11:12 AM Re: wd 40 [Re: waltywalt]
Donald Offline
Loc: Upstate NY
There are better things to spray on the underbody of the vehicle. Not sure where you are in NY. I suggest you go to Dolgerville or Buffalo (I think) and have you car sprayed with Carwell or buy some and spray it yourself.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3310472 - 03/13/14 11:19 AM Re: wd 40 [Re: waltywalt]
waltywalt Offline
Loc: ny
Dutchess county ny Donald. I see u say a product called carwell. what is it and were can I get it if I chose to use it
#3310582 - 03/13/14 12:32 PM Re: wd 40 [Re: waltywalt]
SatinSilver Offline
Loc: Ohio
redhat on here is located around buffalo and had his cars sprayed. Hopefully, he will chime in or send him a pm. Fluid Film is another good one.
2012 Toyota Camry 62k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 103k miles- MC 0w20 syn-blend, MC filter
#3310621 - 03/13/14 01:04 PM Re: wd 40 [Re: waltywalt]
Boomer Offline
Loc: Pennsylvania
I have sprayed the frames of my pickups (three Chevys and now a Nissan) since 1988 with WD-40. I never had any real rust on the frames or cross members even though I lived in PA and drove on heavily salted roads. Now keep in mind my frames had a coating of scmutz on them that was factory applied and the WD-40 soaked into this material. On a bare painted frame I doubt it would do much at all.
On bare painted metal like the control arms, I always applied a coating of grease when I lubed the ball joints. Since my Nissan has sealed joints, I have not been as regular about this and at 7 years, I notice some surface rust forming on the lower surfaces.
2003 Saturn L 300 128,200 miles
2013 VW Passat TDI SE, 31,600 miles
2014 VW Jetta TDI SportWagen 17,300 miles
#3310706 - 03/13/14 02:37 PM Re: wd 40 [Re: waltywalt]
Donald Offline
Loc: Upstate NY
I lived in Dutchess when I worked for IBM in POK. Now in Columbia County.
CarWell is on the web, just Google them. Were it me, I would drive to Dolgerville some Saturday morning in the spring and have them spray your car for $100. Watch them and then do the under body yourself from then on. They have long wands to spray in body cavities which probably only need to be done once. I believe the place sells CarWell product also.
I have gone there in the spring for the past 2 years and had both my vehicles done.
Carwell and Krown are the same product I believe. One in US, one in Canada.
#3311105 - 03/13/14 09:13 PM Re: wd 40 [Re: Donald]
waltywalt Offline
Loc: ny
Ibm in pok and fishkill i used to plow the parking lots there. Anyways thanks for the info.
#3338100 - 04/09/14 07:45 PM Re: wd 40 [Re: waltywalt]
buck91 Offline
Loc: West Michigan
Search around here for underbody rust protection and rust proofing; LOTS of discussion. I think you have Crown or a similar line available in your area, but if not check out Fluid Film and Amsoil HDMP for a DIY application.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
1980 Yamaha XS850G
#3420676 - 07/10/14 12:26 PM Re: wd 40 [Re: Donald]
Smcatub Offline
Loc: Western NY
I know a guy up here in Buffalo that does the CarWell procedure in his driveway. He does an oil change in the autumn (to avoid doing one in the cold weather) and takes that used oil & sprays in on with a garden sprayer; the wand on that gets into all the cracks & crevices.
I'm not sure what's in the CarWell stuff, but his motor oil works well - none of his cars have rust, except one that already had rusted quarters when he bought it.
Edited by Smcatub (07/10/14 12:27 PM)
2005 Kia Optima nearing 100k
Supertech 0W-20 / TG Filter
